0 Replies Latest reply on Aug 23, 2007 7:18 AM by gumnam
    Graphics using graphic API are drawn below the loaded content created using Flash authoring tool
    gumnam
      Here is my problem.
      I am developing a Analog Dial component. Here , I am extending UIComponent and loading a swf file generated using Flash CS3 authoring tool ( the swf basically has the circle and needle) and adding the loaded content as child of Dial class.
      Next I use Graphics API to draw the major and minor ticks on the dial.
      As mentioned in the curveTo method of flash.display.Graphics class documentation ( http://livedocs.adobe.com/flex/201/langref/index.html), if you are using graphics api and also loading content created using the flash authoring environment the vector graphics will be drawn underneath the loaded content.
      Well , Is there any way to make the graphics appear on top of the loaded contents?
