5 Replies Latest reply on Jul 12, 2010 11:22 AM by jay fresno
    Batch sequence to remove document JavaScript
    jay fresno Level 2
      Does anyone know of a batch sequence that can remove the document JavaScript from a group of Acrobat 9 Pro PDFs?
        • 1. Re: Batch sequence to remove document JavaScript
          If you know the script's name, use this:
          this.addScript("ScriptName", "");
          • 2. Re: Batch sequence to remove document JavaScript
            jay fresno Level 2
            Hi Try67,
            Thanks so much for your reply. I really appreciate your help.
            I need to remove the script rather than add it, but your answer gave me the clue I needed for how to construct the remove script. Problem solved.
            • 3. Re: Batch sequence to remove document JavaScript
              You use the "addScript" method to add or modify a document level script. You use the 'setAction' method for adding or modifying page triggers, bookmark triggers, and field actions. And you use the 'setPageAction, for adding or modifying page actions. A null string for a script is the same as a "NOP" command, No Operation. But you need to know the various script names.
              With the PDF Optimizer in Acrobat Professional, you can remove all JavaScirpt actions.
              • 4. Re: Batch sequence to remove document JavaScript
                wildcathoya Level 1
                If the doc-level Javascript names are not known in advance, then the only way I found to remove all of the Javascripts is with doc.extractPages(), which will create a new doc object, and then newDoc.saveAs() followed by newDoc.closeDoc().
                I don't do this in a batch sequence but in a .Net app, so I'm not entirely sure how you would write this in a batch sequence.  Here's a code snippet that shows the basic logic:
                                object AcroJS = AcroPDDoc.GetJSObject();
                                string PdfFullPath = "C:\\filename.pdf";
                                Type T = AcroJS.GetType();
                                object newDoc = T.InvokeMember("extractPages", InvokeMethodFlags, null, AcroJS, null);
                                AcroJS = null;
                                AcroPDDoc.Close();
                                object[] saveAsDataParam = { PdfFullPath };
                                T.InvokeMember("saveAs", InvokeMethodFlags, null, newDoc, saveAsDataParam);
                                T.InvokeMember("closeDoc", InvokeMethodFlags, null, newDoc, null);
                                newDoc = null;
                                AcroPDDoc.Open(PdfFullPath);
                This can also be used to create a new doc GUID.
                Bill
                • 5. Re: Batch sequence to remove document JavaScript
                  jay fresno Level 2
                  Bill,
                  Thanks for this information. I've made a note of it in case I need it in the future.
