4 Replies Latest reply on Jul 6, 2010 11:08 AM by Eric Horde
    Form does not show "new" records from SQL Database
    Eric Horde
      I have a PDF form that pulls data from a SQL Server.  The fields in
      the PDF are populated from the database after selecting a specific
      record from a drop down and then clicking on a button labeled "Fill".
      The problem is that the dropdown does not display new records that
      have been recently added to the database.  I have to open the form up
      in designer then save it, (*note - I change nothing at this point.)
      Then when the form is opened back up in Adobe the dropdown show all
      the records including the new ones.  I even put a manual refresh on
      form to try and fix this an it did not help. Seriously stumped.
      Any help is greatly appreciated.
      Here is my code for the dropdown.
      topmostSubform.Page1.JobSelect::initialize - (JavaScript, client)
      var sDataConnectionName = "BBCC"; // example - var sDataConnectionName
      = "Test";
      var sColHiddenValue = "ContractAdmin_Key"; // example - var
      sColHiddenValue = "Dept_ID";
      var sColDisplayText = "JobDescription"; // example - var
      sColDisplayText = "Dept_ID"
      // Search for sourceSet node which matchs the DataConnection name
      var nIndex = 0;
      while(xfa.sourceSet.nodes.item(nIndex).name != sDataConnectionName)
      nIndex++;
      var oDB = xfa.sourceSet.nodes.item(nIndex);
      oDB.open();
      oDB.first();
      // Search node with the class name "command"
      var nDBIndex = 0;
      while(oDB.nodes.item(nDBIndex).className != "command")
      nDBIndex++;
      // Backup the original settings before assigning BOF and EOF to stay
      var sBOFBackup =
      oDB.nodes.item(nDBIndex).query.recordSet.getAttribute("bofAction");
      var sEOFBackup =
      oDB.nodes.item(nDBIndex).query.recordSet.getAttribute("eofAction");
      oDB.nodes.item(nDBIndex).query.recordSet.setAttribute("stayBOF",
      "bofAction");
      oDB.nodes.item(nDBIndex).query.recordSet.setAttribute("stayEOF",
      "eofAction");
      // Clear the list
      this.clearItems();
      // Search for the record node with the matching Data Connection name
      nIndex = 0;
      while(xfa.record.nodes.item(nIndex).name != sDataConnectionName)
      nIndex++;
      var oRecord = xfa.record.nodes.item(nIndex);
      // Find the value node
      var oValueNode = null;
      var oTextNode = null;
      for(var nColIndex = 0; nColIndex < oRecord.nodes.length; nColIndex++)
      { if(oRecord.nodes.item(nColIndex).name == sColHiddenValue)
      { oValueNode = oRecord.nodes.item(nColIndex); } else
      if(oRecord.nodes.item(nColIndex).name == sColDisplayText) { oTextNode
      = oRecord.nodes.item(nColIndex); } }
      while(!oDB.isEOF())
        this.addItem(oTextNode.value, oValueNode.value);
         oDB.next();
      // Restore the original settings
      oDB.nodes.item(nDBIndex).query.recordSet.setAttribute(sBOFBackup,
      "bofAction");
      oDB.nodes.item(nDBIndex).query.recordSet.setAttribute(sEOFBackup,
      "eofAction");
      // Close connection
      oDB.close();
      Here is code for the refresh button
      topmostSubform.Page1.Button27::click - (JavaScript, client)
      sourceSet.BBCC.requery();
