12 Replies Latest reply on Jul 8, 2010 1:54 PM by thenoisystuff
    cannot export avi dv pal upper field dominance
    cicciograzini1
      hi all
      i have this problem with premiere pro cs5, when i try to export the sequence (made in upper dominance field), i can do it in avi dv pal but i cannot cange the fieldtipe chosing upper, by default premiere choses lower.
      in cs4 i can chose wich field use in interlaced mode, here the menu for change that options is locked, i have the same problem if i try to export in quicktime mov dv pal, cannot change the field dominace, a im forget something?
      tnx
