1. Re: Quiz Results Analyzer w/Internal Server
Chinmay Baid Jul 8, 2010 9:59 PM (in response to rtc2010)Hi,
This is strange. Can you please check if you have placed the internalserverread.php file in the root of the wamp server? Also, the link to this PHP file has to be added in the preferences of Quiz Results Analyzer.
Regards
Chinmay
2. Re: Quiz Results Analyzer w/Internal Server
lbj9000 Jul 12, 2010 9:25 AM (in response to Chinmay Baid)Hope you can help out on this one?
I get the following error in the Quiz analyzer. "No Companies found in the current user account."
In the Quiz Analyzer under "Preferences" in the text field "Link" I have written "http://nannabrosolat.dk/quiz/CaptivateResults".
Has taken the quiz once and can see that there is created a folder "CaptivateResults". In the "CaptivateResults" is a folder with the company name that I wrote when I created the quiz. So it seems that I am doing everything correctly or? -
3. Re: Quiz Results Analyzer w/Internal Server
rtc2010 Jul 12, 2010 12:32 PM (in response to lbj9000)lbj9000 --
I got sidetracked last week and haven't tried again using a real server (out on the web), but I did managed to get it working using my desktop installation of WAMP as the server.
Chinmay's post revealed a critical element you seem to also be missing: the PHP file to be accessed needs to be in the URL you specify in the Quiz Results Analyzer's Preferences panel. You have to specify the full path to Adobe's stock PHP file: internalserverread.php. (I made the mistake of assuming the Analyzer already knew which PHP file it was looking for. For example, mine is now working when I use the following URL: http://localhost/trainlocal/internalserverread.php
I'm sure they didn't hardcode the reference to that internalserverread.php file because they wanted to leave open the option for you to create your own PHP file if you want/need to.
A tutorial file Adobe included with Captivate 5 was helpful. Check your system for this file or maybe just copy/paste the following URL into your browser to view the steps involved in getting Alternate Reporting to work.
C:\Program Files (x86)\Adobe\Adobe Captivate 5\cp_tutorials\htmls\18_Alternate_Reporting.html
Hope that helps!
-- Randall
4. Re: Quiz Results Analyzer w/Internal Server
lbj9000 Jul 12, 2010 11:27 PM (in response to rtc2010)Hello RTC2010
Thanks for the quick reply.
Unfortunately I still get the same error: "No Companies found in the current user account."
Status:
The Quiz writes resultdata to the folder. It has created a folder named: http://nannabrosolat.dk/quiz/CaptivateResults
In that folder is a folder that has the company name I entered when I created the quiz. At the bottom of the folder structure is some xml files which I assume is the quiz data.
In the Quiz analyzer in the text field "Link" I have written:
http://nannabrosolat.dk/quiz/internalserverread.php
Kind Regards
Lasse Brosolat Jensen -
5. Re: Quiz Results Analyzer w/Internal Server
Chinmay Baid Jul 13, 2010 12:01 AM (in response to lbj9000)Hi,
Have you placed the internalserverread.php at the same location, which you have mentioned in the link?
Regards
Chinmay
6. Re: Quiz Results Analyzer w/Internal Server
lbj9000 Jul 13, 2010 4:05 AM (in response to Chinmay Baid)Hello Chinmay Baid
Yes I have placed it here: http://nannabrosolat.dk/quiz/internalserverread.phpKind Regards
Lasse
7. Re: Quiz Results Analyzer w/Internal Server
Chinmay Baid Jul 13, 2010 4:55 AM (in response to lbj9000)Hi Lasse,
This message "No Companies found in the current user account", is thrown in case if any IOError or any SecurityError is encountered.
Following information will be helpful to resolve this problem :
1. Can you please check the access permissions/connectivity on this server, from where you are trying to read the data?
2. Can you mention which server are you using? Is it a unix-based or windows-based server?
3. If it is a unix-based server, can you check the permissions set for every folder?
Regards
Chinmay
8. Re: Quiz Results Analyzer w/Internal Server
lbj9000 Jul 13, 2010 6:43 AM (in response to Chinmay Baid)Hello Chinmay
internalserverread.php, internalServerReporting.php and all folders in “CaptivateResults” have following permissions:
Owner permission: Read, Write, Execute
Groups permission: Read, Execute
Public permission: Read, Execute
The XML files in the bottom folder in “CaptivateResults” have following permissions:Owner permission: Read, Write
It is a Unix server. But at work we are using Windows/Asp.net. So I am planning to convert the files to c#.
