11 Replies Latest reply on Jul 5, 2010 1:33 PM by kobe_08
    Validation error for tag cfloop
    kobe_08
      Hi All,
      Complete newbie to CF here.  I've inherited (or bought) an online business which has its site written in CF.  I haven't done this sort of stuff before but do work SQL for a living and object oriented stuff plus have done a bit of html and php so CF isn't mind blowing to me (in its simple form).
      I've downloaded my site on to my computer to run a local copy that I can hack to pieces if needs be.  For some reason, I have a few problems with the site running locally.  The first error I'm getting is a Attribute validation error for tag cfloop.
      Basically, index.cfm has this bit of code in it:
      <cfinvoke component="#datasets#" method="storedProcedure" returnvariable="getFeaturedWineries_qry">
          <cfinvokeargument name="storedProcedure" value="usp_GetFeaturedWineries">
      </cfinvoke>
      Ok, easy enough.  Anyway, there's a call down the page to:
      <cfinclude template = "#REQUEST.CFMPath#includes/displayFeaturedWineries.cfm">
      Within displayFeaturedWineries.cfm is the code that calls the stored proc invoked above:
      <cfloop query="getFeaturedWineries_qry" startrow="1" endrow="2">
      Bam, that's where the error occurs.  "The value of the attribute query, which is currently getFeaturedWineries_qry, is invalid.
      What???  The stored proc exists and it only returns two records (which begs me to wonder why you would have startrow and endrow but anyway, it doesn't work with or without it).
      The other interesting thing is that this works on production, NO PROBLEM!!!  WTF?  How can it work on production but not locally.
      The only thing I'm starting to think is:
      a)  I've missed a setting somewhere in CF or
      b)  I'm running Apache as compared to IIS or
      c)  I'm running SQL 2008 and CF 9 which will no doubt be different to the production host server.
      Should B or C be causing THAT type of problem??
      Matt
        • 1. Re: Validation error for tag cfloop
          JR "Bob" Dobbs Level 4
          Here are some thing to try.
          1. You can use the CFDUMP tag to output the values of variables to assist you in troubleshooting.  If you use CFDUMP output the value of getFeaturedWineries_qry on the line before the CFLOOP do the contents appear as expected?
          2. Does a CFDUMP of #REQUEST.CFMPath#includes/displayFeaturedWineries.cfm point to a file that exists on your system?
          3. Same for #datasets#.
          4. In regards to Apache vs. IIS, could there be an issue with a path or other value being case sensitive in Apache?
          5. In regards to SQL Server does a SQL profile/trace actually show any queries/stored procedures being executed?
          It might be helpful to have more of your code to look at as well as more details about how your enviroment is setup.
          CFDUMP tag documentation
          http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-7e f7.html
          • 2. Re: Validation error for tag cfloop
            kobe_08 Level 1
            The cfdump shows me exactly what I thought, its looking for the stored proc usp_Featured Wineries.  After looking through more pages on the site, almost all pages have some kind of validation error for tag cloop around stored procs, BUT, not all.  The user that logs into the database is a dbo so I can't see what the problem is there.
            I installed IIS7 and got that working fine, so its not an Apache / IIS thing either.  I might try and trace the database server to see if there's a problem there, but I'm guessing its a setting problems either on the Database itself or ColdFusion.  None of it makes any sense otherwise (why would it run some procs and not others???).
            Any other thoughts?
            • 3. Re: Validation error for tag cfloop
              It is would be easier to advise you if you would post additional source code and error messages, if any, you receive.
              • 4. Re: Validation error for tag cfloop
                kobe_08 Level 1
                I'm not sure what code apart from the above is going to show you what you could possibly need to solve this, but here goes.  The following is only snippets of the code, but they are the relavant snippets.  Other stored procs work.  The cfdump for getFeaturedWineries_qry shows 'usp_getFeaturedWineries'.  I know its there because I've been unable to run "EXEC usp_getFeaturedWineries" after copying it straight out of the code.  As previously stated, there are other stored procs which are running fine.
