0 Replies Latest reply on Jul 2, 2010 9:41 AM by msf5042
    SQL getResults always null?
    msf5042
      I am having an issue that I cannot figure. I cannot select data from my SQL database, getResults() always returns null.... here is some of my code, any help is appreciated:
      public function init():void {
      conn.addEventListener(SQLEvent.OPEN, openHandler);
      conn.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      dbFile = File.applicationStorageDirectory.resolvePath("ArnoldMagic.db");
      conn.openAsync(dbFile);
      createTables();
      private function createTables():void {
      var settingsSQL:String =
      "CREATE TABLE IF NOT EXISTS settings (" +
      "    id INTEGER PRIMARY KEY AUTOINCREMENT, " +
      "    flashDuration TEXT, " +
      "    pauseDuration TEXT, " +
      "    manualOperation TEXT, " +
      "    listRandomized TEXT, " +
      "    recordResults TEXT " +
      var initSettingsSQL:String = "INSERT INTO settings (flashDuration, pauseDuration, manualOperation, listRandomized, recordResults) " +
      "VALUES('1 second','1 second','YES','YES','YES')";
      var createSettings:SQLStatement = new SQLStatement();
      createSettings.sqlConnection = conn;
      createSettings.text = settingsSQL;
      createSettings.addEventListener(SQLEvent.RESULT, createResult); // ***************THIS GETS EXECUTED
      createSettings.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      createSettings.execute();
      var initSettings:SQLStatement = new SQLStatement();
      initSettings.sqlConnection = conn;
      initSettings.text = initSettingsSQL;
      initSettings.addEventListener(SQLEvent.RESULT, createResult); //********THIS GETS EXECUTED
      initSettings.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      initSettings.execute();
      private function updateSettings():void {
      selectStmt = new SQLStatement();
      selectStmt.sqlConnection = conn;
      selectStmt.text = "UPDATE settings SET flashDuration = '" + flashDurationCombo.selectedItem + "'," +
      "pauseDuration='" + pauseDurationCombo.selectedItem + "'," +
      "manualOperation='" + manualOperationCombo.selectedItem + "'," +
      "listRandomized='" + listRandomizedCombo.selectedItem + "'," +
      "recordResults='" + recordResultsCombo.selectedItem + "' where id='1';";
      //selectStmt.addEventListener(SQLEvent.RESULT, updateSettingsHandler);
      //selectStmt.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      try {
      selectStmt.execute();
      } catch(err:Error) {
      trace("ERROR (updateSettings): " + err.message);
      return;
      getSettings();
      public function getSettings():void {
      SQLstmt = new SQLStatement();
      SQLstmt.sqlConnection = conn;
      SQLstmt.text = "SELECT id FROM settings WHERE id='1'";
      try {
      SQLstmt.execute();
      trace("ERROR (getSettings): " + err.message);
      return;
      var result:SQLResult = SQLstmt.getResult();
      if(result == null) { //******************THIS ALWAYS HAPPENS
      trace ("WARNING (getSettings): result null");
      return;
      if(result.data == null) {
      trace ("WARNING (getSettings): data null");
      return;
      settings = new ArrayCollection(result.data);
      //pauseDurationCombo.selectedItem = result.data[0];
      testLabel.text = settings[0];
