1 Reply Latest reply: Jul 9, 2010 1:00 PM by Bill@VT RSS
    Should cross-references be removed before creating a PDF form in Acrobat?
    ChristyGTWE Community Member
      Hello,
      I am just learning how to create forms using Acrobat 8.0 Professional. I started off with an appendix of worksheets created in FrameMaker that include numerous cross-references. When I saved the appendix as a PDF and started adding form fields in Acrobat, I set the tab order manually for my form fields. However, when I preview the form and press the tab key to jump to each form field, the tab order continues on (after the form fields) to jump to each cross-reference on the page.
      Should I remove the cross-references from the original worksheets before saving as PDF and adding form fields in Acrobat? (Or is there a workaround for this?)
      thanks very much in advance,
      ChristyG
