4 Replies Latest reply on Nov 29, 2010 9:10 AM by Darrell Loverin
    Cannot load optimized RSL: digest mismatch
    skagels
      Note: I am using Flex 3.0.0.
      When my Flex applicatoin tries to load my own optimized RSL at runtime I see a digest mismatch error.  When I replace the optimized RSL (swf) with the original RSL (same name) in my deployed web app the RSL loads successfully.  The developer's guide doesn't suggest that I need to do anything special to the optimized RSL.  Any idea why the digests are not the same between the regular and optimized RSLs?
      I have run the optimized RSL through digest.exe, thinking that maybe that would insert the correct digest (from the original swc file) but I get the same digest mismatch error.
      Could this be a caching issue or am I missing a step?
      My Steps:
      1. Extract library.swf from mylib.swc file
      2. Run: optimizer.exe -keep-as3-metadata="Bindable,Managed,ChangeEvent,NonCommittingChangeEvent,Transient" -input library.swf -output mylib.swf
      3. Compile my app against mylib.swc with RSL URL: mylib.swf
      4. Deploy optimized mylib.swf with flex application
