3 Replies Latest reply on Jul 5, 2010 11:26 PM by BhaskerChari
    how to set multiple styles on a single component in flex ?
    tuliptaurus
      Hi ,
      I would like to know how to set multiple styles on a single component in flex.
      Can anyone give me an example as to how to set multiple styles for a single component ?
      Thanks ,
      Regards,
      Ajantha
        • 1. Re: how to set multiple styles on a single component in flex ?
          BhaskerChari Level 4
          Hi tuliptaurus,
          You can apply multiple styles to a component by using inline styles directly on the component tag, by using external css and also using setStyle() method and also by applying skins you can change the appearanace of a component..
          Please refer the link below:
          http://blogagic.com/98/styling-flex-custom-components
          Bhasker Chari
          • 2. Re: how to set multiple styles on a single component in flex ?
            tuliptaurus Level 1
            Hi Bhasker ,
            Suppose i have got a button component like this
            <mx:Button id="stackedLayout"
                         width="30"
                        icon="@Embed('/assets/icons/stacked_col_up.png')"
                         disabledIcon="@Embed('/assets/icons/stacked_col_disabled.png')"
                        downIcon="@Embed('/assets/icons/stacked_col_dn.png')"
                        overIcon="@Embed('/assets/icons/stacked_col_over.png')"
                        styleName="blendButtonSkin"
                        toolTip="Stacked layout"
                        click="stackedLayoutDisplay();"
            its already using a style from an external css file
            .blendButtonSkin {
                fontFamily: Arial;
                fontSize: 11;
                color: #F1F1F1;
                textRollOverColor: #F1F1F1;
                textSelectedColor: #F1F1F1;
                horizontal-align:center;
                width:150;
                height:30;
                cornerRadius:5;
                upSkin:ClassReference('assets.skins.BlendButtonSkin');
                downSkin:ClassReference('assets.skins.BlendButtonSkin');
                overSkin:ClassReference('assets.skins.BlendButtonSkin');
                disabledSkin:ClassReference('assets.skins.BlendButtonSkin');
                selected-up-skin: ClassReference('assets.skins.BlendButtonSkin');
                selected-down-skin: ClassReference('assets.skins.BlendButtonSkin');
                selected-over-skin: ClassReference('assets.skins.BlendButtonSkin');
            My question is I need to remove those icon, disabledIcon, downIcon and overIcon  styles from the button component to another css selector so that I can use both blendButtonSkin Style(which is common to all the buttons in my application)   and also the override style tags from this particular button.
            Is there a way to do this other than setting them as inline styles which  i dont want to do cos my purpose is to eliminate all inline styles as  much as possible.
            Regards,
            Ajanta
            • 3. Re: how to set multiple styles on a single component in flex ?
              Hi tuliptaurus,
              You can setStyleName property for chnaging the external css dynamically by using the setStyle() method ...
              btn.setStyle("styleName","blendButtonSkinOther");
              You can change the external css by using the styleaName property with setStyle method..the line in blue..where blendButtonSkinOther is another css class..
              blendButtonSkin {
                  fontFamily: Arial;
                  fontSize: 11;
                  color: #F1F1F1;
                  width:150;
                  height:30;
                  cornerRadius:5;
              blendButtonSkinOther {
                  fontFamily: Arial;
                  fontSize: 11;
                  color: #F1F1F1;
                  width:150;
                  height:30;
                  cornerRadius:5;
              Bhasker Chari
