12 Replies Latest reply on Jul 11, 2010 3:07 PM by marimetfan2007
    Please help Can't install CS5 Illustrator - Adobe is having issues helping
    marimetfan2007
      Can anyone HELP? I tried 8 to 20+ times times. Adobe can't figure it out. They said, they will send me info in a few days. Here is the message I received. I purchased this and need to use it ASAP.
      • Tech info.
      • I am on a silver key MacBookPro
      • Running on Mac OS X version 10.6.4
      • Processor 2GHz Intel Core Duo
      • Memory 2GB  667 MHz DDR2 SDRAM
      Exit Code: 7
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 35 error(s), 31 warning(s)
      WARNING: Payload cannot be installed due to dependent operation failure
      ERROR: 99 Unable to preserve original file at "/Library/Application Support/Adobe/PDFL/9.9/Fonts/AdobeFanHeitiStd-Bold.otf" Error 0
      ERROR: 99 Command ARKDeleteFileCommand failed.
      ERROR: The following payload errors were found during install:
      ERROR:  - Adobe WinSoft Linguistics Plugin CS5: Install failed
      ERROR:  - Adobe CSXS Infrastructure CS5: Install failed
      ERROR:  - SiteCatalyst NetAverages: Install failed
      ERROR:  - Adobe Bridge CS5: Install failed
      ERROR:  - HIL Help Search: Install failed
      ERROR:  - AdobeHelp: Install failed
      ERROR:  - Adobe AIR: Install failed
      ERROR:  - Suite Shared Configuration CS5: Install failed
      ERROR:  - Photoshop Camera Raw: Install failed
      ERROR:  - AdobeColorCommonSetCMYK: Install failed
      ERROR:  - DeviceCentral_DeviceCentral3LP-en_US: Install failed
      ERROR:  - Adobe Media Player: Install failed
      ERROR:  - AdobeColorJA CS5: Install failed
      ERROR:  - Adobe ExtendScript Toolkit CS5: Install failed
      ERROR:  - Adobe BrowserLab CS Live: Install failed
      ERROR:  - CSXS Story Extension: Install failed
      ERROR:  - Adobe XMP Panels CS5: Install failed
      ERROR:  - Adobe Illustrator CS5: Failed due to Language Pack installation failure
      ERROR:  - DeviceCentral: Failed due to Language Pack installation failure
      ERROR:  - AdobeColorEU CS5: Install failed
      ERROR:  - AdobeTypeSupport CS5: Install failed
      ERROR:  - AdobeColorCommonSetRGB: Install failed
      ERROR:  - Adobe CSXS Extensions CS5: Install failed
      ERROR:  - PDF Settings CS5: Install failed
      ERROR:  - Adobe Linguistics CS5: Install failed
      ERROR:  - Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack: Install failed
      ERROR:  - AdobePDFL CS5: Install failed
      ERROR:  - Required Common Fonts Installation: Install failed
      ERROR:  - AdobeColorNA CS5: Install failed
      ERROR:  - Recommended Common Fonts Installation: Install failed
      ERROR:  - Adobe Extension Manager CS5: Install failed
      ERROR:  - Adobe ReviewPanel CS5: Install failed
        • 1. Re: Please help Can't install CS5 Illustrator - Adobe is having issues helping
          Wade_Zimmerman Level 6
          It looks like the failure occurred first while trying to install one of the required japanese fonts
          so you have to go to ~/Library/Application Support/Adobe/PDFL/9.9/Fonts and look to see if you have any fonts at all installed.
          If so does it have a complete list ending at Myriad Pro-Regular.otf or does it stop before you see this font, AdobeFanHeitiStd-Bold.otf which would be at
          AdobeArabic-Regular.otf.
          this is where to look.
          • 2. Re: Please help Can't install CS5 Illustrator - Adobe is having issues helping
            If it stops before you see this font and you are installing from a disk it might be simply a bad disk.
            • 5. Re: Please help Can't install CS5 Illustrator - Adobe is having issues helping
              I would say try this if you have not first uninstall the suites if the is a folder called Adobe Installers in your Applications/Utilities and there is an application called Adobe Illustrator CS 5 Installer or something like that and use that application to uninstall Illustrator
              Create a new account with administrative privileges log in to that account and then try to install AI CS 5
              if that fails I say you have a conflict with a font or corrupt system.
              I would reinstall the system.
              Before doing so wait for other ideas, though I think that might be the solution, I hope I am wrong.
              • 6. Re: Please help Can't install CS5 Illustrator - Adobe is having issues helping
                marimetfan2007 Level 1
                Thank you for your reply. I will wait for a few more and then do as you say. If you think of anything else,...
                • 7. Re: Please help Can't install CS5 Illustrator - Adobe is having issues helping
                  Simply read this and this. In short: You need to start from scratch. Another, older Adobe software is busting things up, possibly due to an update gone wrong or a general known conflict.
                  Mylenium
                  • 8. Re: Please help Can't install CS5 Illustrator - Adobe is having issues helping
                    bhatnaga Adobe Employee
                    Please try renaming the folder: "/Library/Application Support/Adobe/PDFL/" and try to install again. Also, can you please upload full logs here. I believe they will be located at "/Library/Logs/Adobe/Installers/Adobe Illustrator CS5 15.0 ... .log.gz" where ... is the date stamp. This log will help us in nailing down the exact problem.
                    Oh and please have a look at your private messages and respond to it.
                    Anirudh
                    • 10. Re: Please help Can't install CS5 Illustrator - Adobe is having issues helping
                      Visit http://www.adobe.com/go/loganalyzer/ for more information
                      START - Installer Session
                      RIBS version: 3.0.121.0
                      OSX version: 10.6.4
                      ::START TIMER:: [Total Timer]
                      CHECK: Single instance running
                      CHECK : Credentials
                      Load Deployment File
                      Create Required Folders
                      Assuming install mode
                      ::START TIMER:: [Bootstrap]
                      Perform Bootstrapping ...
                      :: END TIMER :: [Bootstrap] took 7443 miliseconds (7.443 seconds) DTR = 0.537418 KBPS (0.000524822 MBPS)
                      Looking up install source path
                      Sync Media DB ...
                      ::START TIMER:: [Sync Media DB]
                      Pre check media db sync
                      End of Pre check media db sync. Exit code: 1
                      Media db sync skipped as session is already installed
                      :: END TIMER :: [Sync Media DB] took 22 miliseconds (0.022 seconds)
                      Ready to initialize session to start with ...
