12 Replies Latest reply on Aug 15, 2007 4:07 PM by Newsgroup_User
    Feedback forms
    ambient2000
      I have set up some forms for this website: www.nownforevergifts.com.au (/Contact.html & /Wholesale.html)
      When you press submit, you are meant to be redirected to another page called 'thanks.html' Nothing happens when I press submit. Any ideas what I have done wrong? Regards
        • 1. Re: Feedback forms
          Level 7
          ambient2000 wrote:
          > Hi,
          > wrong? Regards
          Somehow you have messed up the form code.
          Your first line should be:
          <form name="Contact us Form" method="POST"
          action="cgi-bin/formmail/FormMail.pl" >
          Not:
          <form2 method="POST" action="cgi-bin/formmail/FormMail.pl" name="Contact
          us Form">
          Plus your closing form tag should be: </form> and not </FORM2>. Like below.
          <input type="submit" name="Submit" value="Submit" id="Submit" /></p>
          </form>
          • 2. Re: Feedback forms
            Level 7
            > Not:
            > us Form">
            It doesn't matter - either line would work the same. The only mistake I see
            there is the in both instances the name of the form cannot contain spaces.
            Validation would have caught this, Mr. Smarty. 8)
            > below.
            That would matter.
            Murray --- ICQ 71997575
            Adobe Community Expert
            (If you *MUST* email me, don't LAUGH when you do so!)
            http://www.dreamweavermx-templates.com - Template Triage!
            http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
            http://www.dwfaq.com - DW FAQs, Tutorials & Resources
            http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
            "Osgood" <notavailable@thisaddress.com> wrote in message
            news:f9u8m8$jq0$1@forums.macromedia.com...
            > ambient2000 wrote:
            >> Hi,
            > Not:
            > us Form">
            > below.
            > </form>
            • 3. Re: Feedback forms
              Level 7
              >>Not:
              >>us Form">
              Spaces or no spaces that won't affect the submitting of the form, I
              nearly always try it out before I make a reply, Mr Smarty ;)
              • 4. Re: Feedback forms
                Level 7
                >>> Not:
                >>> name="Contact us Form">
                >> I see there is the in both instances the name of the form cannot
                >> contain spaces. Validation would have caught this, Mr. Smarty. 8)
                This would also work but the '2' should be there after of the the 'form'
                <form method="POST" action="cgi-bin/formmail/FormMail.pl" name="Contact
                us Form">
                • 5. Re: Feedback forms
                  Level 7
                  That of course should be 'SHOULD NOT' not 'SHOULD'
                  • 6. Re: Feedback forms
                    Level 7
                    > Spaces or no spaces that won't affect the submitting of the form, I nearly
                    Not if you are trying to access the form's posted data by name, so, although
                    you could submit it, you couldn't process it properly or client-side
                    validate it.
                    news:f9ureo$ccd$1@forums.macromedia.com...
                    >>>Not:
                    >>>us Form">
                    >> see there is the in both instances the name of the form cannot contain
                    • 7. Re: Feedback forms
                      Level 7
                      > validate it.
                      That wasn't the question asked was it. Maybe that will be the next one.
                      • 8. Re: Feedback forms
                        Level 7
                        It shouldn't be as the formmails script validation functions does not
                        care if you name the form or not :)
                        • 9. Re: Feedback forms
                          Level 7
                          .oO(Murray *ACE*)
                          >validate it.
                          The name of the form itself is never submitted to the server. You might
                          need it for client-side scripting, though, even if using an ID would be
                          preferred then (the name attribute is just there for backwards
                          compatibility).
                          Using spaces in a control's name is something different. Technically
                          it's allowed (and works here), but most likely it's not recommended.
                          Micha
                          • 10. Re: Feedback forms
                            ambient2000 Level 1
                            I tried the things that were suggested and still haven't been able to fix the feedback forms. Firstly, I changed the name of the file from Formmail.pl to Formmail.cgi because I thought it would work.
                            The reason I changed the name of the form to Form2 was because it stopped some of the boxes turning yellow in IE. If anyone knows how to fix it, it would be greatly appreciated.
                            On my local site, when I press the submit button it redirects me to the Formmail.cgi page instead of the thanks.html page. On the remote site it comes up with an error page.
                            Thanks for any help. Regards.
                            • 11. Re: Feedback forms
                              Level 7
                              >the
                              > to
                              I don't think it matters. They are both perl.
                              > some
                              > be
                              That's your Google toolbar doing that.
                              > Formmail.cgi page
                              Yes, it should. It's the formmail page that must process the form and do
                              the redirection to the thank you page.
                              That means that your path/filename for the processing script is not correct.
                              Ask your host to help you.
                              "ambient2000" <webforumsuser@macromedia.com> wrote in message
                              news:fa00kr$ob5$1@forums.macromedia.com...
                              >the
                              > to
                              > some
                              > be
                              > comes
                              • 12. Re: Feedback forms
                                bregent Most Valuable Participant
                                The script is a perl script so it probably needs the pl extension.
                                That's just google toolbar or something similar. Ignore that.
