2 Replies Latest reply on Nov 19, 2010 5:28 AM by MacUsher
    datagrid: tooltipcreate="<fn>" not called?
    ethrbunny
      Im hoping to create a custom tooltip function for a datagrid. Rather than taking the 'datatip' approach Im trying to set one function for the whole grid. Unfortunately the function I set isn't getting called.
      <mx:DataGrid id="studiesGrid" width="100%" height="100%" dataProvider="{participationArrayCollection}" editable="true"
      toolTipCreate="createToolTip( event )" toolTipStart="startToolTip(event)">
      Has anyone tackled this before? The docs make it sound straightforward.
        • 1. Re: datagrid: tooltipcreate="<fn>" not called?
          ethrbunny Level 1
          FWIW here's the answer:
          To set a custom tooltip on a datagrid you need to add event listeners for
          studiesGrid.addEventListener( ListEvent.ITEM_ROLL_OUT, onRollOut);
          studiesGrid.addEventListener( ListEvent.ITEM_ROLL_OVER, onRollOver);
          studiesGrid.addEventListener(ToolTipEvent.TOOL_TIP_CREATE, createToolTip );
          private function createToolTip(event:ToolTipEvent):void
               var ptt:PanelToolTip = new PanelToolTip();
               ptt.title = "Subjects";
               ptt.bodyText = "event.target.toolTip";
               event.toolTip = ptt;
          private function onRollOver(event:ListEvent):void
               event.target.toolTip = null;
               var itemX:int = event.itemRenderer.x;
               var itemY:int = event.itemRenderer.y;
               var point:Point = event.currentTarget.contentToGlobal(new Point(itemX,itemY));
               event.target.toolTip = "tip text";
          private function onRollOut(event:ListEvent):void
               if (event.target.toolTip != null)
          This is the PanelToolTip:
          <mx:Panel xmlns:mx="http://www.adobe.com/2006/mxml" implements="mx.core.IToolTip"
          width="200" alpha="1.0" backgroundColor="#FFFFDD"
          borderColor="black" borderStyle="solid">
          <mx:Script>
          <![CDATA[
          [Bindable]
          public var bodyText:String = "";
          //  Implement required methods of the IToolTip interface
          * @private
          * @inheritDoc
          public var _text:String;
          * @private
          * @inheritDoc
          public function get text():String
          return _text;
          * @inheritDoc
          public function set text(value:String):void
          </mx:Script>
          <mx:Text text="{bodyText}" percentWidth="100"/>
          </mx:Panel>
          • 2. Re: datagrid: tooltipcreate="<fn>" not called?
            MacUsher
            i wrote bs and can't delete this post, sorry...
