0 Replies Latest reply on Jul 10, 2010 8:27 PM by SOMEONEINTHEWORLD
    Not Reading
    SOMEONEINTHEWORLD
      Hello,
                  import flash.net.Socket;
                  public var socket:Socket;
                  public function socketData():void
                      socket = new Socket();
                      socket.connect("localhost", 1234);
                      socket.addEventListener(ProgressEvent.SOCKET_DATA, progressEvent);
                  public function progressEvent(event:ProgressEvent):void
                      socket.writeUTFBytes("ARRIVAL OF DATA \n");
                      socket.flush();
                      var data:String = socket.readUTFBytes(socket.bytesAvailable);
                      textarea.text += data;
      The client is getting the data but the server is not getting the data
      <?php
      $host = "localhost";
      $port = 1234;
      set_time_limit(0);
      $socket = socket_create(AF_INET, SOCK_STREAM, 0) or die("Could not create socket\n");
      $result = socket_bind($socket, $host, $port) or die("Could not bind to socket\n");
      $result = socket_listen($socket, 3) or die("Could not set up socket listener\n");
      $comSocket = socket_accept($socket) or die("Could not accept incoming connection\n");
      echo $socketInput=socket_read($comSocket,1024); // if i comment this line client is getting the data "DATA ARRIEVED".  Not displaying anything if i uncomment it
      socket_write($comSocket, "DATA ARRIEVED");
