4 Replies Latest reply on Jul 19, 2010 4:05 AM by Mahesh_JW
    Path of the choose folder
    Mahesh_JW Level 1
      Hi all,
      what is the problem
      tell application "Finder"
          set SourceFolder to choose folder with prompt "Choose PDF Folder"
          set thePa to (path of SourceFolder) as string
          set theFileList to (entire contents of SourceFolder as alias list)
      end tell
      it throws
      can't make the path of alias "......" into type string
      help me what is the problem
        • 1. Re: Path of the choose folder
          Muppet Mark-QAl63s Level 4
          You have a couple of things mixed up here. Firstly 'choose folder' is from standard additions so this does not need to be inside the tell Finder block although it can. The choose folder command returns an 'alias file specifier' which is what Finder likes best so NO need to coerce to string then back to alias again. Just pass it straight as it is then have Finder get you all the files.
          set Source_Folder to choose folder with prompt "Choose PDF Folder"
               set File_List to (entire contents of Source_Folder)
          end tell
          Also you won't find much in the way of help here with regards to AppleScript this forum is very much aimed to those who are using JavaScript with Acrobat. You would get a better level of response here…
          http://macscripter.net/viewforum.php?id=2
          • 2. Re: Path of the choose folder
            Mahesh_JW Level 1
            Thanks Mark,
            but i received the error "cant make ...... as type string"
                set thePath to (path of SourceFolder) as string
                set File_List to (entire contents of SourceFolder)
            end tell
            what to do....
            Mahesh
            • 3. Re: Path of the choose folder
              You do NOT need to use the parenthesis () or 'path of'… Just ask for 'as text' or 'as string'
              set Folder_String to Source_Folder as text
              end tell
              Folder_String -- This will return the HFS path as text
              or
              set Folder_String to Source_Folder as string
              end tell
              • 4. Re: Path of the choose folder
                Mahesh_JW Level 1
                It works well.
                Thanks Mark...
