0 Replies Latest reply on Jul 9, 2010 4:57 AM by welcomecan
    how to create cfc for this give solution
    welcomecan Level 1
      <cfcomponent>
      <cffunction
      name="doc" access="remote" returntype="Any" >
      <cfargument name="profile_id" type="any" required="true" default="" >
      <cfargument name="search_primary_storage_profile_id_only" type="numeric" required="true" >
      <cfargument name="from_where" type="string" required="true" >
      <cfargument name="from_where_response_mode" type="string" required="true" >
      <cfargument name="setting_sec_document_access_rights" type="numeric" required="true" >
      <cfargument name="customer_name_number_srch" type="any" required="true" >
      <cfargument name="file_or_folder_name_srch" type="string" required="true" >
      <cfargument name="file_extension_srch" type="string" required="true" >
      <cfargument name="document_create_dat_start_srch" type="any" required="true" >
      <cfargument name="document_create_dat_end_srch" type="any" required="true" >
      <cfargument name="dsi_yyyy" type="any" required="true" >
      <cfargument name="dsi_emp_fname" type="any" required="true" >
      <cfargument name="dsi_emp_lname" type="any" required="true">
      <cfargument name="dsi_emp_id" type="any" required="true">
      <cfargument name="dsi_filename_original" type="any" required="true" >
      <cfargument name="dsi_document_type" type="any" required="true" >
      <cfargument name="dsi_file_label" type="any" required="true" >
      <cfargument name="dsi_document_group" type="any" required="true" >
      <cfargument name="dsi_document_expiration_dat" type="any" required="true" >
      <cfargument name="order_by_1" type="any" required="true" >
      <cfargument name="order_by_1_asc_desc" type="any" required="true" >
      <cfargument name="order_by_2" type="any" required="true" >
      <cfargument name="order_by_2_asc_desc" type="any" required="true" >
      <cfargument name="Search" type="any" required="true" >
      <cfargument name="document_ocr_full_text_srch" type="any" required="true" >
      <cfargument name="and_or_setting" type="any" required="true" >
      <cfargument name="setting_search_ocr_type" type="any" required="true" default="1">
      <cfargument name="document_ocr_full_text_rank" type="any" required="true" >
      <cfset
      form.profile_id=profile_id>
      <cfset
      form.search_primary_storage_profile_id_only=search_primary_storage_profile_id_only>
      <cfset
      form.from_where=from_where>
      <cfset
      form.from_where_response_mode=from_where_response_mode>
      <cfset
      form.setting_sec_document_access_rights=setting_sec_document_access_rights>
      <cfset
      form.customer_name_number_srch=customer_name_number_srch>
      <cfset
      form.file_or_folder_name_srch=file_or_folder_name_srch>
      <cfset
      form.file_extension_srch=file_extension_srch>
      <cfset
      form.document_create_dat_start_srch=document_create_dat_start_srch>
      <cfset
      form.document_create_dat_end_srch=document_create_dat_end_srch>
      <cfset
      form.dsi_yyyy=dsi_yyyy>
      <cfset
      form.dsi_emp_fname=dsi_emp_fname>
      <cfset
      form.dsi_emp_lname=dsi_emp_lname>
      <cfset
      form.dsi_emp_id=dsi_emp_id>
      <cfset
      form.dsi_filename_original=dsi_filename_original>
      <cfset
      form.dsi_document_type=dsi_document_type>
      <cfset
      form.dsi_file_label=dsi_file_label>
      <cfset
      form.dsi_document_group=dsi_document_group>
      <cfset
      form.dsi_document_expiration_dat=dsi_document_expiration_dat>
      <cfset
      form.order_by_1=order_by_1>
      <cfset
      form.order_by_1_asc_desc=order_by_1_asc_desc>
      <cfset
      form.order_by_2=order_by_2>
      <cfset
      form.order_by_2_asc_desc=order_by_2_asc_desc>
      <cfset
      form.Search=Search>
      <cfset
      form.document_ocr_full_text_srch=document_ocr_full_text_srch>
      <cfset
      form.and_or_setting=and_or_setting>
      <cfset
      form.setting_search_ocr_type=setting_search_ocr_type>
      <cfset
      form.document_ocr_full_text_rank=document_ocr_full_text_rank>
