8 Replies Latest reply on Jul 7, 2010 9:13 AM by Sebastien V.
    Error:# 1009 data/services.. create()
    Rex-on Level 1
      It been two days and now I am about to hit the wall... but found this forum. Hopefully, someone can help me. I am having issue with creating/sending information to database (zend framework, php, mySql).
      I am creating a simple forum to submit new user. Following is the simplified version as it is happening in all applications. So, I am able to connect to database and retrive data to datagrind. But I am having issue sending new information to the server. I was also able to create and send new data using "Test Operation" but when try to do the same thing with in the application it gives the error message.
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at myEmployee/button_clickHandler()[/Applications/XAMPP/xamppfiles/htdocs/xampp/Flash Builder Cook Book/src/myEmployee/src/myEmployee.mxml:20]
      at myEmployee/__button_click()[/Applications/XAMPP/xamppfiles/htdocs/xampp/Flash Builder Cook Book/src/myEmployee/src/myEmployee.mxml:54]
         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:employeservice="services.employeservice.*" xmlns:valueObjects="valueObjects.*">
      <fx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.events.FlexEvent;
      protected function dataGrid_creationCompleteHandler(event:FlexEvent):void
      getAllEmployeResult.token = employeService.getAllEmploye();
      protected function button_clickHandler(event:MouseEvent):void
      trace(firstNameTextInput.text);
      trace(lastNameTextInput.text);
      employe.firstName = firstNameTextInput.text.toString();
      employe.lastName = lastNameTextInput.text.toString();
      createEmployeResult.token = employeService.createEmploye(employe);
      //getAllEmployeResult.token = employeService.getAllEmploye();
      </fx:Script>
      <fx:Declarations>
      <s:CallResponder id="getAllEmployeResult"/>
      <employeservice:EmployeService id="employeService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
      <valueObjects:Employe id="employe"/>
      <s:CallResponder id="createEmployeResult"/>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <fx:Binding source="dataGrid.selectedItem as Employe" destination="employe"/>
      <mx:DataGrid x="102" y="124" id="dataGrid" creationComplete="dataGrid_creationCompleteHandler(event)" dataProvider="{getAllEmployeResult.lastResult}">
      <mx:columns>
      <mx:DataGridColumn headerText="id" dataField="id"/>
      <mx:DataGridColumn headerText="firstName" dataField="firstName"/>
      <mx:DataGridColumn headerText="lastName" dataField="lastName"/>
      </mx:columns>
      </mx:DataGrid>
      <mx:Form defaultButton="{button}" x="112" y="318">
      <mx:FormItem label="Id">
      <s:TextInput id="idTextInput" text="{employe.id}"/>
      </mx:FormItem>
      <mx:FormItem label="FirstName">
      <s:TextInput id="firstNameTextInput" text="{employe.firstName}"/>
      </mx:FormItem>
      <mx:FormItem label="LastName">
      <s:TextInput id="lastNameTextInput" text="{employe.lastName}"/>
      </mx:FormItem>
      <s:Button id="button" label="Submit" click="button_clickHandler(event)"/>
      </mx:Form>
      </s:Application>
      I don't understand what i wrong with this. The only thing I had to input was the "empolye" on
      Thanks if advance guys... oo and I am using mac OSX, doesn't know if that matters....
      Rexon
