5 Replies Latest reply on Aug 16, 2007 2:51 PM by cf_dev2
    ObjectFatory X Race Condition
    ronanlucio
      I have a class with some public properties.
      To avoid too many create objects I tried to create some object models in the application scope,
      exemple:
      <cfscript>
      application.objProduct = createObject("component","Product").init();
      </cfscript>
      So I started using:
      variables.objProduct = application.objProduct
      variables.objProduct.load( id );
      insted of
      variables.objProduct = createObject("component","Product");
      After that I´ve had many problems with race conditions.
      It seems when I create an object using "objProduct = application.objProduct"
      the variable (objProduct) is created per reference and every execution of the
      load() method populates the same object (application.objProduct) instead of
      the local variables.objProduct.
      So I like to know how to create local objects without getting the objects parent reference.
      If I use a get method like "variables.objProduct = application.objProduct.get();"
      intead of simple attribution "variables.objProduct = application.objProduct"
      would solve the race condition problem?
      I know the ObjectFactory concepts would solve the problem, but these application
      doesn´t have only private properties, but public properties, too.
      Af first I need to solve the problem 1: race condition.
      After that I´ll make some tests with ObjectFatories.
      Ronan