      <cfinclude template="#application.ist_environment.ist_auth#logon/logon_status.cfm">
      <!--- Access parameters --->
      <cfset nf5.mpf = 27>
      <cfinclude template="#application.ist_environment.ist_auth#logon/logon_load_my_auth_access_variables.cfm">
      <cfinclude template="#application.ist_environment.ist_shared#/ist_display/body_main.cfm">
      <!--- Get profiles and indexed keys --->
      <cfquery name="get_active_profiles" datasource="#request.ds.docstor#" cachedwithin="#createtimespan(0,0,5,0)#">
      SELECT storage_profile_id, storage_profile_name
      FROM storage_profile_attributes
      WHERE storage_profile_active = 1
      ORDER BY storage_profile_name, storage_profile_id desc
      </cfquery>
      <cfquery name="get_indexes" datasource="#request.ds.docstor#" cachedwithin="#createtimespan(0,0,5,0)#">
      SELECT distinct
      ml.storage_profile_key_id,
      ml.spk_name,
      ml.spk_key,
      r.spr_desc,
      ml.datatype,
      ml.local_type_name,
      ml.p1,
      ml.p2,
      ml.has_options_list
      FROM storage_profile_variables_master_list as ml
      LEFT JOIN storage_profile_rule_by_profile as r
      ON ml.storage_profile_id = r.storage_profile_id
      and ml.storage_profile_key_id = r.storage_profile_key_id
      WHERE storage_profile_key_isIndexed = 1
      <cfif val(form.profile_id)>
      and ml.storage_profile_id = #val(form.profile_id)#
      <cfelse>
      and 1 = 0
      </cfif>
      <!--- <cfreturn profile_id>--->
      <!---<cfreturn form.dsi_yyyy>--->
      </cfquery>
      <cfif isdefined("form.profile_id")>
      <cfquery name="QoQ_storage_profile_key_options" datasource="#request.ds.docstor#">
      SELECT spko_value, storage_profile_key_id, storage_profile_id
      FROM storage_profile_key_options
      WHERE storage_profile_id = #val(form.profile_id)#
      </cfquery>
      <cfparam name="application.storageProfileTable.sp#val(form.profile_id)#.exists" default="0">
      <cfscript>
      if(val(form.profile_id) gt 0)
      //application.storageProfileTable["sp#val(form.profile_id)#"]["pop"] = 0;
      if(application.storageProfileTable["sp#val(form.profile_id)#"]["exists"] neq 1 or application.storageProfileTable["sp#val(form.profile_id)#"]["pop"] eq 0)
      if(not isdefined("application.cfc.cfcDocstor_search_profile_table_build") or not isCustomFunction(application.cfc.cfcDocstor_search_profile_table_build))
      {application.cfc.cfcDocstor_search_profile_table_build =
      CreateObject("component","ist_business_applications.ist_docstor.search.docstor_search_profile_table_build");}
      // Update the denormalized document index tables
      args =
      structnew();
      args.storage_profile_id =
      val(form.profile_id);
      // If focused_document_id_list is empty then the system will pick up any edits that need to be made
      args.focused_document_id_list =
      args.maxrows =
      500;
      application.cfc.cfcDocstor_search_profile_table_build.fnVerifyStorageProfileTable(args.sto rage_profile_id, args.focused_document_id_list, args.maxrows);
      </cfscript>
      </cfif>
      <!---<cfparam name="form.and_or_setting" default="and">
      <cfparam name="form.file_or_folder_name_srch" default="">
      <cfparam name="form.customer_name_number_srch" default="">
      <cfparam name="form.document_create_dat_start_srch" default="">
      <cfparam name="form.document_create_dat_end_srch" default="">
      <cfparam name="form.file_extension_srch" default="">--->
      <cfparam name="form.search_primary_storage_profile_id_only" default="1">
      <cfparam name="current_storage_profile_name" default="None Selected">
      <!--- Search Options --->
      <!--- Other inputs --->
      <cfparam name="session.ds_search.and_or_setting" default="and">
      <cfparam name="session.ds_search.customer_name_number_srch" default="">
      <cfparam name="session.ds_search.file_or_folder_name_srch" default="">
      <cfparam name="session.ds_search.document_create_dat_start_srch" default="">
      <cfparam name="session.ds_search.document_create_dat_end_srch" default="">
