1 Reply Latest reply on Aug 9, 2010 10:01 PM by Balakrishnan V
    Event driven service calls
    DNelson72
      I am an extremely novice user so please forgive me if this question seems absolutely mundane.  I know I'm missing something fundamental.
      Basically what I want to do is call the service getOMContent when a user clicks an item in the data grid that is populated by the service getCode.  A parameter (codeid) is passed to the service in order to retrieve a single row.  I then want to display the returned data in a text box.
      I have included my mxml and php code below.
         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:complianceservice="services.complianceservice.*"  xmlns:valueObjects="valueObjects.*">
      <fx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.events.FlexEvent;
      import mx.events.ListEvent;
      protected function dataGrid_creationCompleteHandler(event:FlexEvent):void
      getCodeResult.token = complianceService.getCode();
      protected function dataGrid_itemClickHandler(event:ListEvent):void
      getOMContentResult.token = complianceService.getOMContent(code.codeid)
      </fx:Script>
      <fx:Declarations>
      <s:CallResponder id="getCodeResult"/>
      <valueObjects:Code id="code"/>
      <complianceservice:ComplianceService id="complianceService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
      <valueObjects:Omcont id="omcont"/>
      <s:CallResponder id="getOMContentResult"/>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      fx:Binding source="dataGrid.selectedItem as Code" destination="code"/>
      <mx:DataGrid x="23" y="25" id="dataGrid" creationComplete="dataGrid_creationCompleteHandler(event)" dataProvider="{getCodeResult.lastResult}" height="143" itemClick="dataGrid_itemClickHandler(event)">
      <mx:columns>
      <mx:DataGridColumn headerText="Code ID" dataField="codeid"/>
      <mx:DataGridColumn dataField="title" headerText="Title"/>
      </mx:columns>
      </mx:DataGrid>
      <s:TextArea x="23" y="194" id="txtReturn" text="{omcont.omcontent}"/>
      </s:Application>
      public function getCode() {
           $stmt = mysqli_prepare($this->connection,
                "SELECT
                    code.codeid,
                    code.subpart,
                    code.title,
                    code.codecontent,
                    code.material,
                  code.component,
                    code.type,
                    code.offshore,
                    code.timeinterval,
                    code.procdr,
                    code.tablefigure
                 FROM code
                 ORDER BY code.codeid");
            $this->throwExceptionOnError();
            mysqli_stmt_execute($stmt);
            $rows = array();
            mysqli_stmt_bind_result($stmt, $row->codeid, $row->subpart, $row->title, $row->codecontent,
      $row->material, $row->component, $row->type, $row->offshore,
      $row->timeinterval, $row->procdr, $row->tablefigure);
            while (mysqli_stmt_fetch($stmt)) {
                $rows[] = $row;
                $row = new stdClass();
            mysqli_stmt_free_result($stmt);
            mysqli_close($this->connection);
            return $rows;
      public function getOMContent($codeID) {
                "SELECT
                      code.codeid,
                      code.omcontent
                  FROM code
                  WHERE code.codeid LIKE ?");
            mysqli_stmt_bind_param($stmt, 's', $codeID);
            $rows = array();
            mysqli_stmt_bind_result($stmt, $row->codeid, $row->omcontent);
                $rows[] = $row;
      return $rows;
        • 1. Re: Event driven service calls
          Balakrishnan V Level 3
          I am not sure your Flex code has a definition for code.codeid anywhere.
          If its is your intention to choose the id of the clicked row, you could probably try
          yourDataGridDataProvider.getItemAt(event.rowIndex).codeid
          Hope this helps,
          Balakrishnan V