Any way.
When I run the script-pages “outside” Captivate I get error with “internalserverread.php” but “internalServerReporting.php ” works fine.
http://nannabrosolat.dk/quiz/internalserverread.php Error
http://nannabrosolat.dk/quiz/internalServerReporting.php Works fine
On another webhotel it is the same:
http://www.loppen.com/quiz/quiz/internalserverread.php Error
http://www.loppen.com/quiz/quiz/internalServerReporting.php Works fineKind regards
Lasse
9. Re: Quiz Results Analyzer w/Internal Server
Chinmay Baid Jul 13, 2010 7:33 AM (in response to lbj9000)Hi Lasse,
Thanks for sharing the information!!
Ideally, no error should occur with the access permissions that you have mentioned.
Can you please send us the details of the unix server configuration as well the PHP version installed on your server? Using all this information, we'll try to simulate and identify the issue at our end.
Regards
Chinmay
10. Re: Quiz Results Analyzer w/Internal Server
lbj9000 Jul 13, 2010 7:49 AM (in response to Chinmay Baid)Thank you for the quick responses.
The webhotel i am using is: http://www.one.com/en/. Php version is 5.
Maybe you can give me some specific questions about the unix server configuration, sorry im not a unix guy, I will then send them to the webhotels support.
Kind regards
Lasse
11. Re: Quiz Results Analyzer w/Internal Server
lbj9000 Jul 14, 2010 1:14 AM (in response to Chinmay Baid)Hello Chinmay
There is a controlpanel on the webhotel were i can:
Turn on/off: PHP error messages --> It is set to OffTurn on/off: Register globals --> It is set to Off
It is also posible export log files --> Let me know if I should send you some?
The other webhotel I mentioned earlier. There the quiz will not write quizdata(XML) to the server. I can also provide you with information on that server/webhotel?Kind regards and thanks for the help.
Lasse
12. Re: Quiz Results Analyzer w/Internal Server
Chinmay Baid Jul 14, 2010 1:44 AM (in response to lbj9000)Hi Lasse,
Thanks again for sharing the information!!
We seem to have found the solution while debugging. And we have made some changes the internalserverread.php file to work with Unix server.
Can you please share your email-id, so that I can send you the fixed PHP file?
My e-mail id is : cbaid@adobe.com.
Regards
Chinmay
13. Re: Quiz Results Analyzer w/Internal Server
lbj9000 Jul 14, 2010 2:26 AM (in response to Chinmay Baid)Hello Chinmay
Thanks - it is working now.Have a good summer :-)
14. Re: Quiz Results Analyzer w/Internal Server
IHeartCaptivate Nov 24, 2010 8:47 AM (in response to lbj9000)Chinmay -
Can you tell me what was wrong? I'm getting the same problem when I press Get Results in the Analyzer, a window appears saying "No compaines found in the current user account." I read about making sure the permissions correct, but where do I do that?
And - at the end of the quiz when I enter in my information after pressing Post Results, "Connecting..." appears on top of my project, that just sits there. I assume it's trying to connect to the server, but it never connects. I don't get the window saying the results have posted successfully.
So what am I doing wrong?
- Under preferences in Analyzer I have my link to the InternalServerRead.php file.
- In my project under Quiz Preferences, and the Internal Settings I have the link to the internalServerReporting.php file
- I watched the tutorial (18 - Alternate Reporting) and followed those directions. I created a trainlocal folder, published my Captivate project to a folder within the trainlocal folder. The PHP files are in the trainlocal folder also.
- The server I have is located on our network, not on my local computer.
- I have not changed either PHP file, bc I don't know how or what I would do.
- I'm on Windows 7 - 32 bit.
- I have tried reporting to Acrobat.com and it worked fine.
Help!
15. Re: Quiz Results Analyzer w/Internal Server
Chinmay Baid Nov 24, 2010 8:53 PM (in response to IHeartCaptivate)Hi,
The above post was related to unix servers. Can you please mention the details of the server which you're using?
Regards
Chinmay Baid
16. Re: Quiz Results Analyzer w/Internal Server
IHeartCaptivate Nov 29, 2010 6:54 AM (in response to Chinmay Baid)I think I got it...but I thought I'd post my results in case anyone else is following this thread....