      <cfparam name="session.ds_search.file_extension_srch" default="">
      <cfparam name="session.ds_search.setting_search_ocr_type" default="1">
      <cfparam name="session.ds_search.document_ocr_full_text_srch" default="">
      <cfparam name="session.ds_search.document_ocr_full_text_rank" default="0">
      <cfparam name="session.ds_search.setting_sec_document_access_rights" default="1">
      <cfscript>
      if(form.from_where eq "search")
      session.ds_search.and_or_setting = form.and_or_setting;
      session.ds_search.customer_name_number_srch = form.customer_name_number_srch;
      session.ds_search.file_or_folder_name_srch = form.file_or_folder_name_srch;
      session.ds_search.document_create_dat_start_srch = form.document_create_dat_start_srch;
      session.ds_search.document_create_dat_end_srch = form.document_create_dat_end_srch;
      session.ds_search.file_extension_srch = form.file_extension_srch;
      session.ds_search.setting_search_ocr_type = form.setting_search_ocr_type;
      session.ds_search.document_ocr_full_text_srch = form.document_ocr_full_text_srch;
      session.ds_search.document_ocr_full_text_rank = form.document_ocr_full_text_rank;
      session.ds_search.setting_sec_document_access_rights = form.setting_sec_document_access_rights;
      </cfscript>
      <cfloop query="get_indexes">
      <cfparam name="session.ds_search.dsi_#get_indexes.spk_key#" default="">
      </cfloop>
      <cfif form.from_where eq "search">
      <cfparam name="form.dsi_#get_indexes.spk_key#" default="">
      <cfset session.ds_search["dsi_#get_indexes.spk_key#"] = form["dsi_#get_indexes.spk_key#"]>
      </cfloop>
      </cfif>
      <!--- END: Other inputs --->
      <!--- Checkboxes --->
      <cfparam name="session.ds_search.setting_show_ocr_text" default="0">
      <cfparam name="form.setting_show_ocr_text" default="0">
      <cfparam name="session.ds_search.setting_search_ocr" default="0">
      <cfparam name="session.ds_search.setting_search_thumbs" default="0">
      <cfparam name="form.setting_search_thumbs" default="0">
      <cfparam name="session.ds_search.setting_search_attributes" default="0">
      <cfparam name="session.ds_search.setting_search_versions" default="0">
      <cfparam name="form.setting_search_ocr" default="0">
      <cfparam name="form.setting_search_attributes" default="0">
      <cfparam name="form.setting_search_versions" default="0">
      <cfscript>
      session.ds_search.setting_search_versions = form.setting_search_versions;
      session.ds_search.setting_search_attributes = form.setting_search_attributes;
      session.ds_search.setting_search_ocr = form.setting_search_ocr;
      session.ds_search.setting_search_thumbs = form.setting_search_thumbs;
      if(len(form.document_ocr_full_text_rank)) session.ds_search.setting_show_ocr_text = form.setting_show_ocr_text;
      </cfscript>
      <!--- END: Checkboxes --->
      <!--- END: Search Options --->
      <cfscript>
      if(not isdefined("application.cfc.cfcProfileSupportFunctions") or not isCustomFunction(application.cfc.cfcProfileSupportFunctions))
      {application.cfc.cfcProfileSupportFunctions =
      createobject("component", "ist_business_applications.ist_docstor.profile.profileSupportFunctions");}
      isSuccesfulDFC = true;
      if(isDefined("form.profile_id") and isNumeric(form.profile_id))
      {isSuccesfulDFC = application.cfc.cfcProfileSupportFunctions.fnDetectSuccessfulDfcSpidPair(form.profile_id, client.dfc);}
      </cfscript>
      <!--- onclick="display_access_list('document_search_tips');display_access_list('document_search _tool_area')" style="cursor:pointer" --->
      <select name="profile_id" onChange="showIsWorking();document.form1.submit();">
      <option value="">All</option>
      <cfoutput query="get_active_profiles">
      <option value="#get_active_profiles.storage_profile_id#" <cfif isDefined("form.profile_id") and get_active_profiles.storage_profile_id eq form.profile_id> selected <cfset current_storage_profile_name = get_active_profiles.storage_profile_name></cfif>>#get_active_profiles.storage_profile_name#</option>
