RH8, current patch.
I would like to use a skin for my current WebHelp project (not WebHelp Pro). I have skins listed in the Project Set Up pod, but when I try to generate the help files, the skin field is inactive. Is there some setting elsewhere in the program that must be set first?
Hi there
What other options are set? For example, did you enable Section 508? If you did, that's for accessibility and skins are lost on visually impaired folks.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
Hi there
Cheers... Rick
The 508 option was exactly what I had done. It is documented (in the generate webhelp section of the online help) but I must have missed it. I had figured it out just a few minutes beore your post.
Thanks!