The analyzer wouldn't give me results if I published it, viewed the output, took the quiz and tried to submit the results. I had to go to the server and access the project, and take the quiz that way for the results to appear in the analyzer. I don't know if that is common knowledge, but I didn't know that, so if you are having this problem also, try going to the server to access your project. Once I did that, it worked.
Per the tutorial (in the Program Files of Adobe Captivate), the results from the quiz should go to the analyzer but it didn't for me, maybe security reasons?? It should be noted that whenever I was trying to get a quiz to report with email, it would never work when I "Viewed Output" after publishing the project. I would always have to post it to our internal site and access it through the web. So maybe whatever is causing me to not use an email was also causing the results not to be posted. Who cares, it works now.
Chinmay - I don't think I need your help anymore. I don't really care that it doesn't work when viewing the output. As long as it works is all I care about. But thank you for responding to me so quickly.
17. Re: Quiz Results Analyzer w/Internal Server
FightRice Apr 22, 2011 3:07 PM (in response to Chinmay Baid)I sent an email the other day inquiring about these changes and the file. Is it possible you share the file for us here to use, I'm having the same problem the original poster is on a NIX server.
18. Re: Quiz Results Analyzer w/Internal Server
Chinmay Baid Apr 22, 2011 9:13 PM (in response to FightRice)Hi,
Attached is the PHP file for Unix Servers.
Please try and let me know if it works for you.
Regards
Chinmay Baid
Software Engineer
Adobe Captivate | Adobe Systems | Bangalore
19. Re: Quiz Results Analyzer w/Internal Server
FightRice Apr 22, 2011 9:55 PM (in response to Chinmay Baid)Thanks for the reply Chinmay, but how do I download attachments on the forums here? I dont see one listed with the post.
Thanks again!
20. Re: Quiz Results Analyzer w/Internal Server
Chinmay Baid Apr 22, 2011 11:13 PM (in response to FightRice)Can you send me your email-id?
I'll send the file to you on the same.
My email-id is : cbaid@adobe.com.
Regards
Chinmay Baid
Software Engineer
21. Re: Quiz Results Analyzer w/Internal Server
FightRice Apr 22, 2011 11:44 PM (in response to Chinmay Baid)Sure mine is dmchenry35@gmail.com Thanks again!
22. Re: Quiz Results Analyzer w/Internal Server
dnguyen.mtv@gmail.com Sep 28, 2011 10:56 PM (in response to Chinmay Baid)Hi Chinmay,
I also have a same issue as the owner of this thread, that I couldn't get results from my unix-based server. When I hit the "Generate Report" i got the "data is not present on local file system." Would you please help? my email address is: dnguyen.mtv@gmail.com
Thanks much!
23. Re: Quiz Results Analyzer w/Internal Server
sjpvt001 Oct 10, 2011 2:00 PM (in response to dnguyen.mtv@gmail.com)Hello Chinmay and others.....
I am also having a problem getting the "internal server" option to work with out unix (LAMP) server configuration. This appears to be an ideal solution to our quiz reporting needs, but I do not understand why there isn't better documentation on how to set this up on a very commonly used server setup such as ours. If there is a php file for unix servers, can you please email it to me?
Thank you,
SJPVT
24. Re: Quiz Results Analyzer w/Internal Server
sjpvt001 Oct 23, 2011 1:00 PM (in response to Chinmay Baid)Hello Chinmay and others.....
My email address is: spintaur@uvm.edu
Thank you,
SJPVT
25. Re: Quiz Results Analyzer w/Internal Server
cpalmer0001 Oct 26, 2011 8:28 PM (in response to Chinmay Baid)I was getting same error with my Captivate Results Analyzer "No Companies Found....." Searched around and found that if you add
$filterArray = array(".","..",".DS_STORE",".svn"); after <?php in the internalserverread.php file and then put back on your server it worked.
Top line of file should look like this:
<?php $filterArray = array(".","..",".DS_STORE",".svn");
26. Re: Quiz Results Analyzer w/Internal Server
rtc2010 Oct 27, 2011 8:57 AM (in response to cpalmer0001)Casey,
Give this one a try. I believe it's the one Chinmay modified last year --
it's the one with the latest timestamp on my server.
27. Re: Quiz Results Analyzer w/Internal Server
TMPRisk Jan 5, 2012 2:06 PM (in response to rtc2010)I am having the same problem as many other users in this thread.
