2 Replies Latest reply on Jul 2, 2010 1:51 AM by EmaGht
    Display .doc document
    EmaGht
      Hi!
      I would like to know if is it possible to display a .doc document in a new window in the browser
      I already tryed with the NavigateToURL but it asks me if I want to save or open the file,
      I need it to be opened directly in the browser if possible...
      Thanks for help!
      Regards
      Ema
        • 1. Re: Display .doc document
          Dajji
          You would need to create a redirector for that. Create an html file which will redirect to the .doc file on the load event of body. Open this html file from your flash program.
          • 2. Re: Display .doc document
            EmaGht Level 1
            This code regards a Pdf file:
            <html>
            <body>
              <object id="PDFObj"
                data="test.pdf"
                type="application/pdf"
                width="100%"
                height="100%"/>
            </body>
            </html>
            The file i need to create for the ".doc" document should be almost the same, right?