                      ::START TIMER:: [CreatePayloadSession]
                      -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
                      Updated source path: /Volumes/Adobe Illustrator CS5 1/Adobe Illustrator CS5
                      Updating media info for: {007A2A28-D6A8-4D91-9A2B-568FF8052215}
                        Type: 1, Volume Order: 1, Media Name: Adobe Illustrator CS5
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeWinSoftLinguisticsPluginAll/AdobeWinSoftLinguisticsPluginAll.dmg
                      Updating media info for: {02731921-5711-4E7A-A898-D6BCF0F2A1CD}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeCSXSInfrastructure2-mul/AdobeCSXSInfrastructure2-mul.dmg
                      Updating media info for: {03EEF3DA-71F9-4FE5-92AD-D10142E26459}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/SiteCatalystNetAverages1-mul/SiteCatalystNetAverages1-mul.dmg
                      Updating media info for: {042F50EC-2C9E-43D8-B3D7-2BB204A20E44}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeIllustrator15en_GBLanguagePack/AdobeIllustrator15en_GBLanguagePack.dmg
                      Updating media info for: {0D067D13-C3D7-4EA6-B346-740CD91FD547}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeBridge4-mul/AdobeBridge4-mul.dmg
                      Updating media info for: {1BA32816-8C6C-4B81-AFD7-38DCB6AF548F}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-ru_RU/DeviceCentral3LP-ru_RU.dmg
                      Updating media info for: {1C7FF951-A0E5-4CCE-9B14-0DF9C01726C7}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-es_ES/DeviceCentral3LP-es_ES.dmg
                      Updating media info for: {1EC2407F-6A7B-4A3C-9F46-C812EE3D44FD}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/HIL_Help_Search/HIL_Help_Search.dmg
                      Updating media info for: {20D5C83B-E680-4DE8-82C4-863F7EF8F92A}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-zh_CN/DeviceCentral3LP-zh_CN.dmg
                      Updating media info for: {28DA1F46-9442-4FA6-A86C-228CECFE3220}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-ar_AE/DeviceCentral3LP-ar_AE.dmg
                      Updating media info for: {298CF0B0-8B47-46DF-B726-8E4BFAD5432E}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeHelp/InstallAdobeHelp
                      Updating media info for: {2C8C0585-5083-4032-94B8-A9AD04ED0716}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeAIR1.5.3-mul/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
                      Updating media info for: {2D2CE39D-F55A-402C-BC79-50E19A6EBB40}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-ro_RO/DeviceCentral3LP-ro_RO.dmg
                      Updating media info for: {32EA2EF2-43EB-4A58-B9FA-91A423637CB3}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-de_DE/DeviceCentral3LP-de_DE.dmg
                      Updating media info for: {33105D79-0C3C-4F35-BBFB-F6D9DD9CDA44}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-pt_BR/DeviceCentral3LP-pt_BR.dmg
                      Updating media info for: {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeSuiteSharedConfiguration-mul/AdobeSuiteSharedConfiguration-mul.dmg
                      Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeCameraRaw6.0All/AdobeCameraRaw6.0All.dmg
                      Updating media info for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeColorCommonSetCMYK3-mul/AdobeColorCommonSetCMYK3-mul.dmg
                      Updating media info for: {3A7594CE-A6E3-49DC-BBBD-402B60A88A46}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-hu_HU/DeviceCentral3LP-hu_HU.dmg
                      Updating media info for: {3E7A8DA8-0298-42F2-B927-4DB00E2F8FEE}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-en_US/DeviceCentral3LP-en_US.dmg
                      Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeCameraRawProfile6.0All/AdobeCameraRawProfile6.0All.dmg
                      Updating media info for: {3F9DB3B4-2E3C-49C0-A5FB-C2248DB78EC6}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-nl_NL/DeviceCentral3LP-nl_NL.dmg
                      Updating media info for: {41372141-B568-4B5A-80DD-649980B825AC}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-en_GB/DeviceCentral3LP-en_GB.dmg
                      Updating media info for: {43DFDAAC-4596-4224-9B0A-BD69A1FD3675}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-fi_FI/DeviceCentral3LP-fi_FI.dmg
                      Updating media info for: {463D65D7-CD43-4FAC-A6C7-7D24CB5DB93B}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeAMP1.8-mul/Adobe AIR Installer.app/Contents/MacOS/Adobe AIR Installer
                      Updating media info for: {4687A306-D716-4D7A-B0AA-EAB65D17F149}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeAPE3-mul/AdobeAPE3-mul.dmg
                      Updating media info for: {506B00A9-8E71-4F61-9796-67B2F2D9F560}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-fr_FR/DeviceCentral3LP-fr_FR.dmg
                      Updating media info for: {54F4466A-091A-46DA-B697-43D55CEF9DF6}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeColorJA_ExtraSettings3-mul/AdobeColorJA_ExtraSettings3-mul.dmg
                      Updating media info for: {5A60CD44-B38B-47CD-BE38-219C81AE3345}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeExtendScriptToolkit3.5.0-mul/AdobeExtendScriptToolkit3.5.0-mul.dmg
                      Updating media info for: {5E08533A-2C1B-469D-AFD5-953C9D00031F}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/BrowserLabCSLive-mul/BrowserLabCSLive-mul.dmg
                      Updating media info for: {66173EC7-974E-4652-9468-4A93D2481BF0}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeStoryExtension-mul/AdobeStoryExtension-mul.dmg
                      Updating media info for: {6A2E619B-E4AC-433B-A648-D458CE543A96}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeXMPPanelsAll/AdobeXMPPanelsAll.dmg
                      Updating media info for: {6A75E573-6909-4D48-BDFA-D8ED118605A5}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeIllustrator15-mul/AdobeIllustrator15-mul.dmg
                      Updating media info for: {6C31862E-F8D0-4780-B3CD-8B65FBD4954B}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-ko_KR/DeviceCentral3LP-ko_KR.dmg
                      Updating media info for: {6CFA781D-EC16-4077-BCD6-082B2673C719}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-zh_TW/DeviceCentral3LP-zh_TW.dmg
                      Updating media info for: {6E505C8F-2896-11DF-9B64-0013724DD917}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeDeviceCentral3-all/AdobeDeviceCentral3-all.dmg
                      Updating media info for: {6F29BE46-E5F3-4146-8A84-20301E5C985A}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeColorEU_ExtraSettings3-mul/AdobeColorEU_ExtraSettings3-mul.dmg