                datasets.cfc
                    <cffunction name="storedProcedure">
                        <cfargument name="storedProcedure" required="Yes" type="string">
                        <cfstoredproc procedure = "#ARGUMENTS.storedProcedure#"
                                      datasource = "#REQUEST.DSN_NAME#"
                                      username   = "#REQUEST.DSN_USER#"
                                      password   = "#REQUEST.DSN_PASS#"
                                      returncode = "Yes">
                            <cfprocresult name="storedProcedure" resultset="1">
                        </cfstoredproc>
                        <cfreturn storedProcedure>
                    </cffunction>
                application.cfm
                    <!--- DATA SOURCE VARIABLES --->
                    <cfset DSN_NAME = "boutiqueWineriesTest">
                    <cfset DSN_USER = "coldfusion">
                    <cfset DSN_PASS = "coldfusion">
                index.cfm
                <cfobject component="#COMP_REF#.datasets" name="datasets">
                    <cfinvokeargument name="storedProcedure" value="usp_getFeaturedWineries">
                </cfinvoke>
                The value of the attribute query, which is currently  getFeaturedWineries_qry, is invalid.        The error occurred in C:\apps\iishome\includes\displayFeaturedWineries.cfm:  line 33
                Called from C:\apps\iishome\index.cfm: line 399
                Called from C:\apps\iishome\index.cfm: line 79
                Called from C:\apps\iishome\index.cfm: line 1
                31 :      <tr>
                32 :           <td width="626" colspan="3" class="productCenter_bg2">
                33 :          <cfloop query="getFeaturedWineries_qry" startrow="1" endrow="2">
                34 :              <div class="productCennews">
                35 :                  <table border="0" cellspacing="0" cellpadding="0">
                • 5. Re: Validation error for tag cfloop
                  kobe_08 Level 1
                  You wouldn't believe this, but I backed out ColdFusion 9, installed ColdFusion 8 and it worked a treat.
                  What has changed between CF 8 and 9 to make something like this to happen (as well as other problems).  Unreal........never seen something so problematic with backward compatibility.
                  • 6. Re: Validation error for tag cfloop
                    kobe_08 Level 1
                    Just when I think it's fixed....it's not.
                    It now works fine in CF 8 on the index page only.  Still getting the error on all others pages......any suggestions?
                    • 7. Re: Validation error for tag cfloop
                      Adam Cameron. Level 5
                      What do you mean it's "looking for" the proc? What is the output of the dump?  Did you put the dump in the function or the calling code?  What does your proc return if its query returns no rows? Does it return a null? If so, the thing is behaving exactly as one would expect: CF - all versions - will report a variable as undefined if it's set to null.  It also seems a bit odd that you're reusing the storedproc arg as the return value for the function. This shouldn't cause your situation, but it's not great code.
                      • 8. Re: Validation error for tag cfloop
                        Apologies for that being one big run-on paragraph. Am posting this via my phone and the main editor doesn't work on the iPhone's version of Safari, so need to use the HTML view. And I forgot to put <br /> tags in.
                        It sounds like a bit of a tirade when presented like that, but it wasn't intended to!
                        Adam
                        • 9. Re: Validation error for tag cfloop
                          kobe_08 Level 1
                          If I do a <cfdump var="getFeaturedWineries_qry"> I get: getFeaturedWineries_qry
                          If I do a <cfdump var="#getFeaturedWineries_qry"> I get the dump of the query.  So we're ok there on the index.cfm page (which has the invoke statements).
                          If I open a page that isn't index.cfm, the <cfdump var="#getFeaturedWineries_qry#"> from displayFeaturedWineries.cfm says Variable not defined.
                          Excuse me for being somewhat new, but that says to me that the variable is not being kept in memory after leaving the index page.  So how does it do it on the production environment (hosted environment) but not on my local environment??
                          Maybe mappings??  No idea....I'm a newbie
                          • 10. Re: Validation error for tag cfloop
                            Dan Bracuk Level 5
                            Regarding
                            That's because the variable is being created on index.cfm, the page that runs the stored procedure.
                            • 11. Re: Validation error for tag cfloop
                              kobe_08 Level 1
                              I'm seriously going to run and hide and bang my head against the wall several times until my brain clicks back into gear.
                              Apologies for wasting your time gentlemen.  I've found the problem.  It's called the operator!