      </cfoutput>
      </select>
      <cfif isDefined("form.profile_id") and val(form.profile_id)>
      <span style="cursor:pointer" title="Show files where this Profile is the Primary Profile or where the file has any association with this Profile.">Filter: </span>
      <select name="search_primary_storage_profile_id_only" onChange="document.getElementById('hidden_search_primary_storage_profile_id_only').value = this.value;">
      <option value="0" <cfif not val(form.search_primary_storage_profile_id_only)>selected</cfif>>Any Association</option>
      <option value="1" <cfif val(form.search_primary_storage_profile_id_only)>selected</cfif>>Primary Profile Only</option>
      </select>
      </cfif>
      <cfif not isdefined("request.my_dfcName") or not len(request.my_dfcName)>
      <cfset request.my_dfcName = "Please Choose a DFC">
      </cfif>
      <cfif isSuccesfulDFC eq false>
      <cfset isSuccesfulDFCBgcolor = "Red">
      <cfelse>
      <cfset isSuccesfulDFCBgcolor = "">
      </cfif>
      <cfoutput>#request.my_dfcName#<cfset my_dfcName = "   DFC: ">
      <cfreturn my_dfcName>
      </cfoutput>
      <!---<cfoutput>
      <span onClick="display_access_list('document_search_tool_area_folder_options')" style="cursor:help" title="Click for Detailed Folder Search Options">
      <img align="middle" src="#application.ist_environment.ist_shared#ist_images/ist_icons/Modern/gif/24/normal/zo om_config_24.gif">
      </span>
      <span onClick="display_access_list('document_search_tips')" style="cursor:help" title="Click for Search Tips">
      <img align="middle" src="#application.ist_environment.ist_shared#ist_images/ist_icons/Modern/gif/24/normal/in fo_find_24.gif">
      </span>
      <span onClick="display_access_list('document_search_tool_area');display_access_list('document_s earch_tool_area_folder_options','close');display_access_list('document_search_tips','close ');switch_search_icon('document_search_tool_area', 'document_search_tool_area_IMG')" style="cursor:pointer" title="Click to shrink or expand the Search Option Panel.">
      <img id="document_search_tool_area_IMG" align="middle" src="#application.ist_environment.ist_shared#ist_images/ist_icons/Modern/gif/24/normal/wi n_up_24.gif">
      </span>
      <span onClick="reset_session_variables()" style="cursor:pointer" title="Reset your Session. This action will clear any issues with column alignment in the search results.">
      <img id="document_search_tool_area_IMG" align="middle" src="#application.ist_environment.ist_shared#ist_images/ist_icons/Modern/gif/24/normal/de l_config_24.gif">
      </span>
      </cfoutput>
      <td class="inactive_titlebar">
      Search Field
      </td>
      Search Value
      </td>
      </td>
      Search Fulltext
      </td>--->
      <form name="docstor_search" action="docstor_search_task.cfm" method="post" onSubmit="showIsWorking()">
      <cfoutput>
      <input type="hidden" name="profile_id" value="#form.profile_id#">
      <input type="hidden" id="hidden_search_primary_storage_profile_id_only" name="search_primary_storage_profile_id_only" value="#form.search_primary_storage_profile_id_only#">
      </cfoutput>
      <input type="hidden" name="from_where" value="Search">
      <input type="hidden" name="from_where_response_mode" value="Search">
      <!--- First Row - Folder options --->
      <tr>
      <td colspan="4">
      <fieldset>
      <legend><span class="link" style="cursor:help" title="When these are options checked, these folders will also be searched & displayed.">Options</span></legend>
      <table class="dsFolderSearchPanel">
      <tr>
      <td>
      Versions
      </td>
      <td>
      <input type="checkbox" name="setting_search_versions" value="1" <cfif val(session.ds_search.setting_search_versions)>checked</cfif> onhelp="getF1Help('137','','');return false">
      </td>
      <td>
      Attributes
      </td>
      <td>
      <input type="checkbox" name="setting_search_attributes" value="1" <cfif val(session.ds_search.setting_search_attributes)>checked</cfif> onhelp="getF1Help('138','','');return false">