                      Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeTypeSupport10-mul/AdobeTypeSupport10-mul.dmg
                      Updating media info for: {73112F5A-821A-4D15-9278-40491DC29CB9}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-uk_UA/DeviceCentral3LP-uk_UA.dmg
                      Updating media info for: {73697A1F-E89D-4DEA-92C4-3E543F7325E5}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-he_IL/DeviceCentral3LP-he_IL.dmg
                      Updating media info for: {7387FCB7-C6EE-404F-8617-36E8241240D4}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-el_GR/DeviceCentral3LP-el_GR.dmg
                      Updating media info for: {78A53622-CDBA-49D1-A3D0-D563FB398D0C}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeColorCommonSetRGB3-mul/AdobeColorCommonSetRGB3-mul.dmg
                      Updating media info for: {796659A8-114A-4E16-9994-14DF6A1B1683}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeUtilities3-mul/AdobeUtilities3-mul.dmg
                      Updating media info for: {82F05FE0-3CA1-4FE7-8413-E56F1627068A}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-it_IT/DeviceCentral3LP-it_IT.dmg
                      Updating media info for: {8B4C951B-F853-4B05-B892-9D5B3CD8AC98}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobePDFSettings10-ja_JP/AdobePDFSettings10-ja_JP.dmg
                      Updating media info for: {8B99677E-58A7-407F-94E8-E21BA2CBB07B}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-ja_JP/DeviceCentral3LP-ja_JP.dmg
                      Updating media info for: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeCSXSExtensions2-mul/AdobeCSXSExtensions2-mul.dmg
                      Updating media info for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeOutputModuleAll/AdobeOutputModuleAll.dmg
                      Updating media info for: {9311BC8A-EE72-4C20-B511-96E1033A872E}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-cs_CZ/DeviceCentral3LP-cs_CZ.dmg
                      Updating media info for: {969EE838-1FA5-46CF-867A-7540E7805AE0}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-pl_PL/DeviceCentral3LP-pl_PL.dmg
                      Updating media info for: {A2502D10-2D75-4620-8A8B-73F39D5C1243}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobePDFSettings10-mul/AdobePDFSettings10-mul.dmg
                      Updating media info for: {A44863BF-8DB8-4D22-88DB-5A02BE319840}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeLinguisticsAll/AdobeLinguisticsAll.dmg
                      Updating media info for: {ACF98836-E6E3-4FDB-BC64-6DCABC0D4785}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-fr_XM/DeviceCentral3LP-fr_XM.dmg
                      Updating media info for: {B4975576-60AD-4181-AED4-253FC150B404}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeIllustrator15en_USLanguagePack/AdobeIllustrator15en_USLanguagePack.dmg
                      Updating media info for: {B60B8713-F828-44F9-BEEE-7596F814E540}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeColorEU_Recommended3-mul/AdobeColorEU_Recommended3-mul.dmg
                      Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobePDFL9.9-mul/AdobePDFL9.9-mul.dmg
                      Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeCMaps3-mul/AdobeCMaps3-mul.dmg
                      Updating media info for: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeColorNA_ExtraSettings3-mul/AdobeColorNA_ExtraSettings3-mul.dmg
                      Updating media info for: {C34F10DC-7956-469E-924E-C7123C7EB514}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-es_MX/DeviceCentral3LP-es_MX.dmg
                      Updating media info for: {C7145B43-7503-473D-84B2-B2A2EBDA448E}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-sv_SE/DeviceCentral3LP-sv_SE.dmg
                      Updating media info for: {CBDD7465-CE11-4A58-9497-C370B65923F1}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeFontsRequired-mul/AdobeFontsRequired-mul.dmg
                      Updating media info for: {CF1CE210-EDCB-4BEE-B8BA-B5557AC475B5}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-da_DK/DeviceCentral3LP-da_DK.dmg
                      Updating media info for: {D0D141DF-430A-42D3-A86C-822F4BC60A81}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-tr_TR/DeviceCentral3LP-tr_TR.dmg
                      Updating media info for: {D26EEF95-420A-4726-B85D-AFBE752EF526}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeColorNA_Recommended3-mul/AdobeColorNA_Recommended3-mul.dmg
                      Updating media info for: {D4FC35AE-F9A5-40D0-B9BC-99D7EDF91B5A}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-nb_NO/DeviceCentral3LP-nb_NO.dmg
                      Updating media info for: {DAA6CF96-F19E-4D2B-BF53-DD4A1C211E4B}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-fr_CA/DeviceCentral3LP-fr_CA.dmg
                      Updating media info for: {E39A5ABD-516B-46F9-A042-694BBA6A4E08}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeFontsRecommended-mul/AdobeFontsRecommended-mul.dmg
                      Updating media info for: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeExtensionManager5.0All/AdobeExtensionManager5.0All.dmg
                      Updating media info for: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeColorJA_Recommended3-mul/AdobeColorJA_Recommended3-mul.dmg
                      Updating media info for: {FFB4B6E3-C813-41E7-86AC-BB03F0AAFE57}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/DeviceCentral3LP-en_XM/DeviceCentral3LP-en_XM.dmg
                      Updating media info for: {FFEDE6AE-3052-11DF-89B7-E7102C404F28}
                        Path: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeReviewPanel2-mul/AdobeReviewPanel2-mul.dmg
                      --------------------  END  - Updating Media Sources -  END  --------------------
                      Supported RIBS version range: [0.0.66.0,3.0.121.0]
                      ----------------- CreatePayloadSession: machine is x86 ---------------
                      ______ Verify Dependency Subscribers ______
                      Setting property "INSTALLDIR" to: /Applications
                      Setting property "installLanguage" to: en_US
                      Attempting to find the selected language in the set of available payload languages
                      Setting property "installSourcePath" to: /Volumes/Adobe Illustrator CS5 1/Adobe Illustrator CS5
                      Overwrite property "userASUPath" to: /Users/seandsun/Applications/Adobe/OOBE/PDApp
                      Found payload actions:
                      Deciding what installer mode to use...
