2 Replies Latest reply on Jul 6, 2010 10:56 AM by the_wine_snob
    How To Smooth The Merging Between Two Identical loops?
    CruelRhetoric
      I am trying to make several identical objects seem as if they are one continuous loop.
      I understand I have to find the correct CTI placement on each object for the merge to come off smoothly, but
      what I am trying to figure out is if there is a way to fade the ends of each perspective object at the point of
      merging then slide the object into the correct postition.  This was an old trick I used in another program to
      match the exact point where the loops won't create a 'screen glitch' at that point of playback that would be noticable...
      *The selected video object, under the green arrow, in the image above has a reverse attribute already
      AS ALWAYS THANKS IN ADVANCE
