This content has been marked as final.
Show 4 replies
1. Re: From Powerpoint to Photoshop
- JM - Jul 2, 2010 12:54 PM (in response to H3lue)>printing as a PDF
don't print to PDF, instead save it as a PDF.
then open the PDF in PS, when you get the dialog in PS choose images and select the image that you are looking for.
2. Re: From Powerpoint to Photoshop
Mike Ornellas Jul 2, 2010 1:00 PM (in response to - JM -)Export for Web from Powerpoint. It will generate a collect for output of the images in the document at file resolution. At that point, you can determine if your images are garbage or not.
3. Re: From Powerpoint to Photoshop
- JM - Jul 2, 2010 1:04 PM (in response to Mike Ornellas)Hi Mike
That's a good method for easily finding the images, but I find that it doesn't leave the image intact as the original imported rez and file type. Often it will drop it to an indexed gif etc.
regards and happy 4th
4. Re: From Powerpoint to Photoshop
Mike Ornellas Jul 2, 2010 1:12 PM (in response to - JM -)Hmm -
It should. I have always found that it will do a direct collect and not down sample.