                      BEGIN Setting requested payload actions
                      Value returned on lookup of payload: {4687A306-D716-4D7A-B0AA-EAB65D17F149} Adobe Player for Embedding is: true
                      Action string for  {4687A306-D716-4D7A-B0AA-EAB65D17F149} Adobe Player for Embedding  is none
                      Value returned on lookup of payload: {796659A8-114A-4E16-9994-14DF6A1B1683} Adobe Utilities CS5 is: true
                      Action string for  {796659A8-114A-4E16-9994-14DF6A1B1683} Adobe Utilities CS5  is none
                      Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: true
                      Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none
                      Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: true
                      Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none
                      Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: true
                      Action string for  {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule  is none
                      Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: false
                      Action string for  {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5  is none
                      Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: false
                      Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none
                      Value returned on lookup of payload: {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5 is: false
                      Action string for  {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5  is none
                      Value returned on lookup of payload: {298CF0B0-8B47-46DF-B726-8E4BFAD5432E} AdobeHelp is: false
                      Action string for  {298CF0B0-8B47-46DF-B726-8E4BFAD5432E} AdobeHelp  is none
                      Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: false
                      Action string for  {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5  is none
                      Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: false
                      Action string for  {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5  is none
                      Value returned on lookup of payload: {6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5 is: false
                      Action string for  {6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5  is none
                      Value returned on lookup of payload: {5A60CD44-B38B-47CD-BE38-219C81AE3345} Adobe ExtendScript Toolkit CS5 is: false
                      Action string for  {5A60CD44-B38B-47CD-BE38-219C81AE3345} Adobe ExtendScript Toolkit CS5  is none
                      Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: false
                      Action string for  {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw  is none
                      Value returned on lookup of payload: {007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5 is: false
                      Action string for  {007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5  is none
                      Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: false
                      Action string for  {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK  is none
                      Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: false
                      Action string for  {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB  is none
                      Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false
                      Action string for  {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5  is none
                      Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: false
                      Action string for  {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5  is none
                      Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: false
                      Action string for  {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5  is none
                      Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false
                      Action string for  {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5  is none
                      Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: false
                      Action string for  {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5  is none
                      Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false
                      Action string for  {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5  is none
                      Value returned on lookup of payload: {2C8C0585-5083-4032-94B8-A9AD04ED0716} Adobe AIR is: false
                      Action string for  {2C8C0585-5083-4032-94B8-A9AD04ED0716} Adobe AIR  is none
                      Value returned on lookup of payload: {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is: false
                      Action string for  {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live  is none
                      Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: false
                      Action string for  {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5  is none
                      Value returned on lookup of payload: {A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5 is: false
                      Action string for  {A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5  is none
                      Value returned on lookup of payload: {463D65D7-CD43-4FAC-A6C7-7D24CB5DB93B} Adobe Media Player is: false
                      Action string for  {463D65D7-CD43-4FAC-A6C7-7D24CB5DB93B} Adobe Media Player  is none
                      Value returned on lookup of payload: {FFEDE6AE-3052-11DF-89B7-E7102C404F28} Adobe ReviewPanel CS5 is: false
                      Action string for  {FFEDE6AE-3052-11DF-89B7-E7102C404F28} Adobe ReviewPanel CS5  is none
                      Value returned on lookup of payload: {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is: false
                      Action string for  {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension  is none
                      Value returned on lookup of payload: {1EC2407F-6A7B-4A3C-9F46-C812EE3D44FD} HIL Help Search is: false
                      Action string for  {1EC2407F-6A7B-4A3C-9F46-C812EE3D44FD} HIL Help Search  is none
                      Value returned on lookup of payload: {8B4C951B-F853-4B05-B892-9D5B3CD8AC98} PDF Settings CS5 is: false
                      Action string for  {8B4C951B-F853-4B05-B892-9D5B3CD8AC98} PDF Settings CS5  is none
                      Value returned on lookup of payload: {A2502D10-2D75-4620-8A8B-73F39D5C1243} PDF Settings CS5 is: false
                      Action string for  {A2502D10-2D75-4620-8A8B-73F39D5C1243} PDF Settings CS5  is none
                      Value returned on lookup of payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is: false
                      Action string for  {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation  is none
                      Value returned on lookup of payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is: false
                      Action string for  {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation  is none
                      Value returned on lookup of payload: {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is: false
                      Action string for  {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages  is none
                      Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: false
                      Action string for  {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral  is none
                      Value returned on lookup of payload: {28DA1F46-9442-4FA6-A86C-228CECFE3220} DeviceCentral_DeviceCentral3LP-ar_AE is: false
                      Action string for  {28DA1F46-9442-4FA6-A86C-228CECFE3220} DeviceCentral_DeviceCentral3LP-ar_AE  is none
                      Payload {28DA1F46-9442-4FA6-A86C-228CECFE3220} DeviceCentral_DeviceCentral3LP-ar_AE is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {20D5C83B-E680-4DE8-82C4-863F7EF8F92A} DeviceCentral_DeviceCentral3LP-zh_CN is: false
                      Action string for  {20D5C83B-E680-4DE8-82C4-863F7EF8F92A} DeviceCentral_DeviceCentral3LP-zh_CN  is none
                      Payload {20D5C83B-E680-4DE8-82C4-863F7EF8F92A} DeviceCentral_DeviceCentral3LP-zh_CN is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {6C31862E-F8D0-4780-B3CD-8B65FBD4954B} DeviceCentral_DeviceCentral3LP-ko_KR is: false
