10 Replies Latest reply on Jul 6, 2010 4:30 AM by Scott R. Hamilton
    Saving an image to MySQL
    Scott R. Hamilton
      I'm trying to capture and save a image to a blob field in a mySQL
      database. I'm getting an http request error.
      Just what should my code be passing to the SQL insert query?  Nothing
      seems to work. (see the function captureImg)
      Scott
      Here's the code to capture and encode the image (this is a standard sample program):
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
              layout="vertical"
              verticalAlign="middle"
              backgroundColor="white" viewSourceURL="srcview/index.html">
      <mx:Script source="MySqlQry.as"/>
      <mx:Script source="MySqlReturnHandlers.as"/>
          <mx:Script>
              <![CDATA[
                  import mx.graphics.ImageSnapshot;
                  import mx.graphics.codec.*;
                  private const jpgEnc:JPEGEncoder = new JPEGEncoder();
                  private const pngEnc:PNGEncoder = new PNGEncoder();
                  private var ohSnap:ImageSnapshot;
                  private function captureImg(imgEnc:IImageEncoder):void {
                      ohSnap = ImageSnapshot.captureImage(img, 0, imgEnc);
                      textArea.text = ImageSnapshot.encodeImageAsBase64(ohSnap);
                      InsertImage(ohSnap);
          </mx:Script>
          <mx:ApplicationControlBar dock="true">
              <mx:ToggleButtonBar id="toggleButtonBar"
                      itemClick="captureImg(event.item.data);">
                  <mx:dataProvider>
                      <mx:Array>
                          <mx:Object label="Capture as JPEG" data="{jpgEnc}" />
                          <mx:Object label="Capture as PNG" data="{pngEnc}" />
                      </mx:Array>
                  </mx:dataProvider>
              </mx:ToggleButtonBar>
          </mx:ApplicationControlBar>
          <mx:Image id="img"
                  source="@Embed('../image/logo.jpg')" />
          <mx:TextArea id="textArea"
                  editable="false"
                  width="320"
                  height="160" />
      </mx:Application>
      The routine the make the hpptService call ensding the query to mySQL:
      private function InsertImage(imsSnap:ImageSnapshot):void {
          var sQry:String;
          sQry = "INSERT INTO image (picture) VALUES('" +imsSnap.data +"')";
          //Alert.show(sQry);
          mysqlQuery(sQry, "InsertImage");
      I am getting an http request error.
      Scott
        • 1. Re: Saving an image to MySQL
          David_F57 Level 5
          hi,
          If you want to save images to the db using amfphp is the way to go, it deals with the byte array directly so after you encode you simply pass the bytearray to mysql through a remote object, catalog.uploadImage(TmpImg) passes the bytearray(png or jpg) to mysql database quickly and cleanly.
          the php at the server end
          function uploadImage($ba) {
          $data = $ba->data;
          $mysql = mysql_connect(localhost,"root","");
          $data = mysql_real_escape_string($data);
          mysql_select_db( "catalog" );
          $Query = "INSERT INTO images (ID,data) VALUES(0,'$data')";
          $Result = mysql_query( $Query );
          return $Result;
          the call from the application
          private function saveImage(bd:bitmapData) : void
          var ba:byteArray= new byteArray()
             ba = PNGEncoder.encode(bd);
          finally
          catalog.uploadImage(ba);
          • 2. Re: Saving an image to MySQL
            Scott R. Hamilton Level 1
            Hi David,
            thanks for the reply.
            I'm using SQLDataServices which I purchased from Adobe and
            which only offers a HTTPService call using the POST method.
            Is there no way I can use this method to save the image to
            the database?
            Scott
            • 3. Re: Saving an image to MySQL
              UbuntuPenguin Level 4
              You should check out flexlibs its on google somewhere.  They have a function/class that takes an image and turns it into a string.  You can then set this string as a parameter in your httpservice and do what david said as far as pushing it into the db.  There is also the base64 class you can use to turn the image into a string somehow , but I forgot how to use it.
              Sincerely ,
                Ubu
              • 4. Re: Saving an image to MySQL
                Thanks Ubu,
                there is a JPEGEncoder class in standard flex.
                Do you have any idea how the flexlibencoder  differs from this?
                Regards,
                Scott
                • 5. Re: Saving an image to MySQL
                  Not really sure how they differ.  I believe the flexlib encoder came about at a relatively earlier time , or came with more convenience features.  Here is an example of how to use the stock Base64Encoder in actionscript.  You should modify it to suit your needs.
                  http://expertria.com/index.php/archives/30
                  If this post was helpful , please mark it as such.
                  import flash.display.BitmapData;
                  import com.adobe.images.JPGEncoder;
                  import mx.utils.Base64Encoder;
                  import flash.utils.ByteArray;
                  private static const QUALITY:Number =80
                  function getBase64FromComponent(photo:UIComponent) :String
                  var data1:BitmapData = new BitmapData(photo.width, photo.height); data1.draw(photo);
                  var en:JPGEncoder = new JPGEncoder(QUALITY);
                  var bArray:ByteArray=   en.encode(data1);
                  var encoder:Base64Encoder = new Base64Encoder();
                  encoder.encodeBytes(bArray, 0, bArray.length);
                  var base64data:String = encoder.flush();
                  return base64data;
                  • 6. Re: Saving an image to MySQL
                    Thans Ubu,
                    my problem is not so much the encoding of the image, its the
                    saving of it to the database.
                    Here's my encode code:
                    var
                    What should I write to the database -  ohSnap.data, or textArea.text?
                    Should I enclose the byte array in quotes?
                    What is tht best data type to receive the bytearray, a blob?
                    When I try top write the data to the database I get an
                    HTTP request error.
                    Scott
                    • 7. Re: Saving an image to MySQL
                      What I would do is , encode the image as a string for  transport purposes.  Then on the backend , transform the string into a bytearray.  Store that bytearray in the mysql database as a BLOB object.
                      Sincerely ,
                        Ubu
                      • 8. Re: Saving an image to MySQL
                        I just did a little experiment.
                        I encoded an image (the flex logo) and copied the byte array to
                        a text area. I copied this text using control-C.
                        I entered a record into my MySQL table manually and added the
                        text using control-V between two single quotes '<byte array>'
                        into the blob column. This worked.
                        I just can't do the same using an HTTP service call.
                        Scott
                        • 9. Re: Saving an image to MySQL
                          So are you turning the image into a base64 encoded string and then sending it as a parameter of the HTTPService ?
                          • 10. Re: Saving an image to MySQL
                            Yes, that's right. Here is the pertinent code:
                            In the flax app:
                            InsertImage(textArea.text);
                            In the HTTP service AS module:
                            private
                            function InsertImage(sImageCoded:String):void {
                            var sQry:String;
                            sQry =
                            "INSERT INTO image (lImageId, blbBitMap, txtImage, lRecipeId) "
                            sQry +=
                            "VALUES(0, '" +sImageCoded +"', 'text', 23)"
                            //Alert.show(sQry);
                            mysqlQuery(sQry,
                            "InsertImage");
                            As mentioned previously, an HTTPrequest error is generated although I can enter
                            the string into the blob manually in MySQL.
                            Scott
