7 Replies Latest reply on Dec 17, 2010 1:56 PM by Bob Dix Photographer
    Capturing video from Canon Vixia HV 30
    filmschooljefe08 Level 1
      I am trying to capture footage from my Canon Vixia HV30 into premier.  When I go to File--Capture it says that the capture device is offline.  I am using USB connection and on a Mac.
      Anyone know what may be causing this problem?
        • 1. Re: Capturing video from Canon Vixia HV 30
          Harm Millaard Level 7
          Capturing only works over fire wire. Never USB.
          • 2. Re: Capturing video from Canon Vixia HV 30
            I was hoping that wouldnt be the answer haha but thank you!  Guess I need to buy a cable this weekend.
            • 3. Re: Capturing video from Canon Vixia HV 30
              the_wine_snob Level 9
              I would imagine that the USB cable is only to get stills from say an SDX card onto your HDD.
              As Harm mentions, Capture (what you want) is only via FW.
              • 4. Re: Capturing video from Canon Vixia HV 30
                lanstrad Level 1
                Have the HV30 and I can confirm this works with FIrewire. Although I may have to
                shut down cam and fire it up  from time to time so it will be detected... But when this happen, it happens just once when I begin the session (though it stay connected...)
                However, if anyone can tell me if I can transfer still photos with USB without the apparently supplied CD software I never found in the box... For instance, maybe with Photoshop ? - My other solution would be to find a Mini SD adapter with USB connection, but I can't believe there is not a *direct* way to do it without pulling the SD card out ??
                • 5. Re: Capturing video from Canon Vixia HV 30
                  Scott A 1974
                  I have a similar camera (M31) and I think you may be going at this wrong.  I don't think your camera even has a firewire port.  It records AVCHD files.  Just copy the files through USB to a folder on your hd and import them into Premiere.  It is much faster to copy them as files than it is to capture them.  Will take a few minutes to copy the files as opposed to real time to capture.
                  • 6. Re: Capturing video from Canon Vixia HV 30
                    For the transfer of stills, via USB, I use a program, ThumbsPlus from Cerious Software, and it works fine. They update the camera modules often, so RAW from the newest Nikons, Canons, etc., are quickly supported. Though I have the appropriate software for each of my cameras, I find ThumbsPlus to be better, than what the mfgr. supplied. I even use it before Photoshop and ARC.
                    • 7. Re: Capturing video from Canon Vixia HV 30
                      Bob Dix Photographer Level 2
                      Scott,
                      The Canon HV 20/30/40 is a tape videocamcorder , we have used it for 4 years , it has a firewire port for HDV capture to Premiere Pro on a PC and USB2 for transfer of still images at 1920 x 1080i and.to avi file clips as video..
                      The video is at 1920 x 1080p and stored at 1440  x 1080i and it anormorphically outputs the video as 16:9 for HD widescreen (PAL) , it can also be used for play back of tapes recorded in HDV standard from the Canon Professional Canon XL H1, XH G1 or XHA 1 in both 25F mode or 50i (see Canon's Manual Specifications p98 General Information. And can be used as a VTR for transferring H.264 mov  at 1920 x1080 from a Canon 5D mark II for presentation after editing in Premiere Pro on a , say a Sony Bravia Tv HD ,using an HDMI port from the camcorder on a pre-recorded high definition tape. The m2t file generated via Premiere Pro can be used to Export to Blu-Ray  in either H.264 or mpeg-2/HDV.
                      Ie., Unless this Vixia 30 is an intirely different unit to that sold in Australia.
