5 Replies Latest reply on Jul 9, 2010 9:07 PM by LeoAdobeX
    Auto Update Failed Error 2727
    d4nier
      Hello, I have a user (the CIO unfortunatly) that upon attempting to run the updater receives the following error:
      Error 2727. The directory entry 'MOZILLA_2' does not exist in the Directory table.
      I have searched for many of the terms in that message to no avail. Can anyone shed some light on this error?
        • 1. Re: Auto Update Failed Error 2727
          pwillener Level 8
          It would help if you'd specify the operating system where the error occurs.
          • 2. Re: Auto Update Failed Error 2727
            d4nier Level 1
            Sorry, My mistake.
            The OS is Windows XP SP3 and the current version of reader is 9.3.2 I believe it is attempting to update to 9.3.3
            • 3. Re: Auto Update Failed Error 2727
              pwillener Level 8
              I don't know what that error means - never seen it before.  I suggest that you manually download and install the update: http://ardownload.adobe.com/pub/adobe/reader/win/9.x/9.3.3/misc/AdbeRdrUpd933_all_incr.msp
              Make sure that no browser window is open when you run the update.
              • 4. Re: Auto Update Failed Error 2727
                NickIzk
                Having this exact same problem on 2 of our desktops at work.  Firefox/Mozilla is not installed, using Windows XP SP3.
                Tried completely uninstalling (even went so far as to remove all Adobe registry keys under HKLM/Software and HKLM/Current_User, all Adobe folders under Application Data for the current user and All Users and Default User, cleared all temp files) and reinstalling, and the same error occurs after attempting to update:
                [2010-07-09 15:56:03] Adobe ARM 1.1.7.0 logging started.
                [2010-07-09 15:56:03] Command Line:
                [2010-07-09 15:56:03] GetFileVersion(): C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe
                [2010-07-09 15:56:03]    File version: 9.3
                [2010-07-09 15:56:03]    Build number: 0
                [2010-07-09 15:56:03]    Revision number: 148
                [2010-07-09 15:56:03] ProductCode: {AC76BA86-7AD7-1033-7B44-A93000000001}
                [2010-07-09 15:56:03] ProductName: Adobe Reader 9.3.1
                [2010-07-09 15:56:03] ProductVersion: 9.3.1
                [2010-07-09 15:56:03] ProductRegistry: SOFTWARE\Adobe\Acrobat Reader\9.0
                [2010-07-09 15:56:03] ProductInstallDir: C:\Program Files\Adobe\Reader 9.0\
                [2010-07-09 15:56:03] Using default ARM preference AUTO_DOWNLOAD.
                [2010-07-09 15:56:03] Failed to read UAC setting, defaulting to Enabled.
                [2010-07-09 15:56:06] Failed to read UAC setting, defaulting to Enabled.
                [2010-07-09 15:56:06] ArmUpdate record found.
                [2010-07-09 15:56:06] GetFileVersion(): C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe
                [2010-07-09 15:56:06]    File version: 1.1
                [2010-07-09 15:56:06]    Build number: 7
                [2010-07-09 15:56:06]    Revision number: 0
                [2010-07-09 15:56:06] New file object: AdbeRdrUpd932_all_incr.msp
                [2010-07-09 15:56:06] New file object: AdbeRdrUpd933_all_incr.msp
                [2010-07-09 15:56:11] Failed to read UAC setting, defaulting to Enabled.
                [2010-07-09 15:56:11] C:\Documents and Settings\All Users\Application Data\Adobe\Reader\9.3\ARM\24455
                [2010-07-09 15:56:11]    GetLastError(): 0x2 - The system cannot find the file specified.
                [2010-07-09 15:56:12] Updated time stamps for 4 files
                [2010-07-09 15:56:55] Failed to read UAC setting, defaulting to Enabled.
                [2010-07-09 15:56:56] ARM returns ERROR_SUCCESS
                [2010-07-09 15:56:56] Adobe ARM 1.1.7.0 logging finished.
                [2010-07-09 15:56:57] Adobe ARM 1.4.5.0 logging started.
