1. Re: Acrobat 9.3.3 missing DLL
lrosenth Jul 4, 2010 8:44 AM (in response to Polda2)That is correct - this was done for security reasons.
If you wrote the plugin, then you can easily modify your code to load the plugin from the explicit location (which is what you should have been doing all along anyway). If this is someone else's, then you need to contact the author/developer for a fix.
2. Re: Acrobat 9.3.3 missing DLL
Polda2 Jul 6, 2010 11:31 AM (in response to lrosenth)I wrote the plug-in.
However, Acrobat searches for the third-party DLL even before the first line of my PluginInit function is executed.
Therefore the DLL cannot be loaded explicitly. I tried experimenting with delay-loading the DLL and then the error comes up and only after confirming it my PluginInit starts. So it is not a good solution anyway.
Please see this thread:
http://forums.adobe.com/thread/672182?tstart=0
I think we all are seeing the same problem.
Acrobat does not load the DLLs (the APIs are not the problem) from "plug_ins" subfolder. I would expect at least some warning before such a change is made.
to be more specific:
I have a folder created under the "plug_ins" folder, something like "MyFolder". In this folder there are two files:
MyPlug.api and FromOther.dll. Now the FromOther.dll is not loaded. Acrobat complains about missing even before MyPlug.api is initialized.
In every previous version everything was fine.
Polda
3. Re: Acrobat 9.3.3 missing DLL
lrosenth Jul 6, 2010 12:12 PM (in response to Polda2)Acrobat doesn't load ANY DLLs - except those that it knows about and the .api files. Loading any other DLL is province of your software (when loaded explicitly) or via the OS (when simply marked as linked).
What we are doing is imply ensuring that automatic (implicit) loading doesn't happen from directories that it should not in order to prevent rogue DLLs from replacing the ones we are expecting (which has happened and caused both incompatibility/instability as well as insecurity).
Make sure that your linker settings (in VS) are not set to auto-load the DLL and instead your do it yourself (delay loading). Either that or set the DLL load path in the linker.
4. Re: Acrobat 9.3.3 missing DLL
Polda2 Jul 6, 2010 11:37 PM (in response to lrosenth)OK,
so just for your information (I do not know whether this bears some security risk):
When the DLL is simply Copied to "plug_ins" folder. Everything works fine - Acrobat loads the DLL and my plugin then works with the DLL in the subfolder.
It just seems a little strange to me.
I will switch to explicit DLL loading.
Thank you
Polda