      </td>
      <td>
      OCR
      </td>
      <td>
      <input type="checkbox" name="setting_search_ocr" value="1" <cfif val(session.ds_search.setting_search_ocr)>checked</cfif> onhelp="getF1Help('139','','');return false">
      </td>
      <td>
      Thumbs
      </td>
      <td>
      <input type="checkbox" name="setting_search_thumbs" value="1" <cfif val(session.ds_search.setting_search_thumbs)>checked</cfif> onhelp="getF1Help('139','','');return false">
      </td>
      <td>    </td>
      <td style="border:1px #CCCCCC outset; cursor:help" title="Show only Active Files or show only Deleted Files.">
      Show Files
      </td>
      <td style="border:1px #CCCCCC outset; border-right:0px">Active:</td>
      <td style="border:1px #CCCCCC outset; border-left:0px">
      <input type="radio" name="setting_sec_document_access_rights" value="1" <cfif session.ds_search.setting_sec_document_access_rights eq 1>checked</cfif> title="Active Files">
      </td>
      <td style="border:1px #CCCCCC outset; border-right:0px">Deleted:</td>
      <input type="radio" name="setting_sec_document_access_rights" value="0" <cfif session.ds_search .setting_sec_document_access_rights eq 0>checked</cfif> title="Deleted Files">
      </td>
      </fieldset>
      <!--- END: First Row - Folder options --->
      <tbody id="document_search_tool_area">
      <tr>
      <!--- Column 1 --->
      <td colspan="2">
      <fieldset>
      <legend>Search Keys</legend>
      <tr>
      <td align="right">
      Customer Name/Number
      </td>
      <td colspan="2">
      <cfoutput>
      <input type="text" name="customer_name_number_srch" value="#session.ds_search.customer_name_number_srch#" onhelp="getF1Help('132','','');return false">
      </cfoutput>
      </td>
      </tr>
      <tr>
      <td align="right">
      File or Folder Name
      </td>
      <td colspan="2">
      <cfoutput>
      <input type="text" name="file_or_folder_name_srch" value="#session.ds_search.file_or_folder_name_srch#" onhelp="getF1Help('134','','');return false">
      </cfoutput>
      </td>
      </tr>
      <tr>
      <cfoutput>
      <td align="right" style="cursor:help" title="File extension list#chr(10)#Example: doc,xls">
      File Extensions
      </td>
      <td colspan="2">
      <input type="text" name="file_extension_srch" value="#session.ds_search.file_extension_srch#" onhelp="getF1Help('135','','');return false">
      </td>
      </cfoutput>
      </tr>
      <tr>
      <td align="right">
      Upload Date
      </td>
      <td>
      <cfoutput>
      <input type="text" name="document_create_dat_start_srch" value="#session.ds_search.document_create_dat_start_srch#" title="Type a Starting Date" onhelp="getF1Help('136','','');return false">
      </cfoutput>
      </td>
      <td align="left">
      <cfoutput>
      <input type="text" name="document_create_dat_end_srch" value="#session.ds_search.document_create_dat_end_srch#" title="Type an Ending Date" onhelp="getF1Help('136','','');return false">
      </cfoutput>
      </td>
      </tr>--->
      <cfset thisSpk_key = get_indexes.spk_key>
      <cfoutput>
      <tr>
      <td align="right" title="#get_indexes.spr_desc#">
      #get_indexes.spk_name#
      </td>
      <td colspan="2" title="#get_indexes.spr_desc#">
      <cfif get_indexes.has_options_list eq 1>
      <cfquery name="get_storage_profile_key_options" dbtype="query">
      SELECT spko_value
      FROM QoQ_storage_profile_key_options
      and storage_profile_key_id = #val(get_indexes.storage_profile_key_id)#
      ORDER BY spko_value
      </cfquery>
      <select name="dsi_#thisSpk_key#">
      <option></option>
      <cfloop query="get_storage_profile_key_options">
      <option value="#get_storage_profile_key_options.spko_value#" <cfif session.ds_search["dsi_#thisSpk_key#"] eq get_storage_profile_key_options.spko_value>selected</cfif>>#get_storage_profile_key_options.spko_value#</option>
      </cfloop>
      </select>
      <cfelse>
      <input type="text" name="dsi_#thisSpk_key#" value="#session.ds_search["dsi_#thisSpk_key#"]#">
      </cfif>
      </td>
      </tr>
      </cfoutput>
