0 Replies Latest reply on Jul 7, 2010 1:18 PM by Cr99
    setting bounds for WindowedApplication
    Cr99 Level 1
      for some reason this flex 4 code gives me an error but I can't figure out why.  In my WindowedApplication I have:
      var prefs:Object = fs.readObject();
      var rect:Rectangle = new Rectangle();
      rect = prefs.bounds as Rectangle;
      this.bounds = rect;  // error here
      Error message:
      ArgumentError: Error #2007: Parameter rect must be non-null.
      I originally also tried it without the rect object and just did:
      this.bounds = prefs.bounds as Rectangle;
      which gives me the following error:
      TypeError: Error #1034: Type Coercion failed: cannot convert Object@1dbbe1f1 to flash.geom.Rectangle.
      That seems like a bogus error since I can assign pref.bounds to rect without an error.  I don't know why this isn't working.  It works under flex 3 compatibility mode but that also breaks a lot of my spark components so I can't use it.
