1 Reply Latest reply on Jul 1, 2010 6:17 PM by Michael L Hale
    PerLayerMetadata Panel not working correctly in CS5
    Yelnats1 Level 1
      When switching between multiple Photoshop documents, the PerLayerMetadata example panel shows the metadata of the document that is being switched away from, not the newly selected document.
      In CS5, the panel receives the select event, then the panel does its thing, then Photoshop updates  activeDocument to point to the newly selected file.
      In CS4, Photoshop activeDocument is pointing to the newly selected file before the panel acts on the event.
        • 1. Re: PerLayerMetadata Panel not working correctly in CS5
          Michael L Hale Level 5
          Something similar happens with a panel I have created. I have found two ways to fix it.
          One is to add app.refresh() to the event handler. That works fine but slows down the panel. And I could not find a way to tell what was being selected so I could add the refresh to just the select document event.
          So instead I just added a button to the panel to manually update the panel info.