                      Action string for  {6C31862E-F8D0-4780-B3CD-8B65FBD4954B} DeviceCentral_DeviceCentral3LP-ko_KR  is none
                      Payload {6C31862E-F8D0-4780-B3CD-8B65FBD4954B} DeviceCentral_DeviceCentral3LP-ko_KR is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {1C7FF951-A0E5-4CCE-9B14-0DF9C01726C7} DeviceCentral_DeviceCentral3LP-es_ES is: false
                      Action string for  {1C7FF951-A0E5-4CCE-9B14-0DF9C01726C7} DeviceCentral_DeviceCentral3LP-es_ES  is none
                      Payload {1C7FF951-A0E5-4CCE-9B14-0DF9C01726C7} DeviceCentral_DeviceCentral3LP-es_ES is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {C34F10DC-7956-469E-924E-C7123C7EB514} DeviceCentral_DeviceCentral3LP-es_MX is: false
                      Action string for  {C34F10DC-7956-469E-924E-C7123C7EB514} DeviceCentral_DeviceCentral3LP-es_MX  is none
                      Payload {C34F10DC-7956-469E-924E-C7123C7EB514} DeviceCentral_DeviceCentral3LP-es_MX is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {C7145B43-7503-473D-84B2-B2A2EBDA448E} DeviceCentral_DeviceCentral3LP-sv_SE is: false
                      Action string for  {C7145B43-7503-473D-84B2-B2A2EBDA448E} DeviceCentral_DeviceCentral3LP-sv_SE  is none
                      Payload {C7145B43-7503-473D-84B2-B2A2EBDA448E} DeviceCentral_DeviceCentral3LP-sv_SE is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {CF1CE210-EDCB-4BEE-B8BA-B5557AC475B5} DeviceCentral_DeviceCentral3LP-da_DK is: false
                      Action string for  {CF1CE210-EDCB-4BEE-B8BA-B5557AC475B5} DeviceCentral_DeviceCentral3LP-da_DK  is none
                      Payload {CF1CE210-EDCB-4BEE-B8BA-B5557AC475B5} DeviceCentral_DeviceCentral3LP-da_DK is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {D0D141DF-430A-42D3-A86C-822F4BC60A81} DeviceCentral_DeviceCentral3LP-tr_TR is: false
                      Action string for  {D0D141DF-430A-42D3-A86C-822F4BC60A81} DeviceCentral_DeviceCentral3LP-tr_TR  is none
                      Payload {D0D141DF-430A-42D3-A86C-822F4BC60A81} DeviceCentral_DeviceCentral3LP-tr_TR is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {1BA32816-8C6C-4B81-AFD7-38DCB6AF548F} DeviceCentral_DeviceCentral3LP-ru_RU is: false
                      Action string for  {1BA32816-8C6C-4B81-AFD7-38DCB6AF548F} DeviceCentral_DeviceCentral3LP-ru_RU  is none
                      Payload {1BA32816-8C6C-4B81-AFD7-38DCB6AF548F} DeviceCentral_DeviceCentral3LP-ru_RU is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {D4FC35AE-F9A5-40D0-B9BC-99D7EDF91B5A} DeviceCentral_DeviceCentral3LP-nb_NO is: false
                      Action string for  {D4FC35AE-F9A5-40D0-B9BC-99D7EDF91B5A} DeviceCentral_DeviceCentral3LP-nb_NO  is none
                      Payload {D4FC35AE-F9A5-40D0-B9BC-99D7EDF91B5A} DeviceCentral_DeviceCentral3LP-nb_NO is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {DAA6CF96-F19E-4D2B-BF53-DD4A1C211E4B} DeviceCentral_DeviceCentral3LP-fr_CA is: false
                      Action string for  {DAA6CF96-F19E-4D2B-BF53-DD4A1C211E4B} DeviceCentral_DeviceCentral3LP-fr_CA  is none
                      Payload {DAA6CF96-F19E-4D2B-BF53-DD4A1C211E4B} DeviceCentral_DeviceCentral3LP-fr_CA is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {43DFDAAC-4596-4224-9B0A-BD69A1FD3675} DeviceCentral_DeviceCentral3LP-fi_FI is: false
                      Action string for  {43DFDAAC-4596-4224-9B0A-BD69A1FD3675} DeviceCentral_DeviceCentral3LP-fi_FI  is none
                      Payload {43DFDAAC-4596-4224-9B0A-BD69A1FD3675} DeviceCentral_DeviceCentral3LP-fi_FI is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {FFB4B6E3-C813-41E7-86AC-BB03F0AAFE57} DeviceCentral_DeviceCentral3LP-en_XM is: false
                      Action string for  {FFB4B6E3-C813-41E7-86AC-BB03F0AAFE57} DeviceCentral_DeviceCentral3LP-en_XM  is none
                      Payload {FFB4B6E3-C813-41E7-86AC-BB03F0AAFE57} DeviceCentral_DeviceCentral3LP-en_XM is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {506B00A9-8E71-4F61-9796-67B2F2D9F560} DeviceCentral_DeviceCentral3LP-fr_FR is: false
                      Action string for  {506B00A9-8E71-4F61-9796-67B2F2D9F560} DeviceCentral_DeviceCentral3LP-fr_FR  is none
                      Payload {506B00A9-8E71-4F61-9796-67B2F2D9F560} DeviceCentral_DeviceCentral3LP-fr_FR is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {41372141-B568-4B5A-80DD-649980B825AC} DeviceCentral_DeviceCentral3LP-en_GB is: false
                      Action string for  {41372141-B568-4B5A-80DD-649980B825AC} DeviceCentral_DeviceCentral3LP-en_GB  is none
                      Payload {41372141-B568-4B5A-80DD-649980B825AC} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {3F9DB3B4-2E3C-49C0-A5FB-C2248DB78EC6} DeviceCentral_DeviceCentral3LP-nl_NL is: false
                      Action string for  {3F9DB3B4-2E3C-49C0-A5FB-C2248DB78EC6} DeviceCentral_DeviceCentral3LP-nl_NL  is none
                      Payload {3F9DB3B4-2E3C-49C0-A5FB-C2248DB78EC6} DeviceCentral_DeviceCentral3LP-nl_NL is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {73112F5A-821A-4D15-9278-40491DC29CB9} DeviceCentral_DeviceCentral3LP-uk_UA is: false
                      Action string for  {73112F5A-821A-4D15-9278-40491DC29CB9} DeviceCentral_DeviceCentral3LP-uk_UA  is none
                      Payload {73112F5A-821A-4D15-9278-40491DC29CB9} DeviceCentral_DeviceCentral3LP-uk_UA is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {73697A1F-E89D-4DEA-92C4-3E543F7325E5} DeviceCentral_DeviceCentral3LP-he_IL is: false
                      Action string for  {73697A1F-E89D-4DEA-92C4-3E543F7325E5} DeviceCentral_DeviceCentral3LP-he_IL  is none
                      Payload {73697A1F-E89D-4DEA-92C4-3E543F7325E5} DeviceCentral_DeviceCentral3LP-he_IL is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {7387FCB7-C6EE-404F-8617-36E8241240D4} DeviceCentral_DeviceCentral3LP-el_GR is: false
                      Action string for  {7387FCB7-C6EE-404F-8617-36E8241240D4} DeviceCentral_DeviceCentral3LP-el_GR  is none
                      Payload {7387FCB7-C6EE-404F-8617-36E8241240D4} DeviceCentral_DeviceCentral3LP-el_GR is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {3E7A8DA8-0298-42F2-B927-4DB00E2F8FEE} DeviceCentral_DeviceCentral3LP-en_US is: false
                      Action string for  {3E7A8DA8-0298-42F2-B927-4DB00E2F8FEE} DeviceCentral_DeviceCentral3LP-en_US  is none
                      Payload {3E7A8DA8-0298-42F2-B927-4DB00E2F8FEE} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {3A7594CE-A6E3-49DC-BBBD-402B60A88A46} DeviceCentral_DeviceCentral3LP-hu_HU is: false
                      Action string for  {3A7594CE-A6E3-49DC-BBBD-402B60A88A46} DeviceCentral_DeviceCentral3LP-hu_HU  is none
                      Payload {3A7594CE-A6E3-49DC-BBBD-402B60A88A46} DeviceCentral_DeviceCentral3LP-hu_HU is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {82F05FE0-3CA1-4FE7-8413-E56F1627068A} DeviceCentral_DeviceCentral3LP-it_IT is: false
                      Action string for  {82F05FE0-3CA1-4FE7-8413-E56F1627068A} DeviceCentral_DeviceCentral3LP-it_IT  is none
                      Payload {82F05FE0-3CA1-4FE7-8413-E56F1627068A} DeviceCentral_DeviceCentral3LP-it_IT is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {8B99677E-58A7-407F-94E8-E21BA2CBB07B} DeviceCentral_DeviceCentral3LP-ja_JP is: false
                      Action string for  {8B99677E-58A7-407F-94E8-E21BA2CBB07B} DeviceCentral_DeviceCentral3LP-ja_JP  is none
                      Payload {8B99677E-58A7-407F-94E8-E21BA2CBB07B} DeviceCentral_DeviceCentral3LP-ja_JP is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {33105D79-0C3C-4F35-BBFB-F6D9DD9CDA44} DeviceCentral_DeviceCentral3LP-pt_BR is: false
                      Action string for  {33105D79-0C3C-4F35-BBFB-F6D9DD9CDA44} DeviceCentral_DeviceCentral3LP-pt_BR  is none
                      Payload {33105D79-0C3C-4F35-BBFB-F6D9DD9CDA44} DeviceCentral_DeviceCentral3LP-pt_BR is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {32EA2EF2-43EB-4A58-B9FA-91A423637CB3} DeviceCentral_DeviceCentral3LP-de_DE is: false
                      Action string for  {32EA2EF2-43EB-4A58-B9FA-91A423637CB3} DeviceCentral_DeviceCentral3LP-de_DE  is none
                      Payload {32EA2EF2-43EB-4A58-B9FA-91A423637CB3} DeviceCentral_DeviceCentral3LP-de_DE is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {9311BC8A-EE72-4C20-B511-96E1033A872E} DeviceCentral_DeviceCentral3LP-cs_CZ is: false
                      Action string for  {9311BC8A-EE72-4C20-B511-96E1033A872E} DeviceCentral_DeviceCentral3LP-cs_CZ  is none
                      Payload {9311BC8A-EE72-4C20-B511-96E1033A872E} DeviceCentral_DeviceCentral3LP-cs_CZ is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {969EE838-1FA5-46CF-867A-7540E7805AE0} DeviceCentral_DeviceCentral3LP-pl_PL is: false