- I have published a project with a quiz to an external hosted web server
- I am able to take the quiz and successfully get results posted to the server as an XML file
- I am unable to read these results with the Quiz Analyzer
- I am using Captivate 5.5
I have two servers (one used for development and another for production). Both are Unix servers but hosted by different providers
- I have successfully resolved the problem on the development server adding
- $filterArray = array(".","..",".DS_STORE",".svn"); to the internalserverread.php file after the <?php opening
- When using the same edited internalserverread.php file on the production server I am unable to read the results
- I have validated that the file permissions for the internalserverread.php file and for the captivate results folders match on both servers.
Your support would be appreciated
28. Re: Quiz Results Analyzer w/Internal Server
AHamel Feb 15, 2012 12:55 PM (in response to Chinmay Baid)I am having a similar issue. I am hosting the quiz on our web server (linux running Apache and Ubuntu with a version 5 of PHP). I can send someone a link to take the quiz and it reports that the results have posted, but I have no results anywhere. Ideally I would like to use the analyzer, but I really just want to access the results in any way at the moment. I have followed the tutorials, but since I am not using WAMP I am not able to troubleshoot this issue by watching them. Can you help?
Ann
29. Re: Quiz Results Analyzer w/Internal Server
diehlang Mar 21, 2012 7:38 AM (in response to Chinmay Baid)Hi Chinmay,
I'm creating a quiz in Captivate5.5 that will be taken in a classroom of 20-25 junior high students for a thesis project-- this is a one time event so it's not worth it to work with LMS. It's not realistic for me to ask each student to create an Adobe ID so I can get results through Adobe.com. I've been reading blogs and watching tutorials but I'm still not sure what the best method is to gather results if each student is on a separate computer. I can publish the quiz to my website-- can I also have results reported to a folder on my server (my website)? I'm confused about the internal server method--does it have to be on the computer that has the quiz, or can I copy the php files (internalserverread, etc) to my html folder on my server?
If I use the email method, does my quiz need to be published online?
Sorry for the obvious questions. I thought this was going to be simple, but after reading all the blogs about this I'm more confused!
Thanks for your help
Angela
30. Re: Quiz Results Analyzer w/Internal Server
Chinmay Baid Mar 21, 2012 7:57 AM (in response to diehlang)Hi Angela,
You can host your course on your own server. But you need to make the appropriate settings as mentioned in the blogs. Once you publish the course with appropriate settings and distribute it, you can get results of all the students on the server itself.
You can follow the steps mentioned below :
1. Copy your PHP files on any server. (your server should have write permissions enabled)
2. Create the course and set the quiz reporting preferences to Internal Server. Also, put the path of the internalServerReporting.php file in the Configuration dialog.
3. Publish the course and host it anywhere.
4. You can distribute it and get the results stored at the same location where internalServerReporting.php file is hosted.
Later, you can use Quiz Results Analyzer to view the reports.
Hope this helps!!
Regards,
Chinmay
31. Re: Quiz Results Analyzer w/Internal Server
diehlang Mar 21, 2012 8:08 AM (in response to Chinmay Baid)Thanks so much. I appreciate your quick response!
I’ll set it up and test it asap. If I run into problems may I email you again?
Angela
Angela Diehl
Instructor, Multimedia Production
Biomedical Communications Graduate Program
UT Southwestern Medical Center
Paul M. Bass Administrative and Clinical Center
6363 Forest Park Road, Suite 1020
Dallas, Texas 75390-8881
(214) 648-4028
32. Re: Quiz Results Analyzer w/Internal Server
diehlang Mar 21, 2012 8:45 AM (in response to Chinmay Baid)Hi Chinmay,
I took the quiz and selected “post results.” It asks for my name and email ID....when I hit “send” it returns a message that says “wrong URL”
Do I need to edit the php file before saving to my server?
Many thanks
Angela
33. Re: Quiz Results Analyzer w/Internal Server
JJPeople Mar 24, 2012 3:16 AM (in response to TMPRisk)I suspect the difference in your unix server's PHP configuration relates to the handling of global variables and if like me the readdir function does not return the current and parent directories, i.e. ".,.." as the first entries in the list. These two issues combined caused the Quiz Analyzer to behave differently on my two servers.
