1 Reply Latest reply on Jul 10, 2010 5:04 PM by nealeh
    Capture action freezes mouse - Premier Elements 2.0
    Shop159ing
      I have been using Premier Element 2.0 on Windows XP successfully for many years.
      I have a Canon DV camera utilizing a firewire setup.  Just recently, when firing off a capture
      the Adobe goes ahead and captures, but I cannot stop the capture without actually turning off the camera.
      The mouse has no affect or use in the Adobe window until the camera is turned off.  Once I repower the camera,
      I can start a capture again, but the same thing eventually happens.  I have tried a different firewire cable, but have not replaced the interface card.
      Anyone work through this issue, yet?
      Thanks.
        • 1. Re: Capture action freezes mouse - Premier Elements 2.0
          nealeh Level 5
          What you describe reminds me of my wireless mouse when its batteries are close to exhaustion. Try putting fresh batteries in and see if that makes a difference.
          I use AA batteries with a built in USB connector (you just lift the + terminal cap to reveal the connector). So I always have two plugged into a USB hub ready to be swapped when the installed ones run down.
          Cheers,
          Neale