                      Action string for  {969EE838-1FA5-46CF-867A-7540E7805AE0} DeviceCentral_DeviceCentral3LP-pl_PL  is none
                      Payload {969EE838-1FA5-46CF-867A-7540E7805AE0} DeviceCentral_DeviceCentral3LP-pl_PL is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {6CFA781D-EC16-4077-BCD6-082B2673C719} DeviceCentral_DeviceCentral3LP-zh_TW is: false
                      Action string for  {6CFA781D-EC16-4077-BCD6-082B2673C719} DeviceCentral_DeviceCentral3LP-zh_TW  is none
                      Payload {6CFA781D-EC16-4077-BCD6-082B2673C719} DeviceCentral_DeviceCentral3LP-zh_TW is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {2D2CE39D-F55A-402C-BC79-50E19A6EBB40} DeviceCentral_DeviceCentral3LP-ro_RO is: false
                      Action string for  {2D2CE39D-F55A-402C-BC79-50E19A6EBB40} DeviceCentral_DeviceCentral3LP-ro_RO  is none
                      Payload {2D2CE39D-F55A-402C-BC79-50E19A6EBB40} DeviceCentral_DeviceCentral3LP-ro_RO is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {ACF98836-E6E3-4FDB-BC64-6DCABC0D4785} DeviceCentral_DeviceCentral3LP-fr_XM is: false
                      Action string for  {ACF98836-E6E3-4FDB-BC64-6DCABC0D4785} DeviceCentral_DeviceCentral3LP-fr_XM  is none
                      Payload {ACF98836-E6E3-4FDB-BC64-6DCABC0D4785} DeviceCentral_DeviceCentral3LP-fr_XM is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: false
                      Action string for  {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5  is none
                      Value returned on lookup of payload: {6A75E573-6909-4D48-BDFA-D8ED118605A5} Adobe Illustrator CS5 is: false
                      Action string for  {6A75E573-6909-4D48-BDFA-D8ED118605A5} Adobe Illustrator CS5  is install
                      Value returned on lookup of payload: {042F50EC-2C9E-43D8-B3D7-2BB204A20E44} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is: false
                      Action string for  {042F50EC-2C9E-43D8-B3D7-2BB204A20E44} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack  is none
                      Payload {042F50EC-2C9E-43D8-B3D7-2BB204A20E44} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is extension payload. Aligning its action according to parent.
                      Value returned on lookup of payload: {B4975576-60AD-4181-AED4-253FC150B404} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is: false
                      Action string for  {B4975576-60AD-4181-AED4-253FC150B404} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack  is none
                      Payload {B4975576-60AD-4181-AED4-253FC150B404} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is extension payload. Aligning its action according to parent.
                      END Setting requested payload actions
                      Collected advanced path check information for INSTALLDIR
                      INSTALLDIR is a well-formed path
                      INSTALLDIR is not the root path
                      INSTALLDIR is on a local volume
                      INSTALLDIR is on a writable volume
                      INSTALLDIR is not on a case sensitive volume
                      INSTALLDIR passed path basic path validation: /Applications
                      ::START TIMER:: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}]
                      In InstallPreSystemCheckProc
                      Custom action return code: 0
                      :: END TIMER :: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}] took 2 miliseconds (0.002 seconds)
                      ::START TIMER:: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}]
                      :: END TIMER :: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}] took 2 miliseconds (0.002 seconds)
                      [       0] Wed Jul  7 01:44:30 2010  INFO
                      ::START TIMER:: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
                      Font Installer: Fonts STI Custom Hook 1.6 Release
                      :: END TIMER :: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 5 miliseconds (0.005 seconds)
                      ::START TIMER:: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
                      :: END TIMER :: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 6 miliseconds (0.006 seconds)
                      [       0] Wed Jul  7 01:44:32 2010  INFO
                      Payloads passed preflight validation.
                      Call PreSession Custom Hook
                      Calling the custom action code for pre-repair for payload {4687A306-D716-4D7A-B0AA-EAB65D17F149}
                      ::START TIMER:: [Payload Operation :{4687A306-D716-4D7A-B0AA-EAB65D17F149}]
                      [       1] Wed Jul  7 01:44:32 2010  INFO
                      Installer Operation: PayloadUninstaller
                      Session {6A75E573-6909-4D48-BDFA-D8ED118605A5} modify request for AdobeCode: {4687A306-D716-4D7A-B0AA-EAB65D17F149}
                      Effective AdobeCode for: {4687A306-D716-4D7A-B0AA-EAB65D17F149} is {4687A306-D716-4D7A-B0AA-EAB65D17F149}
                      Session includes local copy of payload for repair source
                      Repair payload source package: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeAPE3-mul/AdobeAPE3-mul.dmg
                      [       1] Wed Jul  7 01:44:34 2010  INFO
                      Beginning installation for payload at /private/tmp/.tempdirsgBhhSiP/Install.db
                      [       1] Wed Jul  7 01:44:41 2010  INFO
                      Completing installation for payload at /private/tmp/.tempdirsgBhhSiP/Install.db
                      UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{4687A306-D716-4D7A-B0AA-EAB65D17F149}.db
                      Physical payload repair result:0
                      [       0] Wed Jul  7 01:44:42 2010  INFO
                      *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
                      :: END TIMER :: [Payload Operation :{4687A306-D716-4D7A-B0AA-EAB65D17F149}] took 10019 miliseconds (10.019 seconds) DTR = 1.99621 KBPS (0.00194942 MBPS)
                      Updating driver data - Action: Add driver entry
                      Updating driver data successful. Driver entry was added. ARP estimated size 0KB
                      User specified overrideFile:
                      Calling the custom action code for post-repair for payload {4687A306-D716-4D7A-B0AA-EAB65D17F149} Adobe Player for Embedding
                      Calling the custom action code for pre-repair for payload {796659A8-114A-4E16-9994-14DF6A1B1683}
                      ::START TIMER:: [Payload Operation :{796659A8-114A-4E16-9994-14DF6A1B1683}]
                      [       2] Wed Jul  7 01:44:42 2010  INFO
                      Session {6A75E573-6909-4D48-BDFA-D8ED118605A5} modify request for AdobeCode: {796659A8-114A-4E16-9994-14DF6A1B1683}
                      Effective AdobeCode for: {796659A8-114A-4E16-9994-14DF6A1B1683} is {796659A8-114A-4E16-9994-14DF6A1B1683}
                      Repair payload source package: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeUtilities3-mul/AdobeUtilities3-mul.dmg
                      [       2] Wed Jul  7 01:44:43 2010  INFO
                      Beginning installation for payload at /private/tmp/.tempdirSCpj0sNe/Install.db
                      Completing installation for payload at /private/tmp/.tempdirSCpj0sNe/Install.db
                      UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{796659A8-114A-4E16-9994-14DF6A1B1683}.db
                      [       2] Wed Jul  7 01:44:44 2010  INFO
                      [       0] Wed Jul  7 01:44:44 2010  INFO
                      :: END TIMER :: [Payload Operation :{796659A8-114A-4E16-9994-14DF6A1B1683}] took 2008 miliseconds (2.008 seconds) DTR = 1.99203 KBPS (0.00194534 MBPS)
                      Calling the custom action code for post-repair for payload {796659A8-114A-4E16-9994-14DF6A1B1683} Adobe Utilities CS5
                      Calling the custom action code for pre-repair for payload {3F023875-4A52-4605-9DB6-A88D4A813E8D}
                      ::START TIMER:: [Payload Operation :{3F023875-4A52-4605-9DB6-A88D4A813E8D}]
                      Session {6A75E573-6909-4D48-BDFA-D8ED118605A5} modify request for AdobeCode: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
                      Effective AdobeCode for: {3F023875-4A52-4605-9DB6-A88D4A813E8D} is {3F023875-4A52-4605-9DB6-A88D4A813E8D}
                      Repair payload source package: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeCameraRawProfile6.0All/AdobeCameraRawProfile6.0All.dmg
