2 Replies Latest reply on Jul 5, 2010 12:35 PM by jerry98225
    Animation question...
    jerry98225 Level 1
      Hi guys.
         I am trying to do a simple animation. I want to fade in and resize a List inside creationcomplete. My problem is that I can alway see the element flash in before the element animation begin. On the other word, the user will see the element appear for 1 second->then fade in and resize animation. I was hoping anyone here could help me about it. thanks...
      my code.
      AS:
      protected function compList_creationCompleteHandler(event:FlexEvent):void
           compinfoResult.token = getCompList.compinfo();
           compinfoResult.addEventListener(ResultEvent.RESULT, completeLoading);
           function completeLoading(event:ResultEvent):void{
           fadeList.play();   //the animation will fire when the List get the result from the server...
           scaleList.play();
      mxml
      <s:Scale id="scaleList" scaleXFrom="0" scaleXTo="1" scaleYFrom="0"
      scaleYTo="1" duration="500" target="{compList}" />
      <s:Fade id="fadeList" alphaFrom="0" alphaTo="1" target="{compList}" />
      <s:List id="compList"
      width="280"
      height="560"
      x="0"
      y="0"
      alpha="0"
      creationComplete="compList_creationCompleteHandler(event)"
      itemRenderer="itemRenderer.compListItemRenderer"
      change="compList_changeHandler(event)"/>
        • 1. Re: Animation question...
          David_F57 Level 5
          hi,
          you could try something like this, obviously setting the properties you want to use
          David.
             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" creationComplete="application1_creationCompleteHandler(event)">
          <fx:Script>
          <![CDATA[
          import mx.collections.XMLListCollection;
          import mx.events.FlexEvent;
          import mx.rpc.events.FaultEvent;
          import mx.rpc.events.ResultEvent;
          [Bindable] private var empArr:XMLListCollection = new XMLListCollection();
          protected function getdata_faultHandler(event:FaultEvent):void
          // TODO Auto-generated method stub
          protected function getdata_resultHandler(event:ResultEvent):void
          EmpXMLCollection.source = event.result.children();
          fader.play();
          protected function application1_creationCompleteHandler(event:FlexEvent):void
          getData.send();
          </fx:Script>
          <fx:Declarations>
          <s:Parallel id="fader" target="{lst}" duration="3000">
          <s:Animate>
          <s:SimpleMotionPath property="alpha" valueTo="1.0"/>
          <s:SimpleMotionPath property="width" valueTo="300"/>
          <s:SimpleMotionPath property="height" valueTo="500"/>
          </s:Animate>
          </s:Parallel>
          <s:HTTPService id="getData" url="info.xml" resultFormat="e4x" fault="getdata_faultHandler(event)" result="getdata_resultHandler(event)"/>
          </fx:Declarations>
          <s:List id="lst" width="10" height="10" labelField="name" alpha="0" verticalCenter="0" horizontalCenter="0">
          <s:dataProvider>
          <mx:XMLListCollection id="EmpXMLCollection"/>
          </s:dataProvider>
          </s:List>
          </s:Application>
          • 2. Re: Animation question...
            jerry98225 Level 1
            thanks David...SimpleMotionpath is a good solution...:D
