14 Replies Latest reply on Jul 9, 2010 2:13 AM by karthic_vkn
    Compare Two Array
    JaxNa Level 1
      can you plz help me.
      How i can compare two array. following my code..
      var my_array:Array=Array(5,10,15,20,25,30)
      var new_array:Array=Array(7,8,9,10,11,12,13)
      for(var i:Number=0;i<my_array.length;i++){
          if(my_array[i]==new_array[i]){
              trace(my_array[i])
      Thanks in Advance,
      JaxNa
        • 1. Re: Compare Two Array
          karthic_vkn Level 1
          How do you think to compare, the value of the each array needs to compare?
          • 2. Re: Compare Two Array
            JaxNa Level 1
            yes i want compare value of the each array
            • 3. Re: Compare Two Array
              karthic_vkn Level 1
              Then you are almost on correct... See the same code which I modified little bit,
              var my_array:Array = Array(5, 10, 15, 20, 25, 30);
              var new_array:Array = Array(7, 10, 9, 10, 10, 30, 13);
              for (var i:Number = 0; i<my_array.length; i++) {
                   if (my_array[i] == new_array[i]) {
                      trace("'My Array' "+i+"("+my_array[i]+") 'new_array' "+i+"("+new_array[i]+") = Matching");
                   } else {
                      trace("'My Array' "+i+"("+my_array[i]+") 'new_array' "+i+"("+new_array[i]+") = Not Matching");
              If its not so, explain exactly what you want
              • 4. Re: Compare Two Array
                JaxNa Level 1
                Thanks a lot dear for your kindly replay ..
                Thanks Karthic
                • 5. Re: Compare Two Array
                  JaxNa Level 1
                  hey dear can you tell me one thing..
                  when my_array length is 3
                  and new_array length is 5
                  that time how i can compare two array actually i have this problem..
                  var my_array:Array = Array(5, 10, 15, 20);
                  var new_array:Array = Array(7, 8, 9, 10, 11, 12);
                       } else {
                  • 6. Re: Compare Two Array
                    karthic_vkn Level 1
                    If array has different length, then obviously the comparison will not work so the comparison must be false, that case you need to check whether the array has same length or not...
                    if (my_array.length == new_array.length) {
                             } else {
                    } else {
                         trace("array length is not matching");
                    • 7. Re: Compare Two Array
                      JaxNa Level 1
                      ya thats right.
                      when two array's length is not matching that time how i can compare array's value..
                      new_array is static array and my_array is dynamic array.
                      can u give me any solution??
                      Thanks dear,
                      JaxNa
                      • 8. Re: Compare Two Array
                        karthic_vkn Level 1
                        Then you have to find out which array has minimum length, since we restrict ‘for’ loop to run unnecessarily.
                        Here some stuff I added (we can do this in many ways).
                        var my_array:Array = Array(5, 10, 15, 20, 1);
                        var new_array:Array = Array(7, 8, 9);
                        var findMinArrayName:String;
                        if (new_array.length<my_array.length) {
                        compareTwoArrays("new_array");
                        } else {
                        compareTwoArrays("my_array");
                        function compareTwoArrays(findMinArrayName) {
                        for (var i:Number = 0; i<this[findMinArrayName].length; i++) {
                          } else {
                        • 9. Re: Compare Two Array
                          JaxNa Level 1
                          its not working dear
                          • 10. Re: Compare Two Array
                            karthic_vkn Level 1
                            Code is not working or else someother problem ?...
                            • 11. Re: Compare Two Array
                              JaxNa Level 1
                              when i take this array
                              var new_array:Array = Array(7, 8, 9,10);
                              then i didn't get "10" value
                              JaxNa
                              • 12. Re: Compare Two Array
                                karthic_vkn Level 1
                                You have to explain what you exactly want..
                                Try this...
                                var new_array:Array = Array(7, 1, 20, 10);
                                for (var i:Number = 0; i<new_array.length; i++) {
                                    for (var a:Number = 0; a<my_array.length; a++) {
                                        if (new_array[i] == my_array[a]) {
                                              trace("'new_array' "+i+"("+new_array[i]+") 'my_array' "+a+"("+my_array[a]+") = Matching");
                                • 13. Re: Compare Two Array
                                  JaxNa Level 1
                                  thanks alot dear.....
                                  sory for i gave u headch....
                                  THANKS
                                  JaxNa
                                  • 14. Re: Compare Two Array
                                    karthic_vkn Level 1
                                    you r welcome !!!