                      [       2] Wed Jul  7 01:44:46 2010  INFO
                      Beginning installation for payload at /private/tmp/.tempdirOFOaZAvP/Install.db
                      [       2] Wed Jul  7 01:45:08 2010  INFO
                      Completing installation for payload at /private/tmp/.tempdirOFOaZAvP/Install.db
                      UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{3F023875-4A52-4605-9DB6-A88D4A813E8D}.db
                      [       2] Wed Jul  7 01:45:09 2010  INFO
                      [       0] Wed Jul  7 01:45:09 2010  INFO
                      :: END TIMER :: [Payload Operation :{3F023875-4A52-4605-9DB6-A88D4A813E8D}] took 25027 miliseconds (25.027 seconds) DTR = 0.479482 KBPS (0.000468244 MBPS)
                      Calling the custom action code for post-repair for payload {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer
                      Calling the custom action code for pre-repair for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                      ::START TIMER:: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}]
                      Session {6A75E573-6909-4D48-BDFA-D8ED118605A5} modify request for AdobeCode: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                      Effective AdobeCode for: {BD0D6363-E961-410F-8BF4-ECD8795F3923} is {BD0D6363-E961-410F-8BF4-ECD8795F3923}
                      Repair payload source package: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeCMaps3-mul/AdobeCMaps3-mul.dmg
                      [       2] Wed Jul  7 01:45:11 2010  INFO
                      Beginning installation for payload at /private/tmp/.tempdirBTAcAkyW/Install.db
                      [       2] Wed Jul  7 01:45:16 2010  INFO
                      Completing installation for payload at /private/tmp/.tempdirBTAcAkyW/Install.db
                      UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{BD0D6363-E961-410F-8BF4-ECD8795F3923}.db
                      [       0] Wed Jul  7 01:45:16 2010  INFO
                      :: END TIMER :: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}] took 7041 miliseconds (7.041 seconds) DTR = 1.7043 KBPS (0.00166436 MBPS)
                      Calling the custom action code for post-repair for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5
                      Calling the custom action code for pre-repair for payload {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
                      ::START TIMER:: [Payload Operation :{925ED7E4-E1B6-4544-8141-1C98A18D2E2E}]
                      [       2] Wed Jul  7 01:45:17 2010  INFO
                      Session {6A75E573-6909-4D48-BDFA-D8ED118605A5} modify request for AdobeCode: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
                      Effective AdobeCode for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} is {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
                      Repair payload source package: /Volumes/Adobe Illustrator CS5/Adobe Illustrator CS5/payloads/AdobeOutputModuleAll/AdobeOutputModuleAll.dmg
                      [       2] Wed Jul  7 01:45:18 2010  INFO
                      Beginning installation for payload at /private/tmp/.tempdirxgQQuzpD/Install.db
                      [       2] Wed Jul  7 01:45:20 2010  INFO
                      Evaluating condition# 1
                      Condition failed
                      Condition failed
                      Completing installation for payload at /private/tmp/.tempdirxgQQuzpD/Install.db
                      UninstallDBPath=/Library/Application Support/Adobe/Uninstall/{925ED7E4-E1B6-4544-8141-1C98A18D2E2E}.db
                      [       0] Wed Jul  7 01:45:21 2010  INFO
                      :: END TIMER :: [Payload Operation :{925ED7E4-E1B6-4544-8141-1C98A18D2E2E}] took 4013 miliseconds (4.013 seconds) DTR = 0.996761 KBPS (0.000973399 MBPS)
                      Calling the custom action code for post-repair for payload {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule
                      Calling the custom action code for pre-install for payload {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
                      ::START TIMER:: [Payload Operation :{BAE5212B-6651-4AD8-B26A-1B284D2665C6}]
                      [       2] Wed Jul  7 01:45:21 2010  INFO
                      Installer Operation: PayloadInstaller
                      Request to install payload
                      [       2] Wed Jul  7 01:45:22 2010  INFO
                      Beginning installation for payload at /private/tmp/.tempdirQ69CFMzD/Install.db
                      [       2] Wed Jul  7 01:45:23 2010 ERROR
                      [       2] Wed Jul  7 01:45:23 2010  INFO
                      Completing installation for payload at /private/tmp/.tempdirQ69CFMzD/Install.db
                      [       0] Wed Jul  7 01:45:24 2010  INFO
                      *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
                      :: END TIMER :: [Payload Operation :{BAE5212B-6651-4AD8-B26A-1B284D2665C6}] took 3014 miliseconds (3.014 seconds)
                      Calling the ROLLBACK custom action code for pre-install for payload {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5
                      [       0] Wed Jul  7 01:45:24 2010  WARN
                      Skipping payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 as payload is not cached
                      Skipping payload {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5 as payload is not cached
                      Skipping payload {298CF0B0-8B47-46DF-B726-8E4BFAD5432E} AdobeHelp as payload is not cached
                      Skipping payload {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 as payload is not cached
                      Skipping payload {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 as payload is not cached
                      Skipping payload {6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5 as payload is not cached
                      Skipping payload {5A60CD44-B38B-47CD-BE38-219C81AE3345} Adobe ExtendScript Toolkit CS5 as payload is not cached
                      Skipping payload {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw as payload is not cached
                      Skipping payload {007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5 as payload is not cached
                      Skipping payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK as payload is not cached
                      Skipping payload {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB as payload is not cached
                      Skipping payload {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 as payload is not cached
                      Skipping payload {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 as payload is not cached
                      Skipping payload {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 as payload is not cached
                      Skipping payload {2C8C0585-5083-4032-94B8-A9AD04ED0716} Adobe AIR as payload is not cached
                      Skipping payload {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live as payload is not cached
                      Skipping payload {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 as payload is not cached
                      Skipping payload {A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5 as payload is not cached
                      Skipping payload {463D65D7-CD43-4FAC-A6C7-7D24CB5DB93B} Adobe Media Player as payload is not cached
                      Skipping payload {FFEDE6AE-3052-11DF-89B7-E7102C404F28} Adobe ReviewPanel CS5 as payload is not cached
                      Skipping payload {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension as payload is not cached
                      Skipping payload {1EC2407F-6A7B-4A3C-9F46-C812EE3D44FD} HIL Help Search as payload is not cached
                      Skipping payload {A2502D10-2D75-4620-8A8B-73F39D5C1243} PDF Settings CS5 as payload is not cached
                      Skipping payload {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation as payload is not cached
                      Skipping payload {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation as payload is not cached
                      Skipping payload {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages as payload is not cached
                      Skipping payload {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral as payload is not cached
                      Payload {3E7A8DA8-0298-42F2-B927-4DB00E2F8FEE} can not be installed due to dependent operation failure.
