2 Replies Latest reply on Jul 2, 2010 11:14 AM by =VA=FyreHeart
    Datagrid and Update php script not working
    djh88ukwb Level 1
      I have a datagrid pulling data from an array,  my code is this.
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="application1_creationCompleteHandler()">
          <fx:Declarations>
              <mx:RemoteObject id="db_services" fault="db_services_faultHandler(event)" showBusyCursor="true">
                  <mx:method name="testfunction" result="qrytestfunction(event)"/>
              </mx:RemoteObject>
              <mx:HTTPService id="swapservice" url="swap.php" method="POST" result="swapResult(event)">
              </mx:HTTPService>
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.controls.Alert;
                  import mx.events.FlexEvent;
                  import mx.events.ListEvent;
                  import mx.managers.PopUpManager;
                  import mx.rpc.events.FaultEvent;
                  import mx.rpc.events.ResultEvent;
                  import spark.events.IndexChangeEvent;
                  import spark.events.TextOperationEvent;
                  [Bindable] private var resultArr:ArrayCollection = new ArrayCollection();
                  [Bindable] public var selectedID:String;
                  protected function db_services_faultHandler(event:FaultEvent):void
                      // Alert.Show("something went wrong")
                  private function qrytestfunction(res:ResultEvent):void
                      resultArr = res.result as ArrayCollection;
                  protected function application1_creationCompleteHandler():void
                      db_services.endpoint = "http://localhost/amfphp/gateway.php";
                      db_services.source = "jobs";
                      db_services.destination = "amfphp";
                      db_services.getOperation("testfunction").send();
                  protected function clicky(event:ListEvent):void
                  selectedID = event.itemRenderer.data.id;
                  swapservice.send();
                  private function swapResult(evt:ResultEvent):void
                      Alert.show(evt.result.status, "Result");
          </fx:Script>
          <mx:DataGrid x="10" y="10" width="494" height="442" dataProvider="{resultArr}" itemClick="clicky(event)">
              <mx:columns>
                  <mx:DataGridColumn headerText="ID" dataField="id" width="40"/>
                  <mx:DataGridColumn headerText="URL" dataField="url"/>
                  <mx:DataGridColumn headerText="Vis" dataField="visible" width="50"/>
              </mx:columns>
          </mx:DataGrid>
          <s:Label x="937" y="12" text="{selectedID}"  id="LoadedString_lbl"/>
      </s:Application>
      My php script is this
      <?php
      $hostname_conn = "localhost";
          $username_conn = "videochatadmin";
          $password_conn = "24627930";
          $conn = mysql_connect($hostname_conn, $username_conn, $password_conn);
          mysql_select_db("videochat");
          $sql ="UPDATE test SET visible ='yes' WHERE id = '3'";
          if (!mysql_query($sql, $conn))
              echo "<status>not ok</status>";
          else
              echo "<status>ok</status>";
      But for some reason, sometimes it changes the value to yes, othertimes it dosent, bring the ppop up result box says ok.
      Any idea what i have done wrong ?
        • 1. Re: Datagrid and Update php script not working
          rootsounds Level 4
          So this is a PHP issue?
          • 2. Re: Datagrid and Update php script not working
            =VA=FyreHeart
            I haven't run this code to actually debug it, but a few things come to mind...
            First, you realize that your PHP mysql_query call returns a Boolean that indicates if the query ran or not, not whether the database was actually changed. You can have a successful UPDATE (i.e. mysql_query==true) that affects 0 database rows.
            Second, I'm a little surprised just wrapping "ok" in "<status>" tags works at all, since that's not well-formed XML. I don't know if that might be confusing ActionScript, but echoing well-formed XML can only help.
            Third, I would expect your clicky() function to actually change the value of the column, but I don't see it doing that. Something like ListEvent.target.value=ResultEvent.result.staus (using class names, not objects here) should probably be happening.
            Anyway, that's just a once over. Hope that helps.