      </cfloop>
      <cfif isdefined("application.searchColumnLbl")>
      <cfset order_by_valid_columns = "base_sec_organization_id,sec_org_name,document_folder_name,document_name,document_create_ dat,document_bytes">
      <cfset order_by_valid_columns = listprepend(order_by_valid_columns,valuelist(get_indexes.spk_key,","),",")>
      <cfset QoQ_order_by_options = querynew("ob_key, ob_name")>
      <cfloop item="f" collection="#application.searchColumnLbl#">
      <cfset QueryAddRow(QoQ_order_by_options)>
      <cfset querysetcell(QoQ_order_by_options, "ob_key", f)>
      <cfset querysetcell(QoQ_order_by_options, "ob_name", application.searchColumnLbl[f])>
      </cfloop>
      <cfquery name="order_by_options" dbtype="query">
      SELECT ob_key, ob_name
      FROM QoQ_order_by_options
      ORDER BY ob_name
      </cfquery>
      <cfparam name="form.order_by_1" default="document_name">
      <cfparam name="form.order_by_2" default="document_create_dat">
      <cfloop index="i" from="1" to="2">
      <cfparam name="form.order_by_#i#_asc_desc" default="asc">
      <!---<tr>
      <td align="right">
      Order By
      </td>
      <td colspan="2" nowrap="nowrap">--->
      <cfoutput>
      <select name="order_by_#i#">
      <cfloop query="order_by_options">
      <cfif listfindnocase(order_by_valid_columns, order_by_options.ob_key, ",")>
      <option value="#order_by_options.ob_key#" <cfif evaluate("form.order_by_#i#") eq order_by_options.ob_key>selected</cfif>>#order_by_options.ob_name#</option>
      </cfif>
      </cfloop>
      </select>
      Asc
      <input type="radio" name="order_by_#i#_asc_desc" value="asc" <cfif evaluate("form.order_by_#i#_asc_desc") neq "desc">checked</cfif> title="Ascending sort order">
      Desc
      <input type="radio" name="order_by_#i#_asc_desc" value="desc" <cfif evaluate("form.order_by_#i#_asc_desc") eq "desc">checked</cfif> title="Descending sort order">
      </cfoutput>
      <!---</td>
      </tr>--->
      </cfloop>
      </cfif>
      <!---<tr>
      <td colspan="3" align="right">
      <span id="iconIsWorking" style="display:none">Please wait...<img src="/ist_shared/ist_images/ist_icons/progress/indicator_arrows.gif"></span>
      <input class="dsButtonclass" type="submit" name="Search" value="Search" onMouseUp="submit()" onMouseOver="classchange('dsButtonfocus')" onMouseOut="classchange('dsButtonclass')">
      <input class="dsButtonclass" type="reset" value="Reset" onMouseOver="classchange('dsButtonfocus')" onMouseOut="classchange('dsButtonclass')">
      </td>
      </tr> --->
      </table>
      </fieldset>
      </td>
      <!--- END: Column 1 --->
      <!--- Column 2 --->
      <td id="and_or_label" style="font-weight:bolder; font-size:18px; cursor:help" title="Describes the current relationship between the Standard and Full Text Search options.">
      <cfif len(session.ds_search.document_ocr_full_text_srch) eq 0>
      <!--- nothing --->
      <cfelseif len(session.ds_search.document_ocr_full_text_rank) eq 0>
      O
      <br>R
      <cfelse>
      A
      <br>N<br>D
      </cfif>
      </td>
      <!--- END: Column 2 --->
      <!--- Column 3 --->
      <!---<td>
      <fieldset>
      <legend>Full Text Search</legend>
      <tr>
      <td>
      <cfoutput>
      <textarea name="document_ocr_full_text_srch" rows="5" cols="15" onKeyUp="ocr_show_srch_panel()" onhelp="getF1Help('140','','');return false">#session.ds_search.document_ocr_full_text_srch#</textarea>
      </cfoutput>
      </td>
      </tr>--->
      <cfif len(trim(session.ds_search.document_ocr_full_text_srch))><cfset show_ftr = "block"><cfelse><cfset show_ftr = "none"></cfif>
      <!--- <cfoutput>
      <tbody id="document_ocr_full_text_rank_ROW" style="display:#show_ftr#">
      <tr>
      <td>
      <span style="cursor:help" title="Search for documents that match BOTH the search fields AND the OCR text.">
      And
      </span>
      <input type="radio" name="and_or_setting" value="and" <cfif session.ds_search.and_or_setting eq "and">checked</cfif> onClick="chooseAndOrForFTSearch()" onhelp="getF1Help('','','');return false">
