2 Replies Latest reply on Jul 12, 2010 7:47 PM by nlfdss
    trying to run adobe reader update 9.3.3 on a xp sp3 box
    mnash54
      Message
      is " The upgrade patch cannot be installed by windows in staller servi
      ce because the program to be upgraded may be missing or the upgrade pa
      tch may update a different version
      of the program. Verify that the program to be upgraded e
      xists on your computer and that you have correct upgrade patch
      have right version even reinstalled it and still same message?
        • 1. Re: trying to run adobe reader update 9.3.3 on a xp sp3 box
          pwillener Level 8
          My suggestion: uninstall Reader 9.3.x completely, then reinstall it from scratch.
          There is a possibility that you cannot uninstall 9.3.x and get the same error message.  If this happens, use the Windows Installer Cleanup Utility to remove the Reader.  The utility is no longer supplied by Microsoft; use Google to find any of the dozens alternate download locations.  Let us know if you need instructions how to use the utility.
          • 2. Re: trying to run adobe reader update 9.3.3 on a xp sp3 box
            nlfdss
            I'm curious if this would work as opposed to using the "Cleanup Utility"
            Try opening a command prompt by going to Start > Run and type in "cmd" and press enter. Then enter this command:
            msiexec.exe /x {AC76BA86-7AD7-1033-7B44-A93000000001} /qb
            and see if that will uninstall the application successfully.
