This content has been marked as final.
Show 8 replies
1. Re: Can't put video within template,
Stephen Pickering122 Aug 17, 2007 4:26 AM (in response to Stephen Pickering122)Also, I know it is with all templates as I created a new template from scratch with nothing but three lines of text. As soon as it is created into a template, any new pages based on it cannot insert a flash video. The flash video I am talking about is Insert>Media>Flash Video.
I am inserting it this way because I compress it using Flash CS3 Video Encoder (which I don't believe gives me options for navigation).
I assume the video is trying to put coding in the head where only the body is editable, except I made a new template with everything editable- same problem. -
2. Re: Can't put video within template,
Newsgroup_User Aug 17, 2007 5:09 AM (in response to Stephen Pickering122)Turn off the check for Flash version option when you insert the video.
That's the root cause of the problem. With that selected, DW tries to write
a call to a javascript routine into the <body> tag, and you cannot do that
in a template child page.
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.dreamweavermx-templates.com - Template Triage!
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
"is this taken?" <webforumsuser@macromedia.com> wrote in message
news:fa40lb$eeh$1@forums.macromedia.com...
> scratch
> flash
> Encoder
> is
> problem.
3. Re: Can't put video within template,
Stephen Pickering122 Aug 17, 2007 1:56 PM (in response to Stephen Pickering122)Murray, Thank you! What a simple solution. Doing a search I couldn't find any answers that worked- they all dealt with corrupt config files, etc.
Thank you again,
Steve -
4. Re: Can't put video within template,
Newsgroup_User Aug 17, 2007 2:08 PM (in response to Stephen Pickering122)Good luck, Steve! Now, if you *REALLY* want to have that check for Flash
versions, there is a way to do that, too.
news:fa521j$m91$1@forums.macromedia.com...
> etc.
> Thank you again,
> Steve
5. Re: Can't put video within template,
JimboSun Aug 17, 2007 9:32 PM (in response to Stephen Pickering122)How, how? How do we have the Check for Flash in a Template Child Page? -
6. Re: Can't put video within template,
Newsgroup_User Aug 18, 2007 3:59 AM (in response to Stephen Pickering122)When you insert Flash video with Flash detection and prompting, DW wants to
put this into the body tag -
onLoad="MM_CheckFlashVersion('7,0,0,0','Content on this page requires a
newer version of Adobe Flash Player. Do you want to download it now?');"
e.g.,
<body onLoad="MM_CheckFlashVersion('7,0,0,0','Content on this page requires
a newer version of Adobe Flash Player. Do you want to download it now?');">
Let's assume that you have a child page with the video already inserted
WITHOUT Flash detection.
What you would need to do would be to create a DUMMY page, (FILE | New >
Basic HTML), and insert the video on that page, then copy and paste from
that page into your template child page.
First, copy and paste the Flash detection script -
change this -
</head>
to this -
function MM_CheckFlashVersion(reqVerStr,msg){
with(navigator){
var isIE = (appVersion.indexOf("MSIE") != -1 &&
userAgent.indexOf("Opera") == -1);
var isWin = (appVersion.toLowerCase().indexOf("win") != -1);
if (!isIE || !isWin){
var flashVer = -1;
if (plugins && plugins.length > 0){
var desc = plugins["Shockwave Flash"] ? plugins["Shockwave
Flash"].description : "";
desc = plugins["Shockwave Flash 2.0"] ? plugins["Shockwave Flash
2.0"].description : desc;
if (desc == "") flashVer = -1;
else{
var descArr = desc.split(" ");
var tempArrMajor = descArr[2].split(".");
var verMajor = tempArrMajor[0];
var tempArrMinor = (descArr[3] != "") ? descArr[3].split("r") :
descArr[4].split("r");
var verMinor = (tempArrMinor[1] > 0) ? tempArrMinor[1] : 0;
flashVer = parseFloat(verMajor + "." + verMinor);
// WebTV has Flash Player 4 or lower -- too low for video
else if (userAgent.toLowerCase().indexOf("webtv") != -1) flashVer =
4.0;
var verArr = reqVerStr.split(",");
var reqVer = parseFloat(verArr[0] + "." + verArr[2]);
if (flashVer < reqVer){
if (confirm(msg))
window.location =
" http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash";
</script>
</head>
Then, assuming you have no other events in the child page's body tag, change
this -
</head>
to this -
window.onload(MM_CheckFlashVersion('7,0,0,0','Content on this page requires
</script>
</head>
and you should be all set.
(by the way, my example is set to check for version 7)
"JimboSun" <webforumsuser@macromedia.com> wrote in message
news:fa5sph$jkk$1@forums.macromedia.com...
7. Re: Can't put video within template,
JimboSun Aug 18, 2007 7:21 AM (in response to Stephen Pickering122)Thank You Murray! I'll try it out. -
8. Re: Can't put video within template,
Newsgroup_User Aug 18, 2007 7:26 AM (in response to Stephen Pickering122)Good luck.
news:fa6v8g$p7o$1@forums.macromedia.com...
