1 Reply Latest reply on Jul 1, 2010 9:32 AM by ARM2705
    Opening files with no extension
    Mario - Roma
      Adobe Reader is installed on 2 different PCs running Windows XP, PC1 and PC2.
      Both PCs need to open .pdf files with no extension, because an application renames files, let's say "file1pdf", as "file1", without altering the contents.
      On PC1 if I try to open a file, let's say "file1", I see a list of available applications including "Adobe Reader".
      On PC2 if I try to open the same file I don't see "Adobe Reader" in the list of available applications.
      Adobe reader is installed on both PCs.
      How can I add "Adobe Reader" to the list of available applications to open files with no extension on PC2?
      Regards
      Marius
        • 1. Re: Opening files with no extension
          ARM2705 Adobe Employee
          Click on "Browse" button at the "Open With" dialog and navigate to the location, where acrord32.exe is located. Preferebly, it should be this location "C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe" unless you have installed at some customized location.  I'm assuming you have installed Reader 9. Once you add Adobe Reader in the open with list, it would continue to appear next time onwards.