                      Skipping payload {3E7A8DA8-0298-42F2-B927-4DB00E2F8FEE} DeviceCentral_DeviceCentral3LP-en_US as payload is not cached
                      Skipping payload {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 as payload is not cached
                      Skipping payload {6A75E573-6909-4D48-BDFA-D8ED118605A5} Adobe Illustrator CS5 as payload is not cached
                      Payload {B4975576-60AD-4181-AED4-253FC150B404} can not be installed due to dependent operation failure.
                      Skipping payload {B4975576-60AD-4181-AED4-253FC150B404} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack as payload is not cached
                      No operation.  We're done:
                      Updating driver data - Action: Remove driver entry
                      Updating driver data successful. Driver entry was added. ARP estimated size 247442KB
                      [       0] Wed Jul  7 01:45:26 2010  INFO
                      Total components installed: 0
                      Successfully repaired 5 components:
                      - Camera Profiles Installer
                      - Adobe Player for Embedding
                      - Adobe Utilities CS5
                      - AdobeOutputModule
                      - AdobeCMaps CS5
                      Total components removed: 0
                      [       0] Wed Jul  7 01:45:26 2010 ERROR
                      Call PostSession Custom Hook
                      :: END TIMER :: [Total Timer] took 66258 miliseconds (66.258 seconds) DTR = 1.32814 KBPS (0.00129701 MBPS)
                      Search the same string above to find when the error occured.
                      Exit Code: 7 - Unable to complete Silent workflow
                      END - Installer Session
                      • 11. Re: Please help Can't install CS5 Illustrator - Adobe is having issues helping
                        DarkMatter78 Level 1
                        PROBLEM SOLVED!!!!!!!!!!!!
                        I just spent 9 hours straight on this, but will was stronger than "its". Now I have both cs4 and cs5, but hopefully it will work if you just have cs5 as well. I also did not try runnning cs5 installer first after implementing the fix, maybe that will work too..And when getting the cs5 error, I went to re-install cs4 but got an error as well so that is why I took the steps I did. On 7x64 do the followin
                        First run the cs5 cleanup tool and reboot.
                        Second, go into c:\program file(x86)\common files\adobe\installers . Delete everything in it
                        Then go into you registry (start, run, then type regedit) and expand to this registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\ Components ...(if this isnt there, go to the folder that you deleted the files from a moment ago and extract the log from the zip file and open it and go to the end. where it says error 1402 will be followed by a unknown\components\(a bunch of numebers right here)\(more numbers)  ...
                        Copy the numbers directly after the components\ and go back into registry and click edit then "find" paste those numbers into the box and hit find..when you get to the key, scroll ALL the way back up to components again. Right click components and hit permissions.. Go to advanced and then the ownership tab up top.. click edit, hightlight administrator(s), check the box to "replace subcontainers" and click apply. respond yes to everything and close that and hit apply again if asked. then click the add button above the advanced button you just clicked. when the new box appears, click advanced and then click find now. Highlight Administrators and SYSTEM and hit OK. Then give both of them full rights and hit apply. Then click advanced again and in the first window check the box that says "replace all child objects...." and hit apply. accept the prompts and hit okay. Now give Administrators, SYSTEM, AND TrustedInstaller full rights by clicking edit above the advanced tab in the first properties box.. Then click advanced again and in the first window click "replace all child object....." again and hit apply....
                        Now do the same for the winsxs folder and (for good measure i did syswow64 but not sure if its necessary)...
                        Now you should be able to install both versions..(as i said, I installed cs4 first, maybe it was not necessary)...
                        If you dont like the idea of just blindly giving administrators full rights to all system folders, you can spend MANY MANY hours running the installs over and over and getting the faulty registry value that caused it to fail and create specific permissions for that and then go on to the next value that fails......what a pain
                        Now go into c:\windows and on the system32 folder, right click and go to properties. Go to the security tab. Click advanced and then "owner" and click edit. highlght administrators and check the box
                        • 12. Re: Please help Can't install CS5 Illustrator - Adobe is having issues helping
                          This is what I did to fix the problem. And yes, I dreaded doing it but it worked. Thanks for your direction.
                          To fix my installation problem (after 5 days talking with Adobe, going on their forums, reading everything I could read, a trip to the Apple store and talking to Tek Serve).
                          • clean sweep of all Adobe everything (double check and clean out the following)
                            • Applications/Adobe
                          • Applications/Utilities/Adobe*
                          • Library/Application Support/Adobe*
                          • Library/Application Support/FLEXnet Publisher/
                          • Library/Preferences/com.adobe*
                          • Library/Preferences/FLEXnet Publisher/
                          • Users/[user]/Library/Application Support/Adobe*
                          • Users/[user]/Library/Caches/Adobe*
                          • Users/[user]/Library/Preferences/Adobe*
                          • Users/[user]/Library/Preferences/com.adobe*
                          • mac hd/utilities/adobe installers/uninstall everything related to adobe
                          • restart computer
                          • reinstall Mac Operating System,
                          • restart computer
                          • download CS5 Illustrator
                          • restart computer
                          • create a new log in
                          • install the program on the new log in name and finally it worked.
                          • Processed to re-install all of the other Adobe programs.
                          Some of these steps had been taken before but never all in one sequence. If that would not work I would have had to clean out the entire the computer and start from scratch.
                          So that was my recipe for Exit code 7 error
