5 Replies Latest reply on Jul 5, 2010 2:07 AM by Matt Le Fevre
    Some help with transitions
    djh88ukwb
      Hello all,
      Im trying to get to grips with trandisitions.
      I have  a basic layout -
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" width="828" height="532">
          <mx:DataGrid x="6" y="6" height="516">
              <mx:columns>
                  <mx:DataGridColumn headerText="Column 1" dataField="col1"/>
                  <mx:DataGridColumn headerText="Column 2" dataField="col2"/>
                  <mx:DataGridColumn headerText="Column 3" dataField="col3"/>
              </mx:columns>
          </mx:DataGrid>
          <s:BorderContainer x="316" y="6" width="232" height="516" id="tab1">
              <s:Button x="10" y="483" label="Button" click="tab2.visible=true"/>
          </s:BorderContainer>
          <s:BorderContainer x="562" y="6" width="232" height="516" id="tab2" visible="false">
      </s:Application>
      Where when you click the button in tab 1  tab 2 appears.  At the moment it jus pops up, the normal way flex does it.
      How easy is it to add some transitions and effects so that it fades in or something ?
      ANy help would be great !
        • 1. Re: Some help with transitions
          VRPDeveloper Level 3
          You need to define states and transitions and need to set PropertyAction of it... I am giving you an example ,you can do something like this in your application....
          <?xml version="1.0" ?>
          <!-- transitions\ActionTransitions.mxml -->
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
              verticalAlign="middle"
              layout="vertical">
              <!-- Define one view state, in addition to the base state.-->
              <mx:states>
                  <mx:State name="OneOnly">
                      <mx:SetProperty target="{p2}" name="visible" value="false"/>
                          name="includeInLayout" value="false"/>
                  </mx:State>
              </mx:states>
              <!-- Define Transition array with one Transition object.-->
              <mx:transitions>
                  <mx:Transition id="toOneOnly" fromState="*" toState="OneOnly">
                      <mx:Sequence id="t1" targets="{[p2]}">
                          <mx:Iris showTarget="false" duration="350"/>
                          <mx:SetPropertyAction name="visible"/>
                          <mx:SetPropertyAction target="{p2}" name="includeInLayout"/>
                      </mx:Sequence>
                  </mx:Transition>
                  <mx:Transition id="toAnyFromAny" fromState="*" toState="*">
                      <mx:Sequence id="t2" targets="{[p2]}">
                          <mx:Iris showTarget="true" duration="350"/>
                      </mx:Sequence>
                  </mx:Transition>
              </mx:transitions>
              <mx:Panel id="p1" title="One"
                  width="100" height="100">
                  <mx:Label fontSize="24" text="One"/>
              </mx:Panel>
              <mx:Panel id="p2" title="Two"
                  <mx:Label fontSize="24" text="Two"/>
              </mx:Panel>
              <mx:Button id="b1" label="Change state"
                  click="currentState = currentState == 'OneOnly' ? '' : 'OneOnly';"/>
          </mx:Application>
          • 2. Re: Some help with transitions
            djh88ukwb Level 1
            Thank you for your answer.
            So there is not way to add custom effects without adding extra states?  I would rather not do this, i am building out a quite a large app with lots of different states for log in's as it is, i dont want to confuse things anymore.
            Does the fact im using Flash BUilder 4 change anything ?
            Does this allow for it in another way ?
            • 3. Re: Some help with transitions
              Matt Le Fevre Level 4
              there's a vastly easier way
              add a transition in your declarations, give it an id +  duration and link it to the showEffect or hideEffect of whatever  component you want,
              ta daa
                  <fx:Declarations>
                      <!-- Place non-visual elements (e.g., services, value objects) here -->
                      <s:Transition>
                          <mx:Fade id="fadeIn" duration="1000"/>
                      </s:Transition>
                  </fx:Declarations>
                  <mx:DataGrid id="dg1" x="6" y="6" height="516" hideEffect="{fadeIn}">
                      <mx:columns>
                      </mx:columns>
                  </mx:DataGrid>
                      <s:Button x="10" y="483" label="Button" click="tab2.visible = true; dg1.visible = false"/>
                  <s:BorderContainer x="562" y="6" width="232" height="516" id="tab2" showEffect="{fadeIn}" visible="false">
              </s:Application>
              • 4. Re: Some help with transitions
                djh88ukwb Level 1
                Thank You
                What other transitions are there ?
                • 5. Re: Some help with transitions
                  Wipe up/down/left/right, dissolve, move, rotate, resize, blur, glow etc....
                  there will be a list somewhere on google or the flex docs pages i imagine, those are just the ones i easily remember.
