0 Replies Latest reply: Jul 1, 2010 9:33 PM by John Whitney RSS
    Bug in ExtendScript's regular expression engine
    John Whitney Community Member
      I'm using ExtendScript 3.92.115, and I'm noticing that a certain regular expressions don't work properly.  I've tried the same expressions on popular browsers, and they work fine.  Here's an example:
      alert('ab'.match(/(.)(?:.*?)$/));
      The alert should display the array: ["ab", "a"], because there is a match ("ab"), and one capturing group ("(.)" captures "a").  Instead it displays ["ab", undefined], which makes no sense.  It works fine if both groups are capturing: "(.)(.*?)$", if you remove the non-greedy modifier: "(.)(?:.*)$", or even if you don't group the second part: "(.).*?$".
      Any thoughts?  I can modify my regular expressions to work around these problems, but it'd be good to fix the engine if it's really broken, as I suspect.
      Thanks!