      <span style="cursor:help" title="Search for documents that match EITHER the search fields OR the OCR text.">
      Or
      </span>
      <input type="radio" name="and_or_setting" value="or" <cfif session.ds_search.and_or_setting eq "or">checked</cfif> onClick="chooseAndOrForFTSearch()" onhelp="getF1Help('','','');return false">
      </td>
      </tr>
      <tr>
      <td>
      <span style="cursor:help" title="The OCR search will find words NEAR one another. (More Precise)">
      Words
      </span>
      <input type="radio" name="setting_search_ocr_type" value="1" <cfif val(session.ds_search.setting_search_ocr_type) eq 1>checked</cfif> onhelp="getF1Help('141','','');return false">
      <span style="cursor:help" title="The OCR search will look for natural language matches. (Less Precise)">
      Phrase
      </span>
      <input type="radio" name="setting_search_ocr_type" value="2" <cfif val(session.ds_search.setting_search_ocr_type) eq 2>checked</cfif> onhelp="getF1Help('142','','');return false">
      </td>
      </tr>
      <tr>
      <td>
      <span style="cursor:help" title="The OCR text will be shown for files having OCR Text when this box is checked and active.">
      Show OCR Text
      </span>
      <input type="checkbox" style="cursor:help" id="setting_show_ocr_text" name="setting_show_ocr_text" value="1" <cfif val(session.ds_search.setting_show_ocr_text)>checked</cfif> onhelp="getF1Help('143','','');return false" title="The OCR text will be shown for files having OCR Text when this box is checked and active.">
      </td>
      </tr>
      <tr>
      <td>
      <span style="cursor:help" title="Enter a minimum Full Text result Rank.#chr(10)##chr(10)#Possible Range: 0 to 1000 or BLANK#chr(10)##chr(10)#A Higher Rank is a better match.#chr(10)##chr(10)#BLANK makes the Full Text an 'OR' search.">
      Rank <input type="text" size="1" maxlength="4" id="document_ocr_full_text_rank" name="document_ocr_full_text_rank" value="#session.ds_search.document_ocr_full_text_rank#" onChange="show_rank_show_ocr()" style="cursor:help" onhelp="getF1Help('144','','');return false">
      </span>
      </td>
      </tr>
      </tbody>
      </cfoutput>
      </table>
      </fieldset>
      </td>
      <!--- END: Column 3 --->
      </tr>
      </tbody>
      </table>
      <!--- Outer Table --->
      </td>
      </form>--->
      <!---<td id="document_search_tips" align="left" valign="top" style="display:none">--->
      <fieldset>
      <legend>Profile Description</legend>
      <cfoutput>#current_storage_profile_name#</cfoutput>
      </fieldset>
      <!---<fieldset>
      <legend>Search Tips</legend>
      Type a * in order to find "any text"<br>
      Example: Jo* finds John and Jones<br>
      May Also Use [&gt;=, &lt;=, &gt;, &lt; or *]
      </fieldset>
      <fieldset>
      <legend>Full Text</legend>
      If <b>Rank</b> is [EMPTY] Then <b>Results</b> = [Basic Search <b>OR</b> Full Text Search]<br>
      If <b>Rank</b> is [0-1000] Then <b>Results</b> = [Basic Search <b>AND</b> Full Text Search]<br><br>
      You may use [*] for wildcard searches.<br><br>
      Find a Phrase by using ["].<br>
      Example: "ship yard"<br><br>
      Use [And, Or, And Not]<br>
      Example: gold* and not exchange<br><br>
      To stop the Full Text Search action, clear the Full Text Search box.
      </fieldset>
      <fieldset>
      <legend>Help!</legend>
      Press the function key "F1" on the top row of your keyboard for help on this page.<br>
      If you click on a checkbox, search field, etc., then F1 will bring up help specific to that
      search element.
      </fieldset>
      </td>
      </tr>--->
      ---> <!---</table>--->--->
      <cfif
      isdefined("application.searchColumnLbl") and 1 eq 0>
      <cfdump var="#application.searchColumnLbl#" expand="no">
      </cfif>
      <cfif form.from_where is "search" or form.from_where is "resort">
      <cfparam name="form.document_folder_id" default="13">
      <cfinclude template="#application.ist_environment.ist_docstor#view/docstor_filelist.cfm">
      </cfif>
      </cffunction>
      </cfcomponent>
