3 Replies Latest reply on Jul 14, 2010 12:38 AM by SVenu_2703
    Help me on HSlider with two thumbs
    SVenu_2703
      Hi Friends,
      I have a problem with HSlider. I am working on a slider with two thumbs. I have a requirement to overlap two thumbs. But the problem with overlapping is i can slide in reverse also. I need to restrict that. Please suggest me solution and save my time.
      I will explain with example:
      I have a slider to select classes from 1 - 12. For this i am using HSlider with two thumbs.
      Now a user can select class range between 1 - 12. i.e., 5-6 or 8-9 or 2-9 etc..
      I am giving an option to select 1-1 or 4-4 or 5-5 by overlapping the thumbs.
      Now the problem i am facing is : user can select 9-5 or 6-1 or 5-3 etc, because i am giving chance to overlap thumbs.
      But i have to restrict that behaviour... The user should not be able to select reverse.
      I tried to Override getSnapValue method to restirct that behavior. But it is not working as expected. Please suggest me a solution for this. Please share me if you have any example which is having same or similar behavior.
      Venu S.
        • 1. Re: Help me on HSlider with two thumbs
          BhaskerChari Level 4
          Hi Venu,
          Can you post the code that you are working reproducing your problem..?
          Normally HSlider won't allow its thumbs to be dragged reverse of another one...
          Thanks ,
          Bhasker Chari
          • 2. Re: Help me on HSlider with two thumbs
            SVenu_2703 Level 1
            Hi Bhasker,
            Thanks for immediate response.
            Here is my code:
            package
            import mx.controls.HSlider;
            import mx.controls.sliderClasses.SliderThumb;
            import mx.core.mx_internal;
            use namespace mx_internal;
            public class CustonSlider extends HSlider
            public function CustonSlider ()
            override mx_internal function getSnapValue(value:Number, thumb:SliderThumb = null):Number
            if (!isNaN(snapInterval) && snapInterval != 0)
            var val:Number = getValueFromX(value);
            trace("value min max val "+value+" "+minimum+" "+maximum+" "+val);
            //if (thumb && (thumbs.numChildren > 1) && !allowThumbOverlap)
            if (thumb && (2 > 1) && !allowThumbOverlap)
            var check_bounds:Boolean = true;
            var bounds:Object
            bounds = getXBounds(thumb.thumbIndex);
            var prevThumb:SliderThumb =
            thumb.thumbIndex > 0 ?
            //SliderThumb(thumbs.getChildAt(thumb.thumbIndex- 1)) :
            SliderThumb(getThumbAt(thumb.thumbIndex- 1)) :
            null;
            var nextThumb:SliderThumb =
            //thumb.thumbIndex + 1 < thumbs.numChildren ?
            thumb.thumbIndex + 1 < 2 ?
            //SliderThumb(thumbs.getChildAt(thumb.thumbIndex + 1)) :
            SliderThumb(getThumbAt(thumb.thumbIndex + 1)) :
            null;
            if (prevThumb)
            bounds.min -= (prevThumb.width / 2);
            trace("bounds.min "+bounds.min);
            // check if thumb is at minimum, if not we can ignore the bounds logic
            if (val == minimum)
            if (getValueFromX((prevThumb.xPosition - prevThumb.width/2)) <= minimum)
            check_bounds =
            false;
            else
            if (val >= minimum)
            check_bounds =
            false;
            if (nextThumb)
            bounds.max += (nextThumb.width / 2);
            trace("bounds.max "+bounds.max);
            // check if thumb is at maximum, if not we can ignore the bounds logic
            if (val == maximum)
            if (getValueFromX((nextThumb.xPosition + nextThumb.width/2)) >= maximum)
            check_bounds =
            false;
            else
            if (val <= maximum)
            check_bounds =
            false;
            trace("check_bounds : "+check_bounds);
            if (check_bounds)
            val = Math.min(Math.max(val, getValueFromX(Math.round(bounds.min)) + snapInterval),
            getValueFromX(Math.round(bounds.max)) - snapInterval);
            return getXFromValue(val);
            return value;
            I am calling the above snippet in my application.
            But it is not working as i expected. Let us consider two thumbs as left thumb and right thumb, the left thumb should not move to right and rite thumb should move to right thumb. I can achieve this functionality if i set the boolean property "allowThumbOverlap" to false. But if i did this i cannot select range between 1-1 0r 4-4 or 9-9 etc. I have to give a chance to select range between 1-1 or  4-4 or 9-9 etc
            Message was edited by: SVenu_2703
            • 3. Re: Help me on HSlider with two thumbs
              SVenu_2703 Level 1
              Friends,
              Can i have a solutions for this. I need it very urgent.
              Venu S.
