0 Replies Latest reply on Jul 6, 2010 4:36 PM by rottmanja
    Lauching from a browser Air 2.0
    rottmanja
      I am working on integrating my application with a web application and I only have one issue left.
      When I launch my application, I need to pass in parameters from the web application. Up to this point everything I have tried has failed.
      The issue that I am seeing is that if I use my launching badge to pass parameters to the air application, the air application does start, but it sits at 50% cpu usage and never displays. If I do not pass in parameters the application starts perfectly fine.
      Any help with this is greatly appreciated.
      Here is the code that I am testing with:
      Launching Badge:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="onCreationComplete()" layout="absolute" width="500" height="400">
      <mx:Script>
      <![CDATA[
      import mx.utils.ObjectUtil;
      private static const _applicationID:String = "test.myapp";
      public var airSWF:Object;
      public var airSWFLoader:Loader = new Loader();
      public var loaderContext:LoaderContext = new LoaderContext();
      private function onCreationComplete():void
      loaderContext.applicationDomain = ApplicationDomain.currentDomain;
      airSWFLoader.contentLoaderInfo.addEventListener(Event.INIT, onInit);
      airSWFLoader.load(new URLRequest("http://airdownload.adobe.com/air/browserapi/air.swf"),
      loaderContext);
      private function onInit(e:Event):void
      airSWF = e.target.content;
      airSWF.getApplicationVersion(_applicationID,"", versionDetectCallback);
      private function versionDetectCallback(version:String):void
      if (version == null)
      launchButton.label="not installed";
      else
      launchButton.enabled = true;
      var applauncharg:String = "Launch my application";
      public function clickHandler( event:MouseEvent ):void
      var arguments:Array = String(Application.application.parameters.arguments).split(',');
      dbug.text = ObjectUtil.toString(arguments);
      airSWF.launchApplication(_applicationID,"",arguments);
      </mx:Script>
      <mx:Button label="Launch" id="launchButton" click="handleClick(event)" verticalCenter="0" horizontalCenter="0" width="88" height="31"/>
      <mx:TextArea x="10" y="10" id="dbug" width="302" height="147"/>
      </mx:Application>
      Air application listing for BrowserInvokeEvent:
      private function browserInit():void
      NativeApplication.nativeApplication.addEventListener(BrowserInvokeEvent.BROWSER_INVOKE, OnBrowserInvoke);
      private function OnBrowserInvoke(event:BrowserInvokeEvent):void
      message.text = ObjectUtil.toString(event);
      HTML/Javascript Code:
      <script type="text/javascript" src="swfobject.js"></script>
      <div id="flashcontent">
      </div>
      <p>
      var so = new SWFObject("launcher.swf", "badge", "500", "400", "9.0.115", "#FFFFFF");
      so.addVariable( "arguments", "1,2,3,4,5" );
      so.write("flashcontent");
      </script>
      </p>
