3 Replies Latest reply on Nov 28, 2010 9:42 PM by dmera
    Flex/Zend channel connect failed error...
    jerry98225 Level 1
      Hi guys.
          I am using Flex and php to develop my project. Everything works great in my local machine. However, when I upload my files to my server (godaddy.com). I got the error when loading my flex application.
      The pop-up error message is
      send failed
      channel.connect.failed.error
      Netconnection.call.Badversion: url:
      http://mydomail/folder/gateway.php
      I have upload my ZendFramewrok folder into my server and amf_config.ini has been configured. (webroot =http://mydomain)
      I am not sure what's going on here. Please help. Thanks.
      Update: my gateway.php
      <?php
      ini_set
      ("display_errors", 1);
      $dir
      = dirname(__FILE__);
      $webroot
      = $_SERVER['DOCUMENT_ROOT'];
      $configfile
      = "$dir/amf_config.ini";
      //default zend install directory
      $zenddir
      = $webroot. '/ZendFramework/library'; //I did upload the ZendFramwork folder
      //Load ini file and locate zend directory
      if(file_exists($configfile)) {
      $arr
      =parse_ini_file($configfile,true);
      if(isset($arr['zend']['webroot'])){
        $webroot
      = $arr['zend']['webroot'];
        $zenddir
      if(isset($arr['zend']['zend_path'])){
        $zenddir
      = $arr['zend']['zend_path'];
      // Setup include path
      //add zend directory to include path
      set_include_path
      (get_include_path().PATH_SEPARATOR.$zenddir);
      // Initialize Zend Framework loader
      require_once
      'Zend/Loader/Autoloader.php';
      Zend_Loader_Autoloader::getInstance();
      // Load configuration
      $default_config
      = new Zend_Config(array("production" => false), true);
      $default_config
      ->merge(new Zend_Config_Ini($configfile, 'zendamf'));
      $default_config
      ->setReadOnly();
      $amf
      = $default_config->amf;
      // Store configuration in the registry
      Zend_Registry::set("amf-config", $amf);
      // Initialize AMF Server
      $server
      = new Zend_Amf_Server();
      $server
      ->setProduction($amf->production);
      if(isset($amf->directories)) {
      $dirs
      = $amf->directories->toArray();
      foreach($dirs as $dir) {
      // get the first character of the path.
      // If it does not start with slash then it implies that the path is relative to webroot. Else it will be treated as absolute path
           $length
      = strlen($dir);
           $firstChar
      = $dir;
      if($length >= 1)
            $firstChar
      = $dir[0];
      if($firstChar != "/"){
      // if the directory is ./ path then we add the webroot only.
      if($dir == "./"){
             $server
      ->addDirectory($webroot);
      }else{
             $tempPath
      = $webroot . "/" . $dir;
          $server
      ->addDirectory($tempPath);
      }else{
            $server
      ->addDirectory($dir);
      // Initialize introspector for non-production
      if(!$amf->production) {
      $server
      ->setClass('Zend_Amf_Adobe_Introspector', '', array("config" => $default_config, "server" => $server));
      $server
      ->setClass('Zend_Amf_Adobe_DbInspector', '', array("config" => $default_config, "server" => $server));
      // Handle request
      echo $server
      ->handle();
      Error from gateway.php if I call it directly.
      Warning: require_once(Zend/Loader/Autoloader.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/79/4687979/html/parkerList/gateway.php on line 27
      Fatal error: require_once() [function.require]: Failed opening required 'Zend/Loader/Autoloader.php' (include_path='.:/usr/local/php5/lib/php:http://blackwheels.info//ZendFramework/library') in /home/content/79/4687979/html/parkerList/gateway.php on line 27
      gateway.php is the rat. but I still can't figure out what's wrong. Zend/Loader/Autoloader.php is under the server root "ZendFramework/library" folder. I don't understand why my application can't find it. Thanks again!
        • 1. Re: Flex/Zend channel connect failed error...
          oesiri
          Hello,
          I had the same problem (I think). I've got a kind of solution : not a very good one, but at least it works (for me)...
          So, I put the ZendFramework directory into my application directory (that's why it's not a good solution...), and changed the directories configuration in amf_config.ini and gateway.php.
          (on my server : ......./myFlexApp/ZendFramework)
          new  amf_config.ini file :
          [zend]
          ;set the absolute location path of webroot directory, example:
          ;Windows: C:\apache\www
          ;MAC/UNIX: /user/apache/www
          webroot = .
          ;set the absolute location path of zend installation directory, example:
          ;Windows: C:\apache\PHPFrameworks\ZendFramework\library
          ;MAC/UNIX: /user/apache/PHPFrameworks/ZendFramework/library
          zend_path = ./ZendFramework/library
          [zendamf]
          amf.production = true
          amf.directories[]= ./services
          and the beginning of the gateway.php file :
          ini_set("display_errors", 1);
          $dir = '.';
          $webroot = $_SERVER['DOCUMENT_ROOT'];
          $configfile = "amf_config.ini";
          $zenddir = $webroot. '/ZendFramework/library';
          And for me that's OK.
          I'll try to fix the problem in a cleaner way later, with a ZendFramework directory separated from the application directory. Or maybe someone else can help ?... With a few "echoes" in the gateway.php file I wasn't able to understand what was wrong, I'm not familiar enough with php configuration.
          Hope this can help you !
          • 2. Re: Flex/Zend channel connect failed error...
            jerry98225 Level 1
            Thank you for the help oesiri.
            • 3. Re: Flex/Zend channel connect failed error...
              dmera
              HI , I was reading ur problem and the answer given, and im trying to do the same in my hosting services but i cant seem to get it working have any of you gotten a better solution???
