1 Reply Latest reply on Jul 7, 2010 6:15 PM by UbuntuPenguin
    Avoiding Vertical scrollbar of a flashplayer inside a browser
    mxvx
      I am using a flex application which opens up with a default height
      I am adding some components at run time which increases the height of the application.
      Since the swf is embedded @ within a html file and centered. I am getting a vertical scroll bar for the flash player
      The flash player looks ugly and i am tyring to remove it ??
      Any solutions
      Regards
      mxvx
        • 1. Re: Avoiding Vertical scrollbar of a flashplayer inside a browser
          UbuntuPenguin Level 4
          Generally when I need to get rid of a scrollbar I will do something like this.
          Create  a skin based off of the component you are trying to remove the scroll-bar from.  For example , my lists tend to want to have a horizontal scrollbar.  So I would create a custom list skin.
          Then , in the auto-generated skin code , you should see a <s:Scroller /> component.  On this scroller component you set the scroll-policy to what you want it to be.  So I would have something like this
          <Scroller horizontalScrollPolicy="off" ... >
            <Some kind of content group ...
          If this post was helpful , please mark it as such.
          Sincerely ,
             Ubu
