5 Replies Latest reply on Aug 6, 2010 9:57 AM by the_wine_snob
    Some audio missing in CS5
    woolyboy
      Hi everyone,
      I recenrtly upgraded from CS4, and am now using a full, paid version of CS5. (Windows 7 x64).
      Using Premiere CS5, I opened a CS4 project file, and everything seemed to update smoothly.  However, I quickly discovered that some of my audio was missing. The missing audio comes from an mpeg file.  Mind you, the video comes through fine, but the audio is gone, not only in the timeline, but even if I open the file in the source monitor.  In fact, according to Premiere, there are no waveforms associated with the clip.  However, if I directly open the file in Windows Media Player, the audio plays back fine.
      Now it gets wierder.
      Other audio is working fine.  I have a handful of short mpeg clips, in which both audio and video come through just fine.
      However, my primary mpeg clip, which is quite long, is not coming through with audio.
      Any tips on this one?
      Jim
        • 1. Re: Some audio missing in CS5
          the_wine_snob Level 9
          Jim,
          Do you have Soundbooth, or Audition? If so, just rip the Audio for the original MPEG, and do a Save_As PCM/WAV 48KHz 16-bit PCM/WAV and Import that. Drag to the Timeline, with the CTI at the beginning of the MPEG Clip and Snap ON (S key), and you should be fine.
          If you do not have either of those programs, or similar, the free audio-editor, Audacity, will do the same for you.
          • 2. Re: Some audio missing in CS5
            woolyboy Level 1
            Bill,
            I successully converted it to a wav file in Audacity (I tried it in Soundbooth, but the audio wouldn't play there either).
            However, I can't just put it into the timeline like you suggested.  My movie is already complete.  The clip has already been sliced and diced into subclips and placed all throughout the movie.
            Can you think of a way to get around this mess?
            Jim
            • 3. Re: Some audio missing in CS5
              So that "long Clip" has become many smaller Instances of that Clip on the Timeline - correct?
              In that case, the only workflow that I can think of would be to manually cut up that file too, to match. I was thinking that you still had that one long Clip intact, so you could just replace the missing Audio stream, then lock that WAV to the Video, and then edit away. Sorry that I missed where you were in the Project.
              • 4. Re: Some audio missing in CS5
                SteveMark
                I had a similar problem with CS3 and m2V files. I believe that I just added the ad2ac3dec.dll to the Premier folder copying it from the Encore folder per www.slashcam.com/EN/info/Premiere-CS3--No-audio-on-some-imports-MPEG-258091.html .
                Hope this helps!
                Steve
                • 5. Re: Some audio missing in CS5
                  Steve,
                  For PrPro, up through CS3, adding the appropriate AC3 .dll from that version of Encore, did a good job of allowing AC3 Import into PrPro. Not quite sure why Adobe did not add that .dll to PrPro, but it was an easy Copy over.
                  With CS4, things did not work, and this was through CS4.1. No AC3 Import. Then with CS4.2, support was added, and I assume that it remains in CS5, but others can verify. As so many AVCHD cameras now shoot in DD 5.1 SS with the AC3 CODEC, it would seem logical to have full support for that CODEC in CS5 too.
                  Note: even with DD 5.1 SS source files, one needs the Minnetonka SurCode DD 5.1 SS Encoder plug-in (optional) to Export to DD 5.1 SS. Otherwise one gets a 2-channel mix-dwon.
                  Good luck, and thanks for reminding us of the AC3 .dll Copy method. For pre-CS4 versions, that is still the "fix."
