3 Replies Latest reply on Jul 15, 2010 5:08 AM by Mike Bauer
    Getting remote messaging to work with Java/Spring and Flex
    Mike Bauer Level 1
      I am trying to get remote messaging working on a Flex client with a Java/Spring backend.
      I have the channel is setup on the server as such:
      channel-definition id="long-polling-channel"
      class="mx.messaging.channels.AMFChannel">
      <endpoint
      url="http://{server.name}:{server.port}/{context.root}/messagebroker/amflongpolling"
      class="flex.messaging.endpoints.AMFEndpoint" />
      <properties>
      <!-- Values for near-real time messaging -->
      <polling-enabled>true</polling-enabled>
      <polling-interval-millis>0</polling-interval-millis>
      <wait-interval-millis>-1</wait-interval-millis>
      <max-waiting-poll-requests>
      10
      </max-waiting-poll-requests>
      </properties>
      </channel-definition>
      In the Spring context, I am setting up the MessageBroker, MessageTemplate, and some custom wrapper code:
      xml version="1.0" encoding="UTF-8"?>
      beans xmlns="http://www.springframework.org/schema/beans"
      xmlns:flex="http://www.springframework.org/schema/flex" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
      xsi:schemaLocation="
      http://www.springframework.org/schema/beans/spring-beans-2.5.xsd
      http://www.springframework.org/schema/flex/spring-flex-1.0.xsd"
      <flex:message-broker id="messageServiceBroker" />
      <flex:message-destination id="event-bus"
      message-broker="messageServiceBroker" channels="long-polling-channel"
      message-time-to-live="1000"
      subscription-timeout-minutes="5"
      throttle-inbound-max-frequency="500" throttle-inbound-policy="ERROR"
      throttle-outbound-max-frequency="500" throttle-outbound-policy="IGNORE" />
      <bean id="defaultMessageTemplate" class="org.springframework.flex.messaging.MessageTemplate">
      <property name="defaultDestination" value="event-bus" />
      <property name="messageBroker" ref="messageServiceBroker" />
      </bean>
      <bean id="MessagingServices" class="com.bofa.esm.utility.messaging.MessagingServices">
      <property name="messageTemplate" ref="defaultMessageTemplate" />
      <property name="destinationName" value="event-bus" />
      <property name="scheduler" ref="PersistentQuartzScheduler" />
      </bean>
      beans>
      The custom wrapper code is insignificant, but it basically creates a thread and posts a custom context over and over every minute.  The actual message is posted with this bit of code:
           messageTemplate.send(msgCtx);
      On the Flex side, I create a Channel and ChannelSet like thus:
      public
      static function getMessageChannelSet():ChannelSet{
      if(messageChannelSet == null){
      messageChannelSet =
      new ChannelSet();
      //e.g. 'http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling';
      var messageURL:String = getBaseUrl() + MESSAGE_URL;
      var channel:AMFChannel = new AMFChannel(MESSAGE_CHANNEL_NAME,messageURL);
      messageChannelSet.addChannel(channel);
      return channelSet;
      And then, latter I create a Consumer and add the channelset to it:
      var
      _messageConsumer:Consumer = new Consumer();
      var msgChannel:ChannelSet = RemotingUtility.getMessageChannelSet();
      var encrypted:Object = this.encrypt(_sessionModel.username, _sessionModel.password);
      var token:AsyncToken = msgChannel.login(encrypted.userId, encrypted.password);
      _messageConsumer.channelSet = msgChannel;
      _messageConsumer.destination =
      "event-bus";
      _messageConsumer.addEventListener(MessageEvent.RESULT,
      this.onMessage);
      The problem is, I dont get the messages from the server.  In fact, from what I can tell by the logs when I post a message from the server, it doesn't appear that anything is listening to the channel:
      09:32:03,106 INFO [MessagingServices] Posting message...
      09:32:08,184 INFO [STDOUT] [BlazeDS]Before invoke service: message-service
      incomingMessage: Flex Message (flex.messaging.messages.AsyncMessage)
      clientId = CC2B0D5D-B00A-CD8B-CE43-0430C8CC10DF
      correlationId = null
      destination = event-bus
      messageId = CC3211B4-F80E-15FE-076C-00C963ED5D01
      timestamp = 1278595928184
      timeToLive = 0
      body = com.bofa.esm.utility.messaging.SimpleMessageContext@159a771
      09:32:08,200 INFO [STDOUT] [BlazeDS]Before invoke service: message-service
      timeToLive = 0
      09:32:08,200 INFO [STDOUT] [BlazeDS]Sending message: Flex Message (flex.messaging.messages.AsyncMessage)
      timeToLive = 1000
      to subscribed clientIds: []
      timeToLive = 1000
      09:32:08,200 INFO [STDOUT] [BlazeDS]After invoke service: message-service; execution time = 0ms
      reply: null
      reply: null
      09:32:12,075 INFO [STDOUT] [BlazeDS]Before invoke service: message-service
      messageId = CC3236D0-7B0D-182C-5632-C84FB4D1E215
      timestamp = 1278595932075
      timeToLive = 0
      body = com.bofa.esm.utility.messaging.SimpleMessageContext@1a6595b
      timeToLive = 0
      09:32:12,075 INFO [STDOUT] [BlazeDS]Sending message: Flex Message (flex.messaging.messages.AsyncMessage)
      timeToLive = 1000
      timeToLive = 1000
      09:32:12,075 INFO [STDOUT] [BlazeDS]After invoke service: message-service; execution time = 0ms
      reply: null
      reply: null
      Shouldn't the "subscribed clientIds: []" have something listed as subscribed?  What am I missing?
        • 3. Re: Getting remote messaging to work with Java/Spring and Flex
          Mike Bauer Level 1
          I made some modifications to the code section that registers the Consumer:
            Alert.show(
          "onRegister running","AppShellMediator",Alert.OK);
            var _messageConsumer:Consumer = new Consumer();
          "event-bus";
          this.onMessage);
            _messageConsumer.subscribe(
          "MessagingClient"+Math.random());
          if(_messageConsumer.connected)
                Alert.show(
          "Message Channel is connected","AppShellMediator",Alert.OK);
            if(_messageConsumer.authenticated)
                Alert.show(
          "Message Channel is authenticated","AppShellMediator",Alert.OK);
            if(_messageConsumer.subscribed)
                Alert.show(
          "Message Channel is subscribed, clientId: "+_messageConsumer.clientId,"AppShellMediator",Alert.OK);
          I am now calling the subscribe method, then testing to see if the consumer is connected, authorized, and subscribed.  The first two return True, the last one does not.  So, despite the call to subscribe(), the Consumer is not subscribed.  Is there a way to figure out why?  Possibly there was an error somewhere?