                [2010-07-09 15:56:57] Command Line: /ArmUpdateExe:"C:\Documents and Settings\All Users\Application Data\Adobe\Reader\9.3\ARM\24455" /MODE:2 /PRODUCT:Reader /VERSION:9. /qn
                [2010-07-09 15:56:57] ProductCode: {AC76BA86-7AD7-1033-7B44-A93000000001}
                [2010-07-09 15:56:57] ProductName: Adobe Reader 9.3.1
                [2010-07-09 15:56:57] ProductVersion: 9.3.1
                [2010-07-09 15:56:57] ProductRegistry: SOFTWARE\Adobe\Acrobat Reader\9.0
                [2010-07-09 15:56:57] ProductInstallDir: C:\Program Files\Adobe\Reader 9.0\
                [2010-07-09 15:56:57] Found CommandLine preference AUTO_DOWNLOAD.
                [2010-07-09 15:56:57] Restarted, skipping IsTimeElapsed.
                [2010-07-09 15:56:57] Restarted, skipping InitArmUpdate.
                [2010-07-09 15:56:57] New file object: AdbeRdrUpd932_all_incr.msp
                [2010-07-09 15:56:57] New file object: AdbeRdrUpd933_all_incr.msp
                [2010-07-09 18:13:39] InstallProductMsp...
                [2010-07-09 18:13:39]    file - C:\Documents and Settings\All Users\Application Data\Adobe\Reader\9.3\ARM\AdbeRdrUpd932_all_incr.msp;C:\Documents and Settings\All Users\Application Data\Adobe\Reader\9.3\ARM\AdbeRdrUpd933_all_incr.msp
                [2010-07-09 18:13:39]    args -
                [2010-07-09 18:13:51] Error 2727.The directory entry 'MOZILLA_2' does not exist in the Directory table.
                [2010-07-09 18:13:51] ** Setting Error Condition:
                [2010-07-09 18:13:51]    Error Code: 1500
                [2010-07-09 18:13:51] Installation error code:
                [2010-07-09 18:13:51]    Error Code: 1603
                [2010-07-09 18:18:04] User exited
                [2010-07-09 18:18:04] Delete file: C:\DOCUME~1\user\LOCALS~1\Temp\ArmUI.ini
                [2010-07-09 18:18:04]    Error Code: 2
                [2010-07-09 18:18:04] C:\Documents and Settings\All Users\Application Data\Adobe\Reader\9.3\ARM\
                [2010-07-09 18:18:04]    GetLastError(): 145 - The directory is not empty.
                [2010-07-09 18:18:04] ARM returns ERROR_SUCCESS
                [2010-07-09 18:18:04] Adobe ARM 1.4.5.0 logging finished.
                [2010-07-09 18:21:08] Adobe ARM 1.4.5.0 logging started.
                [2010-07-09 18:21:08] Command Line: /PRODUCT:Reader /VERSION:9.0 /MODE:2
                [2010-07-09 18:21:08] ProductCode: {AC76BA86-7AD7-1033-7B44-A93000000001}
                [2010-07-09 18:21:08] ProductName: Adobe Reader 9.3.1
                [2010-07-09 18:21:08] ProductVersion: 9.3.1
                [2010-07-09 18:21:08] ProductRegistry: SOFTWARE\Adobe\Acrobat Reader\9.0
                [2010-07-09 18:21:08] ProductInstallDir: C:\Program Files\Adobe\Reader 9.0\
                [2010-07-09 18:21:08] Found CommandLine preference AUTO_DOWNLOAD.
                [2010-07-09 18:21:11] ArmUpdate record found.
                [2010-07-09 18:21:11] Newer version ARM Update is not available.
                [2010-07-09 18:21:11] New file object: AdbeRdrUpd932_all_incr.msp
                [2010-07-09 18:21:11] New file object: AdbeRdrUpd933_all_incr.msp
                • 5. Re: Auto Update Failed Error 2727
                  LeoAdobeX Adobe Employee
                  Updater has nothing to do with this – it simply executes installers using Windows Installer Service.
                  Something is not right in the installer database and is not related to a presence of Firefox on the system.
                  You have to uninstall current Reader (if uninstall from ARP does not work, use MS cleanup tool)
                  Then you need to install Reader 9.3.0 from Adobe.com and let Updater install all the patches.
                  Good luck..
