3 Replies Latest reply on Aug 17, 2007 1:38 PM by Newsgroup_User
    Text in a table
    Jack_606
      Hi guys,
      I'ma bit confused.
      I have a table already, and when I type in text, it just appears in the cell normally.
      But I have just started a new table, and when I type text, the text comes up inside a box made of dashed black lines, and when I am finished, the table cell shrinks to fit the text, instead of just staying how it is in my original table.
      Is there any way I can make my second table just accept text normally without this box appearing and changing the size of the cells when I type?
      Regards,
      Jack.
        • 1. Re: Text in a table
          Level 7
          > up
          This means that you have selected the text and clicked on one of the
          alignment icons on the Property inspector to cause a <div
          align="somevalue">...</div> to wrap your content. This is the wrong way to
          align content in a table cell. You should select the <td> on the tag
          selector and use the Horiz drop list to select the cell's horizontal
          alignment.
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "Jack_606" <webforumsuser@macromedia.com> wrote in message
          news:fa4n95$afn$1@forums.macromedia.com...
          > Hi guys,
          > I'ma bit confused.
          > cell
          > normally.
          > up
          > cell
          > table.
          > without
          > Regards,
          > Jack.
          • 2. Re: Text in a table
            Jack_606 Level 1
            sorry I'm not to good at this. Could you exaplain how I do that. Do I right click in each cell and select something from the drop down menu?
            • 3. Re: Text in a table
              Level 7
              Click in a cell, and look at the Property inspector in DW. Find the field
              called "Horiz". Select the alignment you desire (bearing in mind that the
              default values are Horiz=left and Vert=middle).
              news:fa4u5m$i60$1@forums.macromedia.com...
              > Hi,
