2 Replies Latest reply on Jul 28, 2010 1:26 AM by hidarikani
    Spark skinning fade in
    hidarikani Level 2
      I want my custom component to fade in
      when it's added to a container
      but the state desn't change when the component is created so I can't use a transition.
      What can I do?
        • 1. Re: Spark skinning fade in
          David_F57 Level 5
          hi,
          Use the show event to fire your state change. then you get your transition  .
          David
          • 2. Re: Spark skinning fade in
            hidarikani Level 2
            Inside my custom Spark component:
                      public function Node() { //constructor
                           super();
                           addEventListener(FlexEvent.SHOW, visibilityHandler);
                           addEventListener(FlexEvent.HIDE, visibilityHandler);
                      protected function visibilityHandler(event:FlexEvent):void {
                           invalidateSkinState(); //this line is never executed
                      override protected function getCurrentSkinState():String {
                           var skinState:String = 'invisible';
                           if (visible)
                                skinState = 'up';
                           return skinState;
            visibilityHandler is never executed, so my skin state doesn't change but in Flex documentation:
            "After the last render event occurs, Flex performs the following actions: Makes the component visible by setting the visible property to true(...)"