I modified the internalserverread.php script in the following way and it now works: -
<?php
switch($_POST['API'])
case 1: getCompanies();
break;
case 2: getDepartments($_POST['company']);
break;
case 3: getCourses($_POST['company'],$_POST['department']);
break;
case 4: getXMLs($_POST['company'],$_POST['department'],$_POST['course']);
break;
case 5: downloadXML($_POST['company'],$_POST['department'],$_POST['course'],$_POST['xmlname']);
break;
default: getCompanies();
break;
function getCompanies()
$exclude = array(".","..");
$dir = @opendir("CaptivateResults");
if($dir != "")
echo ".;..;";
while(($file = readdir($dir)) !== false)
if ($file == $exclude[0] || $file == $exclude[1]) {
continue;
if(!is_file($file))
echo $file.";";
closedir($dir);
else
echo "No Captivate Results found;";
function getDepartments($comp)
$dir = @opendir("CaptivateResults"."/".$comp);
echo ".;..;";
while (($file = readdir($dir)) !== false)
continue;
if(!is_file($file))
echo $file.";";
closedir($dir);
function getCourses($comp,$dept)
$dir = @opendir("CaptivateResults"."/".$comp."/".$dept);
echo ".;..;";
continue;
if(!is_file($file))
echo $file.";";
closedir($dir);
function getXMLs($comp,$dept,$course)
$dir = @opendir("CaptivateResults"."/".$comp."/".$dept."/".$course);
if($dir != "") {
$directory = "CaptivateResults"."/".$comp."/".$dept."/".$course;
if(!(is_dir($file)) && findexts($file) == 'xml')
echo $file.",".number_format(filectime($directory."/".$file),0, '.', '').";";
closedir($dir);
function downloadXML($comp,$dept,$course,$name)
$dir = "CaptivateResults"."/".$comp."/".$dept."/".$course."/".$name;
$handle = fopen($dir, "r");
$contents = fread($handle, filesize($dir));
fclose($handle);
echo $contents;
function findexts ($filename)
$filename = strtolower($filename) ;
$exts = explode(".", $filename);
$n = count($exts)-1;
$exts = $exts[$n];
return $exts;
I hope this helps.
Bests,
Mike
34. Re: Quiz Results Analyzer w/Internal Server
diehlang Mar 25, 2012 6:25 PM (in response to JJPeople)Thanks Mike. I'll give it a try!
35. Re: Quiz Results Analyzer w/Internal Server
AHamel Mar 30, 2012 4:59 PM (in response to JJPeople)I am having similar problems. I have created a short quiz to test this
feature and it will perform as expected except I have no results. You can
try it here:
http://community.cardigan.org/~spe
I was able to get someone to look at using unix and it says that I am
missing a MMTracking.swf file as soon as you open the site. I am currently
using the php code you pasted, not the original from the template folder in
Captivate. I don't believe it is collecting the answers.
Can you help?
Ann
Ann
36. Re: Quiz Results Analyzer w/Internal Server
Greek2U Mar 31, 2012 10:53 AM (in response to JJPeople)Mike,
Thank you for the modified PHP script you provided. It is ALMOST exactly what I needed. In fact, it was currently the only offered solution online that even came close to what I needed. However, since I am using a Linux-based server it wasn't working exactly right until I made some small modifications (removed one line and added another). So for those of you using the Quiz Results Analyzer with Linux-based servers, here is the secret sauce to make the internalserverread.php script work for you. Enjoy and let me know if this finally does the trick for anyone else!
break;
break;
break;
break;
break;
default:break;
if($dir != "")
echo ".;..;";
continue;
if(!is_file($file))
echo $file.";";
closedir($dir);
else
echo ".;..;";
continue;
if(!is_file($file))
echo $file.";";
closedir($dir);
echo ".;..;";
continue;
if(!is_file($file))
echo $file.";";
closedir($dir);
closedir($dir);
fclose($handle);
echo $contents;
$exts = $exts[$n];
return $exts;
37. Re: Quiz Results Analyzer w/Internal Server
RichardGetting Dec 6, 2012 1:05 PM (in response to Greek2U)My company is on the Linux (LAMP) and we tried the above for our server. The results do appear on the server but we are getting this error message and are unable to retrieve the information for the analyzer.
Any ideas on how we can fix this?
[Wed Nov 28 11:46:37 2012] [error] [client 10.99.2.194] PHP Parse error: syntax error, unexpected T_STRING, expecting T_VARIABLE or '$' in /opt/webcontent/dev/atyrcw/csctrain/internalserverread.php on line 12, referer: app:/QuizReportingApplication.swf
