0 Replies Latest reply on Jul 7, 2010 3:48 PM by smagfx2
    Cannot play SWF on Mac
    smagfx2 Level 1
      Good afternoon,
      I'm have a situation where I must load a PC/Linux-compiled SWF (which came from a version control system) on a Mac. However, the SWF immediately has the following error:
      Error #2034: An invalid digest was supplied.
      Failed to load RSL framework_3.5.0.12683.swz
      Failing over to RSL framework_3.5.0.12683.swf
      Flex Error #1001: Digest mismatch with RSL <SomePath>/framework_3.5.0.12683.swf. Redeploy the matching RSL or relink your application with the matching library.
      I've looked at the local framework SWF on both a PC (where it works fine) and a mac (where it does not) and they appear to be the same file (exact same size). I've tried compiling a test SWF on the mac and running it; that works fine, it is just when I try to run the PC-compiled SWF that it fails.
      Anyways, what's the cause of this and how can I fix it?
      Thank you for any suggestions!
      EDIT: Error occurs in both the browser and standalone player. I assume it is also happening in the non-debug versions of these as it did not load then either. Version of standalone debugger: 10.1.53.64 (10.1)
