1 Reply Latest reply on Jul 8, 2010 12:02 PM by s_puyear
    How to render an age object in DataGrid
    s_puyear
      I cannot figure out how to render elements of an age object (ie. 5 years 3 months 6 days etc.) in a Flex DataGrid.  The object is in an ArrayColection and he data is coming from a ColdFusion component.  However, when I try to display elements of the object in a DataGrid, I merely get [object Object] displayed.  I tried adding a renderer to the column to no avail.  I know the data is coming across OK because I can display it outside the DataGrid.
      Has anyone faced this before?  If so, can you offer ideas on how you overcame this?
      Thanks!
        • 1. Re: How to render an age object in DataGrid
          VRPDeveloper Level 3
          you need to specify labelfield or labelfunction in datagrid column accordingly
          say grid is displaying 5 years so data might be coming as field "years" then the labelfield should be "years" in this column
          so check your arraycollection holding age object....
          If this post answers your question or helps, please kindly mark it as such.
