4 Replies Latest reply on Jul 2, 2010 9:19 AM by Paul Riggott
    change resolution
    Sashikala Balasubramanian Level 1
      Is it posible to change the resolution while opening the tiff file in Photoshop using openOptions.
      regards,
      Sashi
        • 1. Re: change resolution
          xbytor2 Level 4
          There is no TiffOpenOptions object in the JS DOM, so the answer is no. You'll have to open and the change the resolution in separate steps.
          • 2. Re: change resolution
            The resolution property is read only. What is the method to change the resolution after opening the tiff file in Photoshop.
            • 3. Re: change resolution
              Michael L Hale Level 5
              Just like in the GUI you change the resolution with image size.
              docRef.resizeImage(undefined, undefined, 300, ResampleMethod.NONE );
              • 4. Re: change resolution
                Paul Riggott Level 6
                If you only want to change the resolution it could be done in Bridge.
                #target bridge
                var newRes="300";
                    try{
                          loadXMPLib();
                          var thumb = new Thumbnail( app.document.selections[0] );
                          app.synchronousMode = true;
                          var xmp = new XMPMeta(thumb.synchronousMetadata.serialize());
                          var ResX = xmp.setProperty( XMPConst.NS_TIFF, 'XResolution', newRes+"/1");
                          var ResY = xmp.setProperty( XMPConst.NS_TIFF, 'YResolution', newRes+"/1");
                          var PerInch = xmp.setProperty( XMPConst.NS_TIFF, 'ResolutionUnit',2); //Pixels per inch
                          var newPacket = xmp.serialize(XMPConst.SERIALIZE_USE_COMPACT_FORMAT);
                          thumb.metadata = new Metadata(newPacket);
                          unloadXMPLib();
                    }catch(e){ alert(e); unloadXMPLib();}
                function loadXMPLib(){
                if (ExternalObject.AdobeXMPScript == undefined) {
                    ExternalObject.AdobeXMPScript = new ExternalObject("lib:AdobeXMPScript");
                function unloadXMPLib(){
                   if( ExternalObject.AdobeXMPScript ) {
                      try{
                         ExternalObject.AdobeXMPScript.unload();
                         ExternalObject.AdobeXMPScript = undefined;
                      }catch (e){ }
                The cache will need to be purged to show the correct details though.
