1 Reply Latest reply on Jul 8, 2010 7:29 AM by asydd
    How to time music (sync) to timeline
    nxst Level 1
      If i create timeline slideshow with tweens
      between the pictures, how do I add music so that it ends when the pictures end?
      I read that audio can come out of sync??
      What if i use another program to create the swf like after effects that exports with audio? and import, would it lose sync then?
        • 1. Re: How to time music (sync) to timeline
          asydd Level 1
          May I add to the question? Thanks...  can AS3 read cue points in audio (added in say Soundbooth) and start and stop at different cue points.
          To the sync, I add sound file to the library (or load it), and set different sounds to start at particular frames, I haven't had trouble with sync but I believe it is more prevalent in video files. You can add audio to the timeline directly and you can visibly see the duration of the sound clip. In AS2 I was using onSoundComplete to determine when to change images, in AS3 channel.addEventListener(Event.SOUND_COMPLETE, callFunction);
